Question about Leviton (102-5G108-RW5)
Tell me the color coding of wall jack to connect cat6 cable to the switch
    President:
  • 860 Answers
You can use either T 568 A or B providing that both ends of the cable are wired in the same format. If one side is allready ended thenI would try T568 B standard first.
Pin T568A Pair T568B Pair Wire T568A Color T568B Color Pins on plug face (socket is reversed) 1 3 2 tip tell me the color coding - 60px-wire_white_green_stripe.svg.png
white/green stripe
white/orange stripe rj45plug-8p8c.png 2 3 2 ring
white/orange striptell me the color coding - 60px-wire_white_green_stripe.svg.pngwiki/File:Wire_white_green_stripe.svg">60px-wire_white_green_stripe.svg.png
blue solid
blue solid 5 1 1 tip
white/blue stripe 60px-wire_white_blue_stripe.svg.png
white/blue stripe 6 2 3 ring 60px-wire_orange.svg.png
white/btell me the color coding - 60px-wire_brown.svg.pngttp://en.wikipedia.org/wiki/File:Wire_white_brown_stripe.svg">
white/brown stripe 8 4 4 ring 60px-wire_brown.svg.png
Posted on Sep 09, 2010
I need networking cables, which cables are best for use.
CAT6 cables & jacks are better than CAT5E.
CAT5E cables & jacks are better than CAT5.
CAT5 cables & jacks are better than CAT3.
CAT3 cables have problems going faster than 10Mbit/second.
CAT5 cables support 100Mbit/second, and seem to work with 1000Mbit/second ("gigabit") devices.
Apr 01, 2014 | Computers & Internet
How do you wire a RJ11 phone jack with cat6 wire??
I assume you are using this configuration to connect a phone and not data outlet.
The RJ11 connector is used for phones and the RJ45 is used for data.
The CAT6 cable has 8 wires and to wire this cable to a RJ45 connector 2 wires on the CAT6 cable are not connected.
Go to this site for a wiring diagram for RJ11 to RJ45.
http://www.google.com.au/imgres?q=rj11+to+rj45+wiring+diagram&hl=en&sa=X&tbm=isch&tbnid=4RlQiCWju6MukM:&imgrefurl=http://ps-2.kev009.com:8081/tl/techlib/manuals/adoclib/aixasync/asycomgd/port128b.htm&docid=zs9vggehEny1kM&w=966&h=680&ei=WWxCTpbYNeL9mAWkpLjVCQ&zoom=1&biw=1016&bih=511
Aug 10, 2011 | Computers & Internet
Dell speaker connection color code needed
  • *Turn off your Dell laptop.
    *Connect speakers to the speaker control box. The speaker control box varies depending on the speaker system you have. Two-speaker systems will have a female jack on the back of one speaker that you plug the other into the second speaker. If your system has a sub-woofer, all of the other speakers will plug into it. The connecting cords are color-coded to the jacks on the back of the control box.
    *Plug an audio cable into the "Audio-In" port on the back of the control box. If the audio cable is color-coded, it will be green.
    *Plug the other end of the audio cable into the headphone jack on your laptop.
    *Plug the speakers' power cord into a surge protector to protect your system from power surges. *Plug the surge protector into a wall outlet.
    *Turn on your speakers and set the volume at a medium level. Be prepared to turn the volume up or down after you turn your laptop on.
    *Turn on your laptop and confirm that sound is coming from your speakers.
    Thanks for rating
    Good luck
  • Jan 25, 2011 | Dell Dimension 4600 PC Desktop
    Hi, I have a 2Wire 270 DSl Modem I had bought through Qwest since they are my ISP. My home is a 1500 Sft Ranch, if the modem is in the bedroom and the Mac Book is in the family room down the hall the...
    If the walls in your house are made of lathe and plaster or concrete block, then the performance of WiFi through all the walls in your house will be very bad. The signal that you are receiving from your neighbor's modem is probably only going through two walls (the outside wall of their house and the outside wall of your house), while the signal from your modem is probably going through at least 4 or 5 walls.
