Question about Maytag MDB8601AWB Built-in Dishwasher
Maytag dishwasher stopped mid cycle with water in bottom. no touch buttons work. Should I start looking for a new one?
    Problem Solver:
  • 11 Answers
I had no lights on my control panel, eventhough power was good.
I replaced the control panel ($265 part), it worked for 2 weeks, then I now have the same problem.
Frustrated, I am probably going to buy new from a different manufacturer.
Whirlpool/maytag does not warranty electronic parts if you do it yourself.
Posted on Feb 09, 2011
Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
Jan 29, 2008 | Asko 24 in. D3120 Dishwasher
I have a Maytag Quiet Series 100 dishwasher. There is an icon with a "3" in it just to the left of "heat dry." I just noticed this "3" light is on and the dishwasher won't start when I push the...
The "3" means hold for 3 seconds to child proof it. When it's on, none of the functions work. When you hold it again for 3 seconds, it turns off and your buttons will work again.
Aug 06, 2010 | Dishwashers
My Maytag dishwaher is three years old. It will not start. The only button that will work is the cycle slection.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MDBH945AWW&siteCd=MT_EN_US&userType=Servicer
Above is your link for your manuals, use these along with the DIY self help repair website below, to troubleshoot and hopefully repair the problem.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Now this fix below may not work, but it is always worth a try, if it fits the criteria. Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Jul 05, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Water in bottom of dishwasher, how do i drain & reset?
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Apr 04, 2010 | Dishwashers
My dishwasher is 12 years old. We have hard water but we use a water softener. I have to rinse the dishes completely clean before I wash them. Is my dishwasher just getting old?
A couple things can be happening here.
1) Make sure the holes in you rotating arms are not clogged up with food particles. If they are clean them out so water will flow freely. Then run an empty dishwasher with a cup of white vinegar, this should clean it real good.
2) The water may not be getting hot enough. The water is heated with the element at the bottom of the dishwasher. A simple way to check this is by stopping the dishwasher at mid wash cycle and touch the water at the bottom of the tub. If it's not very hot, than the element is bad and needs replacing. Just weigh the cost of replacing the element to the cost of a new more efficient dishwasher.
Hope this helps.
Nov 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Can't get unit to start.I have power to unit.
Some open the door in mid cycle ? Try shutting the breaker off and restart the unit.
Jul 26, 2009 | Maytag MDB8601AWB Built-in Dishwasher
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher stopped mid-cycle
you have a bad thermal fuse in the control panel. it's the whit thing with 2 wires going to it
Sep 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Maytag MDB8601AWB Built-in Dishwasher Logo
591 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
