Hi l have avr 134 cannot produce the dts sound using hdmi connection thru media player.
The hdmi connection on avr 134 is only for switching the video.use toslink(otical)to produce dts.
Posted on Feb 12, 2011
How can i connect my denon 5805ci with my new tv 4k & 3D sony 65"
Are you sure that model is HDMI v1.4 compliant? I know my Denon 8508 is not so I use optical outs to get 5.1 surround sound.
Sep 08, 2014 | Denon AVR-5805CI A/V Receiver Dolby...
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
NO SOUND FROM 6 MONTH SHARP AQUOS 60" LCD CONNECTED TO DENON AVR 1312
Check to make sure that when you are on that input that HDMI shows up in the front display. If it does not, then you need to turnit on. If it still does not, you could have a problem with your HDMI board on your receiver not recognising the signal.
Jul 03, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
No Audio in HDMI THRU Onkyo HT-R380 Receiver
Hello, I am sorry about your issue. I suggest that you contact us at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Mar 03, 2017 | Onkyo HT-S3300 Theater System
I have a denon avr 1610 and it is connected to a sony blu ray S370. when i play a blu ray the HD sound i.e DTS HD-MA and Dolby True HD does not give proper sound and when turn on the full volume the there...
Make sure you have connected the blu ray players HDMI out to the Denon's HDMI in. HD sound is passed only through the HDMI port. And in the BD370's sound menu disable downsampling ( i.e enable uncompressed PCM audio for HDMI ).
Jun 23, 2011 | Audio Players & Recorders
My Denon AVR-5800's optical (toslink) inputs no longer work. My Tivo, DVD player, HD DVD player, etc. does not produce sound so I know it's not the toslink cables. I've configured the assignments...
Press the input mode on the front of the unit to select auto while on the input you want to use if this is does not work you will need repair on the unit
Jul 04, 2009 | Denon Audio Players & Recorders
Onkyo tx-sr806 reciver ''DTS HD''
hdmi connection between player and AVR. Right?
I am sure you would have also done the first time setup and set all the 7 speaker as well as the subwoofer thru your auto or manual speaker set up and that the reason you are getting Neo6.
On your Receiver, please also check the format of the digital input signal thru "Displaying Source Information" Press the [RECIEVER] button, and then press the [DISPLAY] buttorn repeatedly to cycle thru the available information.
a).. If the information shown say that DTS - ES Discrete, DTS- Matrix, DTS -HD and so on.... then we need to check as to why the receiver is not accepting the signal.
b).If the information shows otherwise and a 7.1 signal is not availalbe, then its possible that the source(in this case the BD player/or the recording is not sending the required signal).
lets take the case (a). In this case if you have all the 7.1 set up in place and you are getting the required signal , then you can assign a default listening mode to each input source that will be selected automatically when you select each input source.
Press [RECEIVER] button followed by [SETUP] button and enter listening mode setup, use up , down buttons to select the input source that you want to set and press [ENTER].
then use [up], [down] button to select the signal format that you want to set.
then use the [[LEFT] and [RIGHT] buttons to select a listening mode.
When you are finished, you can press [SETUP] again.
The above is with experience with ONKYO AV Receivers. In case you have a problem , please let me know so that I can go thru the SETUP menu of your particular receiver i.eTX-SR- 806.
HOpe the above sort out. DO let me know.
Please do rate this solution and thanks for using FixYa!
Mar 05, 2009 | Onkyo TX-SR803 Receiver
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
Cannot get dts from my Harmon Kardon AVR 300 via my Blue Ray
I'm not sure if this solution is still necessary however:
I own a H/K AVR300 and have a PS3 hooked up via HDMI to the TV and Optical TOSLink to the receiver. I have no troubles selecting between DD 5.1 and DTS 5.1. I can even select trueHD whatever format but I can't detect an audible difference, I think that mode might be downgraded back to regular DD5.1...
Hope this helps...
Mar 23, 2008 | Harman Kardon AVR 300 Receiver
240 people viewed this question
 Grubhead
Grubhead
