Question about Crosley CR248 Turntable
I purchased a Crosley CR49-TA earlier today. For the first few hours it worked great. Upon switching records, the turntable stopped spinning. I was going to reattach the belt to see if it fixed the problem. If that does not work, what are some other problems that it could be having?
    Champion:
  • Crosley Expert
  • 271 Answers
Hi, refit belt. When changing from 33 -45 speed do it whilst the platter is spinning. Styluscity@gmail.com
Posted on Sep 18, 2010
Crosley turn table is not spinning. Tried replacing belt and moving cue lever to right then left. Think it might be the arm or cue lever. Does anyone have an idea what the problem is or a solution?
Since it is new, you should probably return for refund or exchange.
My guess would be it is the micro switch controlled by the arm.
Make sure the power is turned on and the unit's function selection is set on PHONO and then gently move the tone arm to the right until you hear a "click". Remove any cassettes that might be in the cassette player. Lift the tone arm and carry it over to the beginning of the record.
TroubleShooting
Jan 27, 2016 | Crosley CR49 Portable Traveler 3-Speed...
Crosley Cruiser turntable vibration noise
How to Identify Damage in Your Record Player ' eBay
www.ebay.com > ... > Record Players/Home Turntables
They produce audible sound by reproducing sound vibrations from tiny grooves etched on the surface of vinyl records. Record players have three primary ...
Crosley Cruiser Turntable Review - YouTube
? 2:26
https://www.youtube.com/watch?v=w5KVANeimVU
Dec 8, 2013 - Uploaded by DTM
This is a review of the Crosley Cruiser turntable. ... cartridges (the mechanism that converts the vibrations of ...
Just getting into vinyl. Is there any way to improve a Cros
Dec 14, 2015 | Crosley CR8005A-TU Cruiser 3 Speed...
My turntable a Crosley CR49 is about 14 years old. It plays just fine, but have to manually reset, clicking the tone arm after every record I play, either 45s or 33 1/3. How Can I fix this?
You will need to get to the underside of the turntable. There you should find that the arm when it gets to the centre of the record it will push on a switch. This switch might be out of position or just get stuck by grease or dirt. Correcting it should solve the problem.
Dec 08, 2015 | Crosley Audio Players & Recorders
Automatic stop on my turntable is no longer working, record just spins. Player is still in the first year of purchase. Any ideas? Thanks.
If it is still under warranty then it's best to get in touch with Crosley and get them to send an engineer out. It's perhaps an out of place switch or broken one.
Apr 22, 2014 | Crosley Audio Players & Recorders
My Crosley CR49-TA won't revolve. It turns on, and
Most turntables are belt driven. Suggest you take a look inside but remember to unplug the deck first. Usually it's a simple case of slipping the belt back on.
Apr 26, 2013 | Audio Players & Recorders
Turntable plays record then stops after a few minutes, overheating?
These Chinese made plastic products are not the real thing. It can be fixed but will not operate long term like a real stereo system. For a reliable product you need to be using Technics type turntables and Samsui or Pioneer receivers to get a real system working. They are big and heavy and that is why a lot of them are still working after 40 years.
I know because I have some of those products here- they can be repaired to last as well. I do the repairs.
Jan 20, 2013 | Crosley CR49-TW Tweed Traveler Turntable...
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
Belt came off on my crosley cr49 record player
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Aug 29, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Crosley CR704 record player wont work, HELP!!!
Make sure the switch on the back for line in, is off! I had mine on and it would not play. Switched it off and all works fine!
Aug 01, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Crosley CR248 Turntable Logo
411 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
