Question about Watches
I have purchased this PulsarY9608009 [NOS] and require an operators manual, Can you help? Howard
I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
Howard Miller Grandfather Clock
Dec 06, 2016 | The Watches
I purchased a Howard Miller grandfather clock and its keeping time but the pendulum is barely moving. What vould be the problem?
If the clock has a real clockspring mechanism ( with dozens of visible gears), then the problem is likely it needs to be cleaned.and adjusted.
How do I set time on an eh-23sa watch
http://www.lacrossetechnology.com/eh23sa/manual.pdf Hi Bill click link this will explain in detail your question i think you will find it is automatic and sets itself ..but check instructions will tell you hope this helps
Dec 23, 2014 | La Crosse Technology E. Howard Ambassador...
I bought a Festina watch k5506/4 at the shop but I have no instructions with it. can anyone help
Contact Festina at....
Watches@FestinaUSA.Com
1-800-648-9702
Unfortunately they dont post PDF files to their site but they are usually prettyicon1.png good about getting customers owners manuals. .
Aug 18, 2013 | La Crosse Technology E. Howard Ambassador...
I have a EH-23GA Gold E Howard watch that I purchased from Amazon.Com 5/16/11. While working on my lawn mower I must have bumped the crystal on something. It chipped a flake off the inside at about 2...
you can get the crystal off, but not back on. There is a special tool that is used to compress the crystal to make it fit in the bezel. Besides, if a piece chipped off, it is no longer waterproof. Take it to a jeweler and he can put a new crystal on in no time. Crystals are not expensive.
Nov 02, 2017 | La Crosse Technology E. Howard Ambassador...
Can you send me instructions on how to set the time and date on my boss's E. Howard & Co. accurate radio controlled watch? Thanks!
the maker claims setting to be automatic!
The signals for Casio watches are sent out during the night, so I would assume that your watch will be the same.
Do nothing and wait till tommorow!
If nothing happens, then go to http://www.lacrossetechnology.com/support/manuals.php and select the manual from the list.
Mar 22, 2011 | La Crosse Technology E. Howard Ambassador...
My radio watch is off by 5 hours how do i fix it The minutes are correct the hour is wrong . It didn't change with daylight savings and we tried to change it and now it is off by 5 hours. please help
I have never been able to find instructions on their web site but since most watches operate in a similar manner try the following (some experimenting may be required).
Press the mode button and your watch will cycle through the settings menu. On mine, there is a setting "HS" (hand setting) and then I press one of the other buttons (not the light button) to advance or ****** the hands.
When the setting it correct, press the mode button to reach normal operation.
Mar 20, 2010 | La Crosse Technology E. Howard Ambassador...
Watches Logo
26 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