    I suggest that you do not buy a new modem, but buy a wireless access point, a spool of CAT6 cable and two Leviton RJ45 wall jacks. Run the CAT6 cable from the modem to your bedroom, install the Leviton RJ45 jacks on both ends of the cable, and then connect the wireless access point to the the jack in the bedroom and the modem to the jack near to it.
    This will expand the wireless coverage in your house and allow you to buy much better wireless device than QWest would ever sell to you.
    Here is a suggestion for Wireless Access Point.
    You can buy the CAT6 cable and Leviton RJ45 jacks at Home Depot or Lowes.
    Dec 30, 2010 | Computers & Internet
    Hi, I recently bought a XTENDEX® ST-C5USBV-300 USB KVM (Cat 5/5a/6) extender KWM switch. When I connect it to a HP DC 5800 SFF desktop I can´t get any video signal when it´s connected via a...
    Well see Cat5 & Cat6 are different spec's and are wired differently...They have different wires inside the cable. You would be able to use the actual Wires, BUT they will have to be wired to the "Other" standard in the Outlet Jacks. Either that or get one that works on Cat6. http://www.connectworld.net/syscon/support.htm
    Mar 04, 2010 | Belkin OmniView CAT5 KVM Extender F1D084
    I Do Not Know How To Connect Boston Micromedia To My Computer
    The Boston Micromedia speaker set comes with two speakers (right and left),a subwoofer, and a complete set of cables to connect everything up.
    1.) Position the speakers. The two small speakers typically are spaced equal distance apart on a desk/table top to the benefit of the listener. The sub-woofer typically rests under the surface, on the floor for example.
    .) Connect the cable sets to the back of the two small speakers along with the speaker feet.
    Note: the small speaker with the volume control knob will have three cables coming from it. This will be the "right" speaker. The other speaker will have a single cable and will be the "left" speaker.
    2.) The cable ends will be color coded to match the jackson the sub-woofer. Match up the color coded cables to the respective colors on the subwoofer as follows:
    (a) White cable end (left speaker) to white jack on sub-woofer.
    (b) Red cable end (right speaker) to red jack
    (c) Purple cable end (input) to the purple jack
    (d) Green cable end (computer out) to the computer's microphone output jack.
    Note: if any of the cables are too short to reach their jacks for whatever reason, an extender cable with a female and male end can be purchased relatively inexpensively to make up the difference in distance.
    3.) Power up the system (plug in power cables to the sub-woofer and wall), play some music, and adjust the sub-woofer sound (control knob) to suit listening pleasure.
    A nice little set of speakers, I had mine for some years now and continue to enjoy them. Good luck!
    May 17, 2009 | Boston Acoustics MicroMedia Computer...
    What is the difference between, cable cat6 systemax, China and the U.S
    shouldn't be any, cat6 is an industry standard therefor the same across the board. If you are referring to the cable itself there could be stuff such as coloring on the cables, but functionality NONE.
    Apr 15, 2009 | Systemax CAT6 Patch Cable
    Cable connection part broke off in back
    Are you talking about the part that connects the cable from the wall to the tv? I do not really understand which part on tv or vcr. It is true you can use the vcr as the tuner. You still have to connect the cable from the wall to the input cable jack on back of vcr. Then you hookup the R/W/Y rca plug- in cable from the back vcr output jacks (which are also color coded) to the tv's jacks. If you only have two jacks on the tv they will probably red and black. It doesn't really matter. Go from your video output on the vcr to the video input of tv, then use one of the audio outputs on vcr and go to the audio input on tv. It should work like that.
    Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
    Leviton (102-5G108-RW5) Logo
    831 people viewed this question
    Top Leviton Computers & Internet Experts
    vimal
    vimal
    ashburton
    Michael Galve
    Michael Galve
    Are you a Leviton Computer and Internet Expert? Answer questions, earn points and help others
