Tempstar gas furnace fan inducer comes on but furnace will not ingnite?
    Master:
    Sergeant:
  • 449 Answers
You have something activating ths pressure switch possible blockage in the intake or exhaust
Posted on Sep 10, 2010
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
Furnace wont run until i pull a hose from the pressure switch
ok that switch is called proving switch and if it runs when you pull hose off that means switch is stuck-, normal ops- call for heat power fan inducer start and closes proving switch normally two are a dual switch positive connects to fan discharge and negative connects to heat exchanger (fan suction )this is to insure air movement threw heat exchanger( pressure differential )then and only then a trial for ignition starts check for clog in other end of tubes
Feb 21, 2014 | Honeywell Furnace Air Pressure Switch...
I have a goodman modle gms80703ana and at first the inducer fan would kick on in it's normal cycle then the furnace would shut off do to a pressure switch. Now the inducer fan only come on perodicaly...
First unplug your furnace to reset it then plug it back in with thermostat set to heat high enough to make the heat come on. As soon as the inducer motor came on you JUMP the 2 wires that go to pressure switch. Your igniter should come on and gas valve should open for heat. If the flame stay on the blower should come on after a few minutes. If it get to this point your problem could be pressure switch itself or inducer clogged.
Jan 30, 2014 | Goodman GMS807034ANA Heater
My York furnace sometimes doesn't completely ignite
A noisy inducer probably is headed for replacement.
The igniter can produce a healthy glow and still be defective. Mine had to be replaced with a new, improved one.
The thermocouple could be defective even though it seems to open the gas valve when it should.
The heat sensor in the bonnet could be defective. That controls main blower operation.
The heat exchanger could be cracked.
Jan 10, 2014 | Heating & Cooling
Rheem 90+ NG Furnace. When furnace starts, draft inducer starts, ignitor glows and gas ignites. Burners stay lit for 10 seconds or so, then the flame reduces for a few seconds then goes out. Main blower...
Check the draft inducer air switch ( vacuum diaphragm switch) If the switch is opening when the burner starts, you might have a blockage on air piping coming into the furnace. Also prime the condensate trap on the condensate drain from the combustion fan. Also check the gas pressure, if your gas pressure is dropping, the gas pressure switch will shut it down. If it's too high the moment it comes on could raise the pressure in the furnace dropping out the combustion fan proving switch.
Oct 29, 2010 | Electric Circuit Breaker Kit for Furnace
I need to replace a gas furnace thermocouple on a Tempstar gas furnace. How do I do this? Part # SV9500M2682 on Tempstar model # NUG5100BHB2
HI follow the thermocouple lead back to the gas valve undo the silver nut foloow the lead back to the pilot and undone the nut on thermocouple or it may just pull out , or the burner might have to come out to replace it , if you arenot sure on this then a local gas fitter will do this .
Jan 26, 2010 | Heating & Cooling
Heil 75kbtu gas furnace 80% efficiency installed winter 2004-2005 timeframe. the exhaust fan comes on and the green lite on the valve flashes green but the unit wont fire. a service tech asked if the pilot...
if it has a pilot, you can follow the pilot tube from the gas valve back to the burner assembly and find it. It may not have one and if this is the case, the air flow switch is supposed to close when the inducer fan comes on . If the flue is clogged, condensation in the bottom of inducer fan(would hear cracking). then after the draft safety switch is closed,the gas vavle will get 24 volts and allow the gas valve to open
Oct 27, 2009 | Cross Furnace Draft Inducer Blower 115...
My Goodman GMS 90703BXA gas furnace started making higher then normal pitch sounds yesterday. The noise seems to come from the forced draft fan and it only happens in say 3 out of 10 starts so far. The fan...
Check the vacume in your inducer motor. Ensure it is pulling at least -9. If you don't have the equipment, you'll have to wait till it has a problem. Or, pay a tech to come out and service your system, with particular attention to the inducer fan..
Dec 07, 2008 | Heating & Cooling
Heating & Cooling Logo
439 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
