Question about Canon PIXMA MP130 All-In-One InkJet Printer
My canon pixma mp130 is coming up the waste ink absorber is almost full , how do i fix this , can i do it myself?
  • Canon Master
  • 525 Answers
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit..........Done
I hope this help!
Posted on Jan 15, 2015
    President:
  • 1,961 Answers
Two possibilities of solving this by yourself.
First solution: Clean the absorber pads
Look inside the printer, while the ink cartridge seated on the right side of the printer, under the ink cartridge is two absorber pads. Open the cartridge cover, to position the cartridge carrier in the middle. Leaving the right portion open and expose the absorber pads. Lift it up using a tweezer. Now clean this pads on a running water. And when its clean return it back to its place. Close the cover.
Second solution: Reset the Printer after cleaning the absorber pads.
These are the steps to reset your printer and clear all the errors including ink absorber full.
1. Turn on the printer
2. Press the MENU key
3.
Press SCAN button
4.
Press the COPY button
5. Press the SCAN button then wait until it enters the service mode.
6.
Select NVRAM ACCESS further OK
7.
Select SET ABS-M LEVEL and set value equal to zero
8.
Select SET ABS-R LEVEL (if any) and is set to zero.
9.
Turn off the printer
Do this as many times until it fully reset the printer
Please give this solution a 4 thumbs up to help me improve my ratings.
Thank you for using Fixya.
Posted on Sep 09, 2010
Waste ink absorber is almost full on my Canon Pixma MP130 will not print. How do I locate this absorber and how do I clean it ?
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
Sep 11, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber full
Hi There you can try
How To Reset Waste Ink Canon Pixma MP130
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
into the service regime
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
The waste ink absorber is full.
You have to contact the Canon agent to get the waste absorber replaced. or you can continue it with pressing resume everytime.
Apr 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink asborber i almost full... how do I fix
I am providing you with a link that will provide you with everything you could possibly need as the owner of this printer. This link on Canon's Web site will give you access to user guides/manual, driver and software downloads, support, specs for the system and much, much more.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10442
This link will take you directly to the Support & Service tab on the Canon Pixma MP130 page.
(If not, simply click the tab labeled Support & Service).
Type "waste ink absorber" in the text box then click Search.
Click 1. ERROR LCD: WASTE INK NEAR FULL which will result in 4 solutions to this problem:
  • Ink absorber replacement options - mp130
  • Press ON/OFF switch to reset the multifunction device
  • The mp130 may require repair
Try 1 and 2 first. You must click on the solution to view the details.
This should also be helpful in the future event that you may need to download drivers or access the manual to troubleshoot/fix an issue. Drivers and Guides can be downloaded from the Drivers & Software tab.
Hope this helps! Share your experience by rating this solution.
Thanks for using Fixya!
Mar 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
"the waste ink absorber is almost full"
Although the instructions posted here are for a different model, the procedure is almost the same for all ink printers. (I used it to fix my HP printer.)
Even if you can't get the ink pads out, you can try to dry them with paper towels.
Important: DO WEAR GLOVES!!! Put plastic bags around your work space. The ink IS evil and will not come off of anything it gets on.
The first time I did it without and it took forever to get my hands clean again.
Feb 24, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber almost full on Canon MP130
Hi There may work
Dec 26, 2008 | Canon PIXMA MP150 All-In-One InkJet...
The waste ink disposal is almost full and it won't print
The waste ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>
WASTE INK NEAR FULL The printer has a built-in waste ink absorber to hold the ink used during print head cleaning, for example. This error message indicates that the waste ink absorber is nearly full.
Press the OK button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact a Canon1.gif service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
this answer is directly from canon
Jan 30, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Canon pixma MP130
ink waste absorber is almost full, what should I do?
Jan 20, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
67 people viewed this question
old marine
old marine
