Question about Indesit Washing Machines
Washing machine very noisy when spinning - Indesit Washing Machines
    President:
  • 670 Answers
Probally the bearing seal failure causing water to seep into the bearings. You will need to replace the seal and bearings to fix. It is a big job since the washer needs to be taken apart to replace the bearings.
Posted on Sep 09, 2010
Hotpoint aquarius wf620 washing machine,machine very noisy when in high spin working ok when golng through program
While spinning every washing machine is very noisy as it rotates in very high speed.This is normal and no need to worry.
Thank You
Sep 08, 2010 | Hotpoint Washing Machines
Simpson 175 washing machine: spin cycle noisy and motor cuts out after short spin. Bowl feels stiff
Hi just read your posting.Now from the information on your posting the machine is noisy on spin and your motor is cutting out after a short spin.Is this correct?Now does the motor cut out during a wash cycle?If the motor only cuts out during the spin cycle , and with your machine being noisy on spin,I think the fault will be your bearings are corroded.With the bearings being corroded it puts more load on the motor causing the inbuilt thermal overload in the motor to activate and turning the motor off to save it from burning out.Please reply with additional information on, if it cuts out on wash and I am sure I can help you further.
Aug 07, 2010 | Washing Machines
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Washing machine really noisy on spin!
Probably main drum bearings worn
If you turn the drum by hand and it feels rough or noisy ,then definately bearings worn and noisy.
Nov 19, 2008 | Washing Machines
Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
LG direct drive washing machine is getting increasingly noisy when at the spin stage
generally when a machine gets noisy in spin cycle it is due to bearings being worn open the door with the machine empty and try lifting the the drum upwards if it moves then it will be the bearings
Jul 12, 2008 | Washing Machines
Danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 13, 2008 | Danby DWM99W Top Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
