Question about Sony ICF-2010 AM/FM/SW Radio
With fresh batteries and clean contacts my sony 2010 will not turn on at all
  • 3 more comments
  • robert31 Sep 09, 2010
    There is but it on
    The old batteries were just dead, not leaking
    I do have the external power supply that came with the radio but it does nothing. The radio is still dead.
    I would love to give it to a tech. to work on but I live in St. John, US Virgin Islands and there is no one here to work on it. Do you have any suggestions?
    My sony 2101 does not turn on. all switches are on, the batteries are fresh, the battery contacts are clean but no joy. I plugged in the external power supply that came with the radio but it still won't power up. I live in St. John, US Virgin Islands and there is no local tech. to take it to.
  • Sony Master
  • 17,130 Answers
Will have to check if the internal clock battery is fine. Next you must check if the battery voltage is reaching the microprocessor so a s the controller works.
For this use a multimeter to test the voltage on the mP, the if possible see if the processor is clocking. Unless this section works your phone will not be switched on.
use a magnification glass to see if there is any pins out of PCB. If so do a touch up solder around these suspected sections.
Posted on Sep 09, 2010
    President:
  • 1,851 Answers
Is there any lock - unlock switch? Have you tried that.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
  • 2 more comments
  • Stelios
    Stelios Sep 09, 2010
    Sorry for the delayed post, I took a look at the user manual. Since you have checked the lock button (take a look at the timer options too) I have to suggest you to try with power supply, if there is available. By the way you mentioned that you cleaned contacts. Does this means that the batteries were exhausted and was a leakage of acids? In that case maybe there is an internal (near the connectors) cut of a power cable.
    Thanks and regards
    Stelios
    direct fixya link:http://www.fixya.com/users/technical114
  • Stelios
    Any power supply available?
    Thanks and regards
    Stelios
    direct FixYa link:http://www.fixya.com/users/technical114
  • Stelios
    Well totally powered off. Usually these (portable) devices don't have any fuse or other protection method, so I don't assume that if you open the case you will be able to find a fuse to change. The most common problem is problem at the power jack. As the power jack cut off the batteries in order to not use batteries while it's in mains power, a possible problem here means totally loss of power. Since the radio was working fine before, why don't you get it at a technician?
    If you think that I can help you further, don't hesitate to post me a reply before rejecting my answer.
    Thanks and regards
    Stelios
  • Stelios
    I like your place (from photos).... Anyway .... Are you able to use soldering tools and a multimeter? Our purpose is to unscrew the back cover of the radio (usually some philips type screws) and check the power connector jack. Since we can not have replacements, maybe we will do some modifications in connecting the power.
    Waiting clarification, don't hesitate to post.
    Thanks and regards
    Stelios
Remote may be dead
Check it for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside the battery compartment, before inserting batteries to make sure that the batteries are in good contact.To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts. It has details about how to check a remote control.
Nov 30, 2013 | Sony Rmt-d187a Dvd Remote Control
My sony dvd rmt-d243a remote does not work
Check the remote control for its infrared emission. Check it with fresh batteries. Check its battery contacts inside the battery compartment for any dust or rust accumulated, prevents proper electrical contacts. Clean them well before inserting batteries. If still your remote control do not functions well, something wrong should be there. If you wish to get more details about how to check and clean a remote control, check this link. Pull up older posts there.
Feb 25, 2013 | Sony RM-V310 Remote Control
Remote contral not working
Check it with fresh batteries. Check the battery contacts in the battery compartment for any rust or dust accumulated, which prevents the proper electrical contacts. Clean them well and check.
Dec 24, 2012 | Sony RM-LJ304 LCD Remote Control
Hello, My SONY ICF-2010, SN 82502, has ceased to function...it cannot be powered up either by fresh batteries or the battery eliminators I have...no indication of life on the LCD display... I tried having...
http://www.eham.net/reviews/detail/479  says Over the years I've read that some 2010s were prone to static induced blowing of the front end transistor and that others had trouble with an unstable coherent AM detector. Thankfully my receiver was OK in both respects (I take care when touching the whip antenna in low-humidity environments)   that narrows down which part has likely failed
Nov 07, 2009 | Sony ICF-2010 AM/FM/SW Radio
My cyber shot camera's lens is out like it pooping out and the camera is off im scared 2 tell my mom!! help me can i fix it? please help me and when i turn it on the screen gose black then it turns of by...
It may be something more serious, or your new batteries may be too low for the camera to work properly, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera. Assuming that the batteries are fresh/fully charged, this takes care of about 90% of the startup problems. I hope it works for you.
Sep 06, 2009 | Sony Cyber-shot 10.1-Megapixel Digital...
My camera turns on, then immedeately shuts off. I
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Make sure that you are installing a fresh/ full charge battery
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jul 13, 2009 | Kodak EasyShare Z885 Digital Camera
Camera wont switch on
well assuming the camera hasn't been damaged, make sure of the polarity of the batteries when installing them. Also make sure they are all fresh and of the same kind. If one battery is bad, it will prevent the camera from turning on. If still a problem, use a "Q" tip dipped in alcohol to clean the battery contacts in the camera. If this doesn't solve your problem, contact the mfg about downloading new firmware for the camera... Hope this helps.
Jun 14, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Canon A720IS flash problem/low battery indicator
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Mar 13, 2009 | Canon PowerShot A720 IS Digital Camera
No power
I was having the same problem, I took a clean pencil eraser and polished the contacts in the camera.
Using fresh new batteries, I also lightly cleaned the contacts points with emery cloth. I cleaned with alcohal and Q-tips. Issue resolved for now.
Dec 18, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
LCD display invisible on Sony ICF-2010
I found a posting that said this usually is a problem with weak memory batteries or a bad battery contacts. I replaced batteries and cleaned contacts and the problem was solved.
Mar 09, 2008 | Sony ICF-2010 AM/FM/SW Radio
Sony ICF-2010 AM/FM/SW Radio Logo
73 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
