Question about Canon PIXMA MX310 All-In-One Printer
5B00 or 5800 error on Canon MX310 - Canon PIXMA MX310 All-In-One Printer
SOURCE: canon printer displays error
CANON
PIXMA MP450
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will turn off printer.
2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3. you will let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6. you will turn off printer by button POWER.
Posted on Dec 06, 2007
komguy
  • 2306 Answers
SOURCE: i have the error code 5b00 on my canon i905d. please help
The error code can only be reset by using diagnostic routines only available to canon shops.
Posted on Jun 30, 2009
jyackle5
  • 8197 Answers
SOURCE: Getting a 5B00 error on
error 5b00
reset waste absorber counter. here is how to reset.
1) With the printer2.gif powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
If this does not work you need to call canon.
Good Luck
Posted on Nov 13, 2009
mace1mace
  • 1138 Answers
SOURCE: canon pixma mx 320 error 5800
there are two ways you can remove the error message from your printer..
the first is to reset the printer and the second is to replace the waste ink absorber. If the reset thing did not work for your then you'll be spending money to replace the absorber.
How to reset? follow these steps
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
Hope that solve the waste ink absorber in your printer..
Posted on Aug 04, 2010
  • 693 Answers
SOURCE: canon mx310 error message 5b00
If the device is not functioning properly or to clear memory, reset it. important.gif Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. for instructions to attempt a service reset.
  1. On the operator panel, press and hold the button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Service Reset:
  1. On the operator panel, press and hold the button for one second to power off the printer. (The display will go blank.)
  2. Confirm the printer is not on and then unplug the power cord from the back of the printer.
    If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.
  3. Press the button repeatedly five times.
  4. Re-connect the power cord.
  5. Press the button to power the printer back on.
  6. Wait until the device has completed its cycling process before submitting another job request.
    • This procedure will not resolve a physical hardware issue.
      For example, a paper clip is wedged between the paper feed rollers or gears; or, the scanner assembly is detached from the inside housing.
    • This procedure will not resolve all service errors or LCD related anomalies.
      Service errors appear as four characters (a combination of alpha and numeric codes).
Posted on Aug 27, 2011
Canon mx310 is reading "check
Error 6000 is a service error, meaning that the printer needs to be taken into a repair shop.
This is a line feed error, with the problem originating from the timing disk film or the printer's logic board.
Given the complexity of the error and the cost of a new unit, you may find that it works out much cheaper just to buy a replacement unit.
Hope this helps
Lucas
Jul 07, 2011 | Canon PIXMA MX310 All-In-One Printer
I just replaced the ink in my canon mx310,now its saying check ink u051
that is the error for unknown ink level. press the OK buton for at least 10 seconds and the error should be removed.
Nov 13, 2010 | Canon PIXMA MX310 All-In-One Printer
CANON PIXMA MX310 error 6000 - What does this mean?? HOw can i fix this?
Call your local Canon dealer. They are very good at answering questions like this. Failing that, email the Canon company. I like this company very much and find them very good.
Sep 25, 2009 | Canon PIXMA MX310 All-In-One Printer
CANON PIXMA MX310 error 6000 - What does this mean and how can i fix it???
hi..
Error 6000 is a service call error, meaning that the printer needs to be taken into a canon authorized service facility for repair.
This is a line feed error, with the problem originating from the timing disk film or the printer's logic board..
thank u
rate me!!
Jul 26, 2009 | Canon PIXMA MX310 All-In-One Printer
Alram light
Did you replace the Black ink cartridge or the Color cartridge, or did you replace both?
Facing the front of the Canon Pixma MX310, did you install the Black ink cartridge to the left side, and the Color cartridge to the right side?
Do Not reverse how the ink cartridges go. Do Not install a Black ink cartridge, in the Color cartridge holder.
If the Alarm light came on, check to see if you have an error message in the LCD. (Not trying to insult your intelligence. The LCD is the little rectangular Liquid Crystal Display on your Pixma MX310 Operation Panel, to the left of the numeric buttons)
Do you have the Pixma MX310 On-screen manual?
Start>Hover on All Programs>Canon>Pixma MX310>On-screen manual
Click on the Troubleshooting heading.
If you have an error message code, click on the heading ->
An Error Message is Displayed on the LCD.
Also suggest you click on the heading -> Problems Sending Faxes.
See if the information provided has a solution to your problem.
Apr 22, 2009 | Canon PIXMA MX310 All-In-One Printer
Posted already but it seems to have vanished. I have a Canon Pixma MX310 which is displaying ... check printer 5B00 Can somebody help Thanks Dave
The response from Canon for your error code, 5B00, is as follows:
1. Press ON/OFF switch to reset the multifunction device 2. The MX310 may require repair You can access Canon's support site with specific solutions to any error message you get for that machine by clicking here.
I hope this information allows you to resolve this issue.
Apr 06, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer problem
My Canon MX310 doesn't like recycled ink cartridges, but doesn't do this.
Rjams
Jun 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
401 people viewed this question
old marine
old marine
