Question about Krups XP4030 Espresso Machine
Krups xp4050 leaks water and coffee grounds around the brew head. Have replaced the sea because that worked last time. It didn't fix it.
I've got the same problem. Did you get it sorted?
Posted on Sep 30, 2010
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Jan 28, 2016 | Krups XP2280 Combi Espresso & Coffee...
When I want to make coffee the water doesn't go to the revolver but down to the water reservoir. It just started few days ago before that the machine was doing great. How to fix it?
The problem with the XP4050 is the two safety valves that the water goes trough on its way to the coffee head. They are plastic and some of the parts will just become brittle because of the hot water and the contamination they gather. With my XP4050 they just broke and parts of it were in the rubber tubes that go to the waste tank.They are also very cheaply constructed compared to the more robust parts of this machine. The water to the hot water/steam head does not have these valves and has a completely different routing. I am currently trying to fix the machine with just one valve and parts of the two valves that are still good. Fingers crossed....
May 19, 2010 | Krups XP 4050 Espresso Machine
How do I fix a leak from the coffee holder unit
Does it leak around the pod holder, or after the holder is removed?
It it is around then you need to replace the head gasket.
If it is after then the solenoid or the valve seat is damaged.
May 01, 2010 | Breville ESP8XL Espresso Machine
No espresso coming out.
Apr 20, 2010 | Krups XP 4050 Espresso Machine
When doing espresso all water comes in the waste basket. Nothing in the cup. Steam function and hot water funcrion is working.
Apr 10, 2010 | Krups XP 4050 Espresso Machine
Water goes directly to drip tray instead of to the brewing head.
Have the same issue with mine. Descaled it all and wouldn't even brew with no coffee OR filter in the housing, so I took it in to get it checked out. Turns out it's the solenoid valve that needs replacing. ~$60 part plus $90 labor, so I've decided to try and find that part and DIY, if I can. I'll let you know how that turns out!
Aug 04, 2009 | Krups XP4030 Espresso Machine
The krups coffee machine is letting out hot water but not coffee ?
If you find water in the spend grounds drawer or with the cup grid out you see water being dispensed into the drip tray your brew unit needs repair or replacement. If none of that is happening the tube that brings hot water to the brew unit is clogged.
May 24, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Krups xp 4020 leaking
My Krups leaks like a sieve and I found parts (seals) available at  smallappliance.com
Sep 10, 2007 | Saeco Vienna SuperAutomatica Coffee...
Krups XP4030 Espresso Machine Logo
349 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
