Question about Philips 170W4P (Black, Silver) 17 in. Flat Panel LCD Monitor
Philips 190W4 Monitor, started to get error message Attention selected input not available, then screen goes blank, it then come back on and then goes to Automatic adjust then asks me to Save Yes No try Ok for 30seconds this isn't working, also had other messages popping up. Thanks
  • 10 Answers
SOURCE: monitor power problem
It sounds like an internal issue, more likely the LOPT components are overheating, possibily due to dust collection causing temporary shorts, or an arcing capacitor. The randomness is due to weather conditions, high humidity more likely to monitor wil shut down, the dryer the weather the moisture in the dust would have evaporated, resulting in nothing happening, and a working monitor. I suggest trying this first:- Unplug the monitor from the outlet, and the computer, open the case, but REMEMBER! the monitor can still pack a punch even when it's unplugged from the outlet, (once the case is open, it is completely safe if you accidently brush against a metal part, but under no circumstances (unless you know what you're doing) remove the rubber cap that's either on the top, bottom, or sides of the back of the screen, doing so can result in a massive jolt of up to 20,000 volts),use a can of compressed air to blow out the dust, making sure you clean right up to the control buttons on the front, screw the case back in place, then try the monitor, if it's still the same, and unless you are a qualified electronics engineer and would like to repair the monitor yourself, I suggest you take it to a repair shop.
Posted on Jun 18, 2007
  • 6 Answers
SOURCE: screen only stays on for 2 seconds at a time
just an update...I have fitted a new cable (pc to monitor) and it has been on for 2hrs now so fingers crossed!
Posted on Sep 23, 2008
SOURCE: Every few seconds a box
Solution: I followed the advice given by Guru and it fixed the problem. Thank you.
Posted on Jan 22, 2009
SOURCE: Theft Mode Enabled on Philips 190s9fb/27 monitor
wich one is the default? this thing with theft mod pist me offf!!!... >:(
Posted on Dec 28, 2009
SINN3D
  • 85 Answers
SOURCE: Monitor display message : = No Video input. Pls
if cables are ok; Take your computer down to the repair shop.
Posted on Jun 20, 2010
Blank screen
Any error message about inputs? Maybe that clicking sound happens when iit connects to the selected input, but nothing is connected. Can you scroll thru all the inputs? If so, turn on any devices connected to the JVC and scroll thru each input to find the one you're looking for.
Jul 11, 2013 | JVC Audio Players & Recorders
When I turn the monitor on I get a message "In
Most Dell LCDs have multiple inputs and they will go into "standby" while waiting for a signal from your PC. This happens when your PC goes into "sleep" mode or if you are sure your PC is not in "sleep" mode then usually the LCD is not in the correct input selection. Check the input selection for the appropriate input. As always, make sure the cables are securely connected. Hope this helps.
Jun 15, 2011 | Dell E173FP 17" LCD Monitor
When using computer for about 10 min, monitor goes blank with an error message of"No Input Signal" then computer rebuts several times. Any idea's?
Its possible that your computer maybe having a driver conflicting with your monitor. My suggestion would be reinstall the software that came with your monitor. If you don't have that go to the companies website that produced the monitor and download the newest monitor drivers.
As well for an extra double check, make sure that all wires connected to the monitor and the computer are in place.
(might check your monitors energy saving setting)
May 09, 2009 | Computers & Internet
Screen shows message "no input signal" and monitor goes to sleep.
monitor show "no input singnal" error masage when not gating any type of video singnal ,
so if u realy check your monitor wires for correctty plugged in .
then:-
Two possibilities:
either the video/mainboard of the monitor is defective; or
the video card/ CPU is the faulty.
A way to verify is to try the PC with another monitor or to try the monitor in another PC.
thanks
Apr 30, 2009 | HP vp17 Monitor
Hello, My color isn't right on my computer. The box that pops up says "RGB no input signal". How can I fix this problem? Thanks Debbie
REMOVED THE 15 PIN PLUG - I GET A SCREEN MESSAGE - SYSTEM CABLE DISCONNECT! WHEN I PLUG IT BACK IN THE MESSAGE RGB NO INPUT SIGNAL APPEARS FOR A FEW SECONDS THEN THE MONITOR GOES INTO STANDBY AND THE SCREEN STAYS BLANK,
I ALSO PLUGGED THE MONITOR INTO MY LAPTOP AND THE SAME MESSAGE APPEARED
Nov 18, 2008 | Computers & Internet
Monitor won't stay on. Error message comes up that says "no input signal", then monitor goes out.
Problem with the monitor, monitor cable, or video output. For monitor, if you have more than one input, make sure it's set to the correct one. Try a different cable. Try a different monitor. Check your video card settings--if you see the BIOS bootup screen while it's coming up then the Windows splash screen, then monitor blanks out, it's a Windows display setting. Boot into safe mode, then change settings--
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 31, 2008 | HP Computers & Internet
Help with my 190S monitor
I have Philips 19C monitor. From today, every 5 secs an attention message
"osd main controls locked and unlocked"
The AUTO(OK) bottons for 10 sec not give nothink
What i can to do with this?
Gregory
my mail - communar@agry.gov.il
Thanks
Aug 22, 2008 | Computers & Internet
Screen only stays on for 2 seconds at a time
Aug 19, 2008 | Philips 19 in. CRT Monitor
No input signal
Check connections, Hertz rate, and settings (if you can read them). Otherwise, it may be time to whip out the cash and get a new monitor and/or computer.
Aug 17, 2008 | Computers & Internet
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Philips 170W4P (Black, Silver) 17 in. Flat Panel LCD Monitor Logo
43 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
