Question about Whirlpool Dishwashers
Unit does notcall for water. yes, the water is turned on. at first sign of trouble only quick wash would work.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 09, 2010
I have daewoo top load washing machine model DWF 200PS 10KG
go buy a new machine they are not made to be washed with water on the outside .
Aug 11, 2016 | Daewoo Washing Machines
Not doing quick wash
Possible failure of the controller unit. Check and see if all the other functions are working. If so check the water level control unit as in quick wash the level can be set lower. Also if there is no start on the quick wash program then the program controller needs to be rechecked for output.
Nov 14, 2011 | Washing Machines
My Kenmore Washing Machine Model 110.82872100 goes through the wash cycle then gets to rinse cycle fills with water makes a clicking noise and stops. Does not drain but cycle knob moves. An electrical...
Your motor is getting overheated in wash cycle. if you turn it off for about 15 minutes and start it back up in rinse cycle will it work ? If yes, then motor is overheated. A sign that the motor is over working its self and time for a new motor.
Dec 15, 2010 | Washing Machines
When our new LG washer starts its cycle, the water seems to do quick bursts into the washer making the pipes make a bad noise. Any advice?
The quick burst of water is normal for the LG washing machines, its the way the water valves work. The noise you hear, sounds like the water lines jerking, and hitting against the wall, or the cabinet itself. You may need to get some tape, and tape the lines to the unit itself.
Mar 22, 2010 | LG Washing Machines
Won't run
yes at the bottom of washer remove panel shop vac water pump
Feb 01, 2010 | Samsung WF203ANW Front Load Washer
Leaking washing machine
maybe to pump leaking or a hose has come off for the rinse cyc that flushes the fabric softner into the tube if its a smaller amount of water.....try this select a wash cyc let it fill up and wash for a short time then inspect the front of unit for water if no water push cancel/drain and let it drain insp front still no water then I would check for a loose hose or a cut in a hose
Sep 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Hotpoint bwm129 making huming noise
Sounds like the rinse water can't come. Maybe the solenoid for cold water got stuck or a water filter needs cleaning? If the humming is louder, perhaps the drum motor (or drum) needs a little care or cleaning.
If all else fails, download the user manual and check the trouble checklist index. (Or; try learning your kenpo succession move sparring against laundry to clean it.)
Apr 14, 2008 | Hotpoint BWM12 Front Load Washer
No hot water to wash
Is the hot water hot that is coming to the washer? Are you using the correct settings on the unit? If yes to both then either the solinoid water valve is bad or the timer switch unit is bad. Try going to a totally hot water setting. While turning on the machine feel of the hot water line at the machine and see if you notice a buzz or feel a click as you turn on the machine. On this setting does water run in and is it hot or cold. If water runs and it is cold try going to a total cold setting and see if you get cold or hot water. Is this a new setup or has it been working and stopped? If new, you could have the hoses connected backward. If you get water in both hot and cold settings but cold both ways then your hot water heater is not working....let me know....
Feb 10, 2008 | Frigidaire FEX831CS Top Load Stacked...
ZDT5052 flashes quickwash light
Tarvi...I don't know what the problem is...hard to diagnose these things. If the unit is working correctly, I suggest that you simply cut the power for a few minutes and then restart it. That may clear our a trouble code.
Dec 06, 2007 | Zanussi 18 in. ZDT5052 Slim-Line Built-in...
Dishwashers Logo
29 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
