Question about John Deere Garden
My jd stx38 will not go into reverse. reverse gear and shifting fork have been replaced. Should i replace the linkage and how would i adjust it
SOURCE: Broken Linkage on a Manual Transmission?
what kind of vehicle is it?
Posted on Dec 15, 2008
harley9701ha
  • 424 Answers
SOURCE: 1993 Ford Ranger linkage
Sounds like the shifter cable,if it is and automatic trans. has broken. look at the trans selector under the truck and see if it moves when you select different gears.If it doesn't its the cable
Posted on Jan 29, 2009
  • 83 Answers
SOURCE: JD mower won't shift into gear.
Did this help?
Posted on Apr 01, 2009
  • 234 Answers
SOURCE: 1982 rabbit shift linkage
There is a plastic ball that is in the shift linkage that also wears and is usually not included in the shift linkage bushing kit. It is attached to a metal piece and is bolted to the shift linkage. This is generally the problem if you already replaced the bushings.
Sometimes the linkage is out of adjustment but I would make sure that the ball is not worn first. They generally cost $5.00 - $8.00 or so.
If you need to adjust the linkage you can try the following, but if the bushings or the ball is worn adjustment will not do any good.
There is an adjustment on the shift rod that goes from the shifter to the transmission. It is a rod slipped into a tube with a locking collar or clamp.
The way that I do this is to make sure that your vehicle is in 1st gear and then loosen the bolt on the clamp.
Make sure that the clamp is loose enough so that the shaft can slip in the tube. Put the shifter in the 1st gear position and then tighten the clamp.
You may need to fiddle with this a little to get it in just the right spot.
This is much easier if you have an assistant.
Posted on Apr 15, 2009
  • 149 Answers
SOURCE: car will not shift into gear
Sounds like a linkage/cable to me. Disconnect the linkage at the transmission and move the shift actuator by hand to see if there is the same things happening. Don't try to do this with the engine running unless someone is holding the brake inside the car.
Posted on Jul 03, 2009
1994 FORD F150 5 SPEED MAZDA MANUAL TRANSMISSION SHIFTS INTO ALL GEARS BUT REVERSE
99 00 01 02 03 FORD F150 MANUAL TRANSMISSION 5 SPEED MAZDA-TOYO KOGYO 4X2 8 CYL
will it shift if you double clutch ?
might be a shift linkage adjustment
internal shift fork has broken a scroll pin
clutch fork movement ok ?
Nov 04, 2016 | Ford F-150 Cars & Trucks
How can i adjust the gear linkeage on my 2000 ford focus it is hard to select reverse gear occasionally.5 speed manual
You may want to grease the fork sliders on the top plate. Check the nylon thickness on the forks for excessive wear. Check for excessive shaft end play between the gears and the case. Make sure the detentes on the fork sliders fully engage. The shift linkage arms have bushings so make sure there isn't excessive wear on the reverse arm .
Sep 15, 2016 | 2000 Ford Focus
Why cant i select reverse gear ?
Mark, reverse linkage/cable out of adjustment or a bad reverse gear/fork/bearing.
Apr 10, 2016 | Peugeot 307 Cars & Trucks
Goes into reverse but once u give it throttle it pops out until back to idle
Joe,check linkage/cable for damage and adjustment first, faulty reverse gear syncro ,bent shift fork or bad reverse gear.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 25, 2016 | Miscellaneous
Samurai 5th/reverse rail fork stuck
Hi Amanda
This sounds very much to me like a linkage problem. I think your best bet would be to take it to your mechanic for him/her to have a look at it and fix it properly.
Hope this helps.
-Steve
Apr 02, 2015 | 1992 Suzuki Samurai
I have a 1987 Mazda B2000 pick up. My shifter will not fit back on my newly re-built transmission. Do any other shifters work with this model as I am unable to locate an original for replacement.
I'm sure you have checked the shifter and shifter spring,,...Shifters can be rebuilt also....Make sure your clutch linkage is properly adjusted...The clutch is non adjustable...They may have got air in the hydraulic lines while removing and installing...This would give you a spongy pedal ...Most shifters in order to put it in reverse you push over and up or over and down......if shifter is loose and wobbly it won't have enough force to push the reverse shift rod....However if shifter is in great shape it sounds like the reverse shift rod could be hanging up and not sliding the shift fork...It could be the rebuilders fault......Reverse gear is the largest gear in the transmission and it is located at the back of TRANS which means it will require more force to put in reverse.......I would take it back to rebuilders shop and tell them something isn't right with going to reverse gear...if you wait too long they will think it is something you may have done by incorrect shifting.....
Feb 06, 2015 | 1987 Mazda B-Series
94 2x4 polaris 400 ...wont engage in reverse at all
try dissconnecting the reverse linkage from the shifter and then manually by sliding just the rod see if it goes into reverse if it does adjust your linkage if not it may be your shift fork or reverse gear
Apr 05, 2011 | Polaris ATV
89' Chevy Silverado Truck- All gears work but REVERSE
Check the linkage at the transmission. Have somebody move the selector while you watch the linkage move. It might be out of adjustment for reverse, or be binding up.
Aug 20, 2009 | 1994 Chevrolet S-10
My jd stx38 riding mower doesn't go forward or reverse after I re
Check the drive belt but if this is a hydro you probly have a bad trans. Best bet get a new mower.
Jul 26, 2009 | Garden
Reverse gear spits out
is it manual or automatic. Spits out. Being an 85 golf, There are parts on vehicles that need adjusting over time. There are parts on these adjustable parts that need maintenance and after say 24 years lol, replacing. Shift linkage adjustment and shift bushings are the most common cause of reverse (spitting out). Purchased online for 8.00 U.S. or get the nice neoprene if you plan on keeping the golf. Shift linkage adjustment is easy if you are a professional. If your not, plan to be on your back and making alot of trips back and forth if you don't know what your doing. Don't let some crook talk you into serious money. Adjust your linkage , but first replace the shift bushings. The little things are what tell the big things what to do.
Jun 28, 2009 | 1996 Volkswagen Jetta
Garden Logo
188 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
