Question about KitchenAid Architect® II KBRS19KTSS Stainless Steel (185 cu ft) Refrigerator
I have a KitchenAid Refridgerator and the Drip Pan which catches the water is broken. Can you tell me how I can purchase another one on line? The model number is KBRS19KTSS2
  • casspecial Sep 09, 2010
    Hi e-Guru,
    Thanks for your assistance. You were very helpful. I will recommend FixYa.com to all of my friends.
    Thanks once again.
    President:
  • 2,777 Answers
Hello there, the easiest way is either directly through KitchenAid or from an official reseller. I recommend you call 1-800-422-1230 or to locate the nearest authorized reseller, which you can do at:
http://www.servicebench.com/servlet/WebSideServlet?Request_Id=APPWhirlpoolDealerLocateBrandedGoto&Request_Server=servicebenchpublic&Request_Brand=K&Request_ReadUrl=Y
Please let me know if you need further assistance.
Posted on Sep 09, 2010
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link to order the part :-
http://www.repairclinic.com/Appliance-Parts?s=t-KitchenAid%20Refridgerator%20Drip%20Pan%20-%3d%3d
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
Water leaks
Need more information
Does the refridgerator have plumbing for water/ ice? Is the water connected? Check that fittings are tight and not leaking.
How old is your machine? Older refridgerator have a drip pan in order to be frost free. Drip pan could be not in correctly or the hose from compressor is not flowing to drip pan.
Is the refridge level?
Oct 15, 2015 | Whirlpool Refrigerators
The drip pan that sits under the freezer side of our Kitchenaid Superba side by side refrigerator is full of nasty looking black water that I wanted to clean out but I can't figure out how to get it out of...
well to take that out ? which isn't normal part of it the drip pan catches water from the fridge / freezer and is caught in the pan while the evaporator generates heat to dry the pan out!! so if you really must remove it then you have to remove the wire in front of it to get it out other wise you just unplug it and reach in there with a brush to clean it
Jan 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
Refridgerator side not cooling. No air movement.
vent clear but vent opening arround vent frozen or coil is frozen eithor way you probably need a thermostat and a timer
Jul 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
Do I need to empty the water from my drip pan
the pan is there to catch condensation from the compressor during the refridgeration cycle. the water build up to me indicates one of two things. Either the refrigerant level is low and it is freezing up then thawing, or if you have ice or water dispencer it could have a leak in the line. the only thing other than that is a leak in the magnetic door seal or other insulation causing condensation. hope this helps
Jun 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
WATER LEAKING FROM INSIDE BACK OF REFRIDGERATOR SAMSUNG 267LASH
The frigerator has a drip pan it may need to be empty. Check the water line for leaks going into freezer.
Apr 11, 2009 | Refrigerators
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
GE Profile TFX27PF/TFT27PF Refridgerator
There is a line from the defroster catch pan, up under the freezer, to an evaporation pan, down under the bottom. If it becomes clogged with dirt, bugs, whatever, the catch pan will overflow, and leave a puddle on the floor. Find it and unclog it.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge
Clean the door seal and ensure that there are no gaps between the sealing surfaces of the door seal and the refrigerator, if there is, relatively warm moist air will continually feed condensible moisture to the cold gap in the seal and the condensed water will drip on the floor. If the door seal its self is broken or torn it will have to be replaced to stop the drip.
Hope this helps.
Mar 16, 2008 | Refrigerators
Drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Dec 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Architect® II KBRS19KTSS Stainless Steel (185 cu ft) Refrigerator Logo
82 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
