Simple wiring diagram for omron mk2p-s relay - Heating & Cooling
Diagrams free wiring
If you are unfamiliar with basic electrical circuitry, it would be wise to have someone with electrical knowledge personally help you wire the relay. Relays are simple to wire but, if you do not understand the basic principles, you can do damage.
Aug 12, 2014 | Cars & Trucks
Relay diagram dash
relays are often used for many different applications, with same part number, the location of the relay determines its function
Sep 01, 2013 | 1996 GMC Sonoma
How to connect an omron h3y timer into a circuit
I see your comment to ignore:
To protect timer, read following:
1) Max load on this timer is 5 amp at 240volts
http://waterheatertimer.org/pdf/Omron-H3YN0302.pdf
2) If load exceeds 5 amps, then use timer to control contactor.
Here is crude drawing showing basic wiring for pin timer controlling heavy amp load.
http://waterheatertimer.org/images/10-pin-wiring2-1000.jpg
3) If amp rating on incoming wires exceeds 5 amp, for example is circuit breaker feeding circuit is 20-30 amps etc, then protect wires to timer using busman in-line fuseholder with fast-acting 5 amp cartridge fuse.
Dec 03, 2012 | Omron Healthcare Omron H3y-4 5 Second...
Wiring diagram for Omron off delay timer
Which Omron timer?
The model and wiring diagram appear on side of timer.
Add a comment with more details and I can track down the information.
http://waterheatertimer.org/How-to-wire-pin-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#Omron
Sep 07, 2012 | Amperite Dayton Solid State Timer On Delay...
I need a wiring diagram for an Omron H5CX-A timer
Wiring will appear on side of timer.
Test the timer with multimeter to see which terminals are connected. When timer has no power, then Com and NC terminals will have continuity.
H5CX-A Timer has 11 screw terminal connections and timer is rated 100V to 250Volt AC 50-60Hz.
Input is power IN > this is the 100V to 250Volts coming from breaker box or transformer. For example input terminals might be labeled A and B.
This will give power to timer, but remainder of screw terminals have no power.
To put power to relay terminals, jumper the power from Input terminal A to COM terminal.
For example Com terminals might be 7 and 9.
So jumper Hot wire from Terminal A to terminal 7.
This action will put hot on Com terminal 7, but also give power to the NC terminal.
For example the NC terminals might be 1 and 3.
So when timer is OFF, the NC terminal has power.
Then when timer turns ON, the NC terminal no longer has power, but the NO terminals are Hot.
NO terminals might be 4 and 6, and these terminals turn on-and-off when timer turns on--and-off
Open following link to help with Omron 11-pin wiring:
Jun 14, 2012 | Omron Hardware & Accessories
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
I need a wiring diagram for five TL8012-S1 safety interlock wired into a SR103AM monitoring relay or a certified safety PLC
OK go to the web sites below and download PDF documents, They explain it all. It is pretty simple really. www.sti.com/ltr2/access.php?file=pdf/2520.pdf
http://www.alliedelec.com/images/Products/Datasheets/BM/STI/328-0064.pdf
Feb 15, 2010 | Omron Sti / 44519-1430 Safety Interlock...
Farberware Convection Oven T490c does not turn on.
It is usually one of two items that could cause this problem. You need to take the outer shell off. Lots of screws. Pull the "brain board" from the right, front of the oven. There is a relay housing. This 30 amp. relay is made by Omron. Look at the connector pins on the back side of the relay, especially the white wire that goes to the distribution block then on to the heating coil. I find that the soldered pins on the pc board next to the relay often get so hot that they 'shed' the solder. If so, simply clean well and re-solder. The relay itself can also go bad. Unfortunately, I haven't been able to obtain replacements. What I did on one oven was to buy a 30 amp, open frame relay (~$20). Mount it on the chassis near the fan. Remove the Omron relay and simply run the appropriate wires to the open frame relay. That works very well.
Nov 28, 2008 | Farberware T490C 1500 Watts Toaster Oven...
Heating & Cooling Logo
634 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
