Question about Lexmark Optra E312L Laser Printer
Hi, my lexmark Optra E312 mono laser printer seems unable to feed the paper beyond the print cartridge. The page prints OK then bunches up insider the printer between the print cartridge and the fuser/output. Any suggestions? It seems to be a roller problem. There is no paper stuck in the printer. Thanks.
  • Lexmark
    Lexmark Sep 09, 2010
    Try to print with the fuser door open. If the paper prints out fine, then the issue is with the exit guide assembly. If it doesn't, then it has something to do with the fuser. Also, try to check the rollers if they do turn or rotate when paper feeds through. Don't hesitate to contact Lexmark technical support via their toll-free number for further assistance. Thanks.
SOURCE: Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Posted on Apr 13, 2007
SOURCE: paper cannot pass the Fuser/pressure rollers
The little rubber rollers can be taken off and turned inside out and I'll betcha that ****** starts worling.
Posted on Nov 17, 2008
crayzeetrayn
  • 837 Answers
SOURCE: Lexmark E321 Laser Printer
Check pages 76-80
Posted on Dec 07, 2008
SOURCE: PAPER JAM
The problem sounds like your rollers have lost their grip. Remove the paper tray and tip the printer up. Push the red lever on the left of the printer down and you will see the feed mechanism with two wheels. Remove the rubbers on the wheels and turn them inside out. Replace them on the wheels with the worn side now inside and the 'sticky" side out. You should get at least another couple of years worth of use before you need to replace them.
Posted on Mar 19, 2009
Geekman
  • 32281 Answers
SOURCE: FUSER TROUBLE HL 2040
This is a paper jamb problem. There is a piece of torn paper stuck in the paper path that is stopping the printed page from exiting properly.
Posted on Sep 30, 2009
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
The E312 is printing pages in all black. I've replaced the cartridge and cleaned it. What do I need to do to get it to stop printing all black/vey dark?
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Lexmark Optra E312L Laser Printer
Lexmark Opra M410 Laser
Your printer has a separation pad that is worn out and needs to be replaced. This pad prevents the printer from feeding multiple pages. It is located in the inside front of the paper tray Assembly.
Jan 06, 2009 | Lexmark Optra M410 Laser Printer
Catridge refiling
Smartest thing to do s to call Lexmark and purchase a new toner cartridge.
Lexmark does not allow for the use of refilled cartridges in any of their products. In fact, they will void printer warranties and not respond to any print quality question.
Laser printer cartridges have what is called a "Smart Chip." One of its purposes is to protect against the use of refilled toner cartridge.
Also, as an FYI, a toner cartridge that is refilled does not mean that any of the internal parts have been upgraded to "Equivalent to new" condition.
One final thought, it is illegal to hack around proprietary code. I believe it is an Intellectual Law issue.
Oct 21, 2008 | Lexmark Optra E312 Laser Printer
Lexmark printer CD-ROM
I have a Lexmark Optra E310 printer that works fine with the following Vista printer drivers:
Lexmark Optra E312 (MS)
Lexmark Optra E312 PS.
Aug 26, 2008 | Lexmark Optra E310 Laser Printer
Manual feed only
Pull out tray 1 & ensure the gray left-rear paper type clip is completely in the notched hole.
Aug 11, 2008 | Dell M5200n Laser Printer
Lexmark Optra 312L Black & White Laser Printer will not print properly
it's toast...
get another brand, and recycle that one responsibly.
May 21, 2008 | Lexmark Optra E312L Laser Printer
Lexmark Optra E312L Laser Printer Logo
1,298 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
