Question about Epson Perfection 1200 Photo Flatbed Scanner
My Epson scanner Perfection 1200 isn't compatible with my operating system Windows 7
  • mlanderso Sep 09, 2010
    The updates made no difference. Sadly Windows 7 still rebuts the advances of my scanner. They're not 'compatible'.
    President:
  • 2,777 Answers
That is correct, sadly there is no way to make the Epson Perfection 1200 work in Windows 7. Do you have the original disks for the scanner? You can try installing in Windows Compatibility mode, but I do not believe that will work. But to try it, if you have the original software do:
Run the Program Compatibility Wizard
  1. Open the Program Compatibility Wizard by clicking the Start button My Epson scanner Perfection 1200 isn't compatible - 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
  2. Follow the instructions in the wizard.
Posted on Sep 09, 2010
    President:
  • 1,851 Answers
Are you sure that your scanner is not supported by Win 7? Take a look at this link. Here are the updates for the copy utility for your scanner. I know that copy utility is not a driver, but I assume that since there are utility updates for Win 7, the win xp drivers has to be compatible with win 7. So, at the lower right change operating system (to win xp, 32 or 64 bit depends on your system) download and try the win xp drivers.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Is there a driver for my Epson Perfection 1200U scanner which is compatible with Windows 10?
Its working perfectly with Epson 2400U drivers.
  • Download and install the Perfection 2400U drivers from Epson USA, version 3.04A http://www.epson.com/cgi-bin/Store/s...rm=OSF_W_10-64
  • Connect and turn on your scanner
  • Run Device Manager
  • The Perfection 1200U will be shown under under Other Devices
  • Select Update Driver
  • Choose 'Browse my computer for driver software"
  • Choose 'Let me pick from a list of device drivers on my computer'
  • UNCHECK the 'Show compatible hardware'
  • Click on 'Epson' in the Manufacturer box, and the scroll down through model until you find "Epson Perfection 2400', and choose that, and press Next
  • Ignore the 'Update Driver warning - choose 'Yes'; to continue to install.
  • The Perfection 2400 will now be shown in Device Manager. Note that the Perfection 1200 will still be shown under Devices & Printers
  • Run Epson Scan and test the scanner. You may need to log out and log in again for program to work
Nov 03, 2016 | Epson Perfection 1200U USB Flatbed Scanner
Epson Perfection 2450 Photo scanner won't run on Win 7 Ultimate.
is windows 7 32 bit version or 64 bit version . Suggest downloading drivers that match the windows 7 operating system and installing them.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14558&infoType=Downloads
Mar 22, 2015 | Epson Perfection 2450 Photo Flatbed...
I need a driver for my epson 1200u photo scanner. my windows system is 64 bit, window 7. can you help?
I used this link today 7-24-2012 and it worked like a charm.
http://www.box.net/shared/5rxsn87mqr
A huge THANK YOU to the person who did the work that Epson
should be doing.
Without the scanner turned on, I downloaded the file, unziped it
and extracted the files. I then ran the .exe
After that I turned on the scanner and let Win 7 install the device.
Simple as pie.
Dec 09, 2010 | Epson Perfection 1200 Photo Flatbed...
I can not install my Epson scanner perfection 1200 photo on my laptop vista 32bits OS?
It all depends on what driver you have, it would probably be best if you went to the Epson web site, followed links for support and downloads and downloaded the latest driver for you scanner/operating system.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14557&prodoid=8161&infoType=Downloads&platform=Windows
When I say that, I've just had a look and it maybe the case that this scanner isn't supported for Vista and beyond.
My only other suggestion to use their contact us link and ask them.
Oct 29, 2010 | Epson Perfection 1200 Photo Flatbed...
Epson perfection 1200 photo scanner won't work now I have changed to Windows 7. I cannot find any software update to help.
Okay, after careful investigation I have found that your scanner is not windows 7 complaint there fore there is no driver solution for this scanner. If you read below the last operating system this worked on was NT
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQs&oid=14557&prodoid=8161
Now if you have windows ultimate you can run a virtual machine on this and hopes it will work, Also a dual boot will be a solution as well. Otherwise its not compatable.
Thanks and pelase do be considerate when leaving a rting to this fact.
May 26, 2010 | Epson Perfection 1200 Photo Flatbed...
Any chance of a driver for Epson Perfection 1200 scanner with windows 7 64bit
RapidShare is dead.
should be doing.
Simple as pie.
Dec 15, 2009 | Epson Perfection 1200 Photo Flatbed...
I have a new PC with Windows 7 , my scan is Epson perfection 1660 Photo. The new PC does not recognize the scanner, can you give me some advise??
Try going to the Epson website and search for your model number scanner and download and install the drivers.Check for the system requirements to make sure the drivers are compatible for win 7 though.Hope this works. Ken
Dec 09, 2009 | Epson Perfection 1660 Photo Flatbed...
I haven't Epson scanner GT-7600u driver
Please visit the epson.com drivers and support page to get the most recent drivers compatible with your current operating system.
Apr 26, 2009 | Epson Perfection 1200 Photo Flatbed...
Epson scanner perfection 1200u photo
The driver listed on the web for 2K is compatible with XP.
1) Go to the website http://support.epson.com
2) Under the SCANNERS heading select Epson Perfection Series and then your scanner model.
3) Under the Drivers & Downloads section select Windows. Download the most current driver for your Windows operating system.
4) Follow prompts through survey and license agreement. Choose to SAVE this file to your DESKTOP.
5) When the download is complete, double-click on the Epson icon on the desktop. This will automatically extract the files and begin the SETUP.
6) Follow the prompts to install the scanner, and click on FINISH when prompted.
7) At this point reconnect the scanner to the computer.
8) You will see an ADD NEW HARDWARE WIZARD. Make sure INSTALL THE SOFTWARE AUTOMATICALLY (Recommended) is checked and click NEXT.
9) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO TESTING, click CONTINUE ANYWAY. Then click FINISH.
10) Your scanner is now installed. Restart your computer before testing.
Dec 03, 2007 | Epson Perfection 1200 Photo Flatbed...
Epson Perfection 1200 Photo Flatbed Scanner Logo
114 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
