Question about Toshiba Televison & Video
How to Autotune the stations in Toshiba TV 29VF7UC with the remote control
5 Suggested Answers
SOURCE: Code for zenith remote control for toshiba tv
I found the code
Posted on May 22, 2008
CheriT Dish
  • 146 Answers
SOURCE: no sound control: Toshiba T.V. set. ; Hand remote
Hi, Cheri Torres with DISH Network Customer Service. I came across your post and wanted to see if I could help. The information you provided leads me to believe that you will need to address your DISH Network remote to your Toshiba TV. There are a few different codes for each of our different models of remotes. I will list here for you the codes for our more popular models of remotes and also the instructions for addressing your remote to your TV. I hope you find this information useful and if you have any further questions or concerns feel free to email me anytime at Cheri.Torres@Dishnetwork.com and I will be happy to help!
Instructions for addressing the remote to the TV
  1. Turn the Television On
  2. Press and Hold the TV Mode button until all other mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button.
    Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Posted on Feb 23, 2011
SD Tech
  • 14553 Answers
SOURCE: TV does not autotune to all stations and does not store stations
The set has a EPROM somewhere that stores that info--either a stand alone one or one incorporated into the microprocessor the set uses.
The tuner if bad likely will not cause it to "forget" stored channels.
A possible way AROUND this would be the use of a cable/sat box connected to rear inputs on the set---you would sit on that input and change channels via the box which can usually be programmed to skip up/down channels you do not want---straight around the issue.
Posted on May 29, 2012
SD Tech
  • 14553 Answers
SOURCE: I 've lost the remote control for our toshiba super c3 tv, can I buy another Toshiba control ?
Try the toshiba site or Google the model number with "remote" to try to locate an original not a universal.....
Posted on Nov 05, 2012
Control
1) tight the springs contacts batteries with pliers, for better contacts.
2) clean the contacts batteries.
3) open the remote control and clean the Keypads from oxide, dust, and special spray contacts or alcohol.
4) Reset the code again, and try it. if the problem persist, go to the repair shop TV for fix it.
God bless you
Jun 20, 2012 | Toshiba Rem48tvb Remote Control
May 29, 2012 | Televison & Video
Can you tune Hitachi 32LD8D20U B without the remote
If the set have a 'Menu" button on its front panel, you can so this. If not, you must have a remote control to make it autotune.
May 09, 2012 | Hitachi C21-RF80S 21" TV
Bush tv tuning to arerial
Hello
Connec the external areal to its ariel socket at its back side, and get into its meny option, select 'autotune', and press vol (+) button on the remote control. If the set ahs a 'Menu" button on its front panel, you can do this by pressing the Menu button, surf thorugh, select autotune and press Vol(+) button once.
Feb 28, 2012 | Bush Televison & Video
Program dish remote to my curtis mathes tv .
Hi rosecorbin,my name is Mike Houston of DISH Network and I wanted to give you the codes toprogram your remote to your Curtis Mathis TV. The codes are; 516, 573, 680,652, 665, 667, 668, 670, 674, 659, 590, 650, 664, 708, 641, 645, 703, 712, 526,660, 654, 658 and 506. You will need to push and release the TV button and pressthe 3 digit code and press the # button, I will also leave the steps for a PowerScan. http://www.dishnetwork.com/SupportSection/sat-autotune
Apr 03, 2011 | DISH Network IR Remote Control
Have lost all my hd tv stations
Hello
Just reset the TV to factory settings and retune it using auto tuning fuction from the Menu option.
To reset it to factory settings, do the following:
Turn on the TV. While holding down "UP arrow" button on the remote control, press the POWER button on the TV. [The TV will turns itself OFF and then back ON again. Release the "Up Arrow button.
This operation will clear all your customized settings including Paremtial Lock settings.
in otherwords, this is the process to unlock the TV if it is locked.
Retune it by autotune fuction. All the lost stations will emerge again.
Ok.
Jan 20, 2011 | Sony BRAVIA KDL52XBR2 Television
How can i autotune my soney trinitron tv iv lost the manual
Hello
Enter menu, and select the [autotune or auto search] function with the help of Prog+ Prog- and Vol+ and Vol- buttons. After that function highlighted press Vol+ button once and release. The TV will tune and store automatically in its memory, all the transmitting stations at that time, and after tuned the entire band it will finish tuning and will display the first channel. You must select auto tune for this. Not manual tune or fine tune functions. A horizontal bar will run across the bottom side of the screen indicating that the tuning process is in progress, and it will reset three times to zero and will continue tuning. It is due to the auto band selection is done inside the microcomputer of the tv. No other functions will response anymore, till autotune process is completed. Ok.
Oct 19, 2010 | Sony Televison & Video
Toshiba tv 2151tb how do i tune in stations
Toshiba TV 2151TB Tuning
Press remote button adjacent to the picture brightness button.
The symbol of a clock appears.
Press the button again and the >>> symbol appears, this is for course tuning.
Touch the Increase Volume button and auto tuning starts.
When a station is found two green underlines appear.
Type the station number i.e.for 2 type 02, this stores the station.
Touch the Increase volume button again to find the nexr station.
Upto 39 stations can be stored.
Fine tuning of any station is achieved by pressing the tuning button until three blocks sysbol is displayed.
Use the Increase/Decrease Volume buttos to fine tune the station.
Feb 24, 2009 | Toshiba 19A26 19" TV
Tuning a Channel
why did it get the highest raiting?? it doesent even say a solution
Sep 23, 2007 | Philips 30PW633R 32" TV
Televison & Video Logo
142 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
