Question about Canon Network Camera Server VB101 Video Server
In my VB101 server there is no hole on the left of Ethernet port ! No other thin hole on the back ! How can I reset my VB101? Is it any inside switch ? Thanks
    Champion:
    New Friend:
  • 217 Answers
To the left of the ethernet port is the external device (computer) terminal, then above that is 2 card slots. to the far left is the power outlet. reset by switching the unit off for a few seconds and then back on
Posted on Mar 10, 2013
I cant loggin consol
At the back of the device is a small hole wich some has the "reset word'. Insert a paper clip for 10 secs and release with the divice on.
Feb 03, 2014 | Port Designs Oring / IES-3242GC /...
Reset linksys SLM224G4S switch
1-With the unit on, place a paper clip into the hole on the back of the unit labeled Reset.
2-Hold paper clip down for 10 seconds and release.
3-The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults
Jul 04, 2013 | Linksys (SLM224G4S) 24-Port Ethernet...
How do i split out multiple static ip's
You need to attach a DHCP-server to the hub/switch, and configure that DHCP-server to "reserve" a specific IP-address for the MAC-address for the network adapter inside each of the computers that is to receive a "static" IP-address.
For a DHCP-server, you can connect a "cross-over" Ethernet cable from one of the switch-ports to one of the LAN-ports on any "home" wired router. That "home/SOHO" router will become the DHCP-server for all the computers connected to the switch.
Nov 19, 2012 | Linksys Computers & Internet
How to reset the switch of 3C16475CS? (if no reset button)
It's called a recovery button and it is inside the switch. You need a paper clip or pin to press it. It is the tiny hole on the back of the switch
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c02581571/c02581571.pdf
Page 9 shows the hole it is labeled "8"
Comment back if you need more help.
P.S. HP owns 3Com
Aug 29, 2011 | 3Com Baseline Plus 2226 24Port Ethernet...
Ho to reset D-Link DES-1228P 24-Port Ethernet Switch to factory default setting?
This article teach you how to D-Link router to restore factory settings,di-524 as an example.
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release. (Note: Do not repower unit during this procedure.)
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
I hope this information will be helpful. Thank you for using FixYa!
Jun 08, 2011 | D-Link DES-1228P 24-Port Ethernet Switch
I forgot the default login and password
user name: rootpassword: VB101
see the full users manual here:
http://arco.esi.uclm.es/~david.villa/doc/manuales/vcc4/user_vb101.pdf
Oct 10, 2010 | Canon Network Camera Server VB101 Video...
Router does not work need to try to reset before i go and get a new router how do i reset router / dynex 5 port 10/100m router
very small button near ports mine is small square buttong SOME are inset hole you push a paper clip into hole for reset
eh?
Jun 11, 2010 | Dynex 5 Port 10/100 Ethernet Switch...
How to connect netgear fs108 to cable modem
leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
Any doubts further ? please clarify with me.... I am ready to help you....
May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
I forget my ip of TEG-S2600i 24-Port Ethernet
At the back on your switch there is a reset button. Press and hold it down for 10 seconds to reset it.
Default ip address of this switch is 192.168.0.1
May 07, 2010 | Trendware TEG-S2600i 24-Port Ethernet...
How to reset password
Unplug the router and, using something like a paperclip, press and hold the reset button on the router for 20 seconds. The router will be reset to factory default settings.
On your particular model, the reset switch is located on the back of the device, under the antenna, to the right of the 4th ethernet port and to the left of the power plug. It's a small little hole that's not clearly marked so use good lighting to find it.
Oct 24, 2009 | Belkin (F5D7230-4) Router (587009)
Canon Network Camera Server VB101 Video Server Logo
100 people viewed this question
Top Canon Televison & Video Experts
Mohamed Ismail
Mohamed Ismail
Steve Pack
Steve Pack
Are you a Canon Televison and Video Expert? Answer questions, earn points and help others
