Question about Medion md40298 Notebook
I have a medion MD98300 laptop . Last night went to power up with both battery and mains connected seemed to want to start (mains light was on, battery light came on and then immediately went off motor whirred as though going to start but then died. Nothing at all. Any ideas please.
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Posted on Sep 19, 2010
  • salimal Nov 14, 2010
    Exactly the same problem with mine, last week. Identical. Have you tried any of the suggestions offered? Can you let me know? Cheers
No power,adaptor light on when i connected to laptop the light flash and off
see the flowchart attached, and proceed according and fix it.
God bless you
Nov 23, 2013 | Acer Aspire 3680 Laptop
Cant turn on wireless on medion md98300
try right clicking my computer then device manager see if you have a yellow question mark if its there you need to download its driver if its all good then try fn + the blue antenna on f 8
Jan 09, 2013 | Medion MD-40954 Notebook
My laptop was fine last night. i always use it on the charger but needed to take it off and use it. i did so and it ran out of battery so i put it on the charger but then it shut down. i just thought ill...
Remove the battery and mains adaptor. Press and hold the power button for a few seconds. Replace the battery and plug in the mains supply, press power for a few seconds and it should start up.
Aug 31, 2017 | Acer Gateway NV5814u Notebook
Dell Inspiron 1300
Not sure if this will help you or not. I had this same exact problem off and on with an Inspiron that my company issued me. I used to have to take the battery out, then plug in the power cord to the laptop, try turning it on, then putting the battery back in. Not sure at all why it gets stuck like that but that always seemed to work for me. It could very well be that your battery isn't seated properly as well. :) Good luck.
May 22, 2009 | Dell Inspiron 1300 Notebook
2003 windstar no power past the battery ?
I would check with vom voltage at battery terminals and at starter to ground. Is possible could be a fuse or fusable link but I think the positive goes straight to starter and power distribution fuse or fusable link
Dec 15, 2008 | 2003 Ford Windstar
My toshiba satellite p200-140 laptop will not start up. the power button lights up but nothing else happens. it was working fine last night
My laptop had a similar problem. I left my laptop running and some time later when I went back to my laptop, it would not startup. The power light seemed to be on but the laptop would not function. I tried several things like pressing on the power key for some time without any success and also tried all sorts of alternate buttons and sequences.
I resolved the problem by first disconnecting the power cord then by removing the battery for 5 minutes. I then re-installed the battery then connected the power adapter.
As soon as I turned the power button 'ON', the laptop booted up again.
Hope this works out for you.
Regards,
Rick
Sep 28, 2008 | Computers & Internet
Laptop compaq presario f500,running vista.Wireless is not working,Windows cannot load the drivers required for this device. (Code 31)
Matt Sydney Aug 4, 2008 00:28:44 GMT 10 pts
I experienced this problem last night, and seemed to have fixed it this morning.
SYMPTOMS: HP Pavilion dv9000, Win Vista x64 Ultimate. Running on battery, battery level became critical; windows went into 'Hibernate' mode. Upon plugging in to mains power, and resuming the Windows session, the Wireless is still disabled, no matter what position the switch is in.
POSSIBLE CAUSE: Critical battery switches off the wireless network card to preserve power. Motherboard seems to log this status but when re-connecting to mains power the card does not receive power again. Uninstalling the driver and getting Windows to re-install automatically upon re-boot does not work.
SOLUTION: Charge up the battery whilst the computer is running. You can charge it to a substantial level, say, above 25%. Disconnect mains power so that your laptop is running on battery only. Set your wireless switch to OFF (this is usually to the left position, away from the orange indicator). Now run your computer down to the critical battery level again (perhaps overnight). In the morning when you press the power button, the 'CHARGE' indicator (looks like a lightning bolt) on the front of the laptop should flash quickly, indicating that there is no charge in the battery. Remove the battery from the laptop's underside. Wait a couple of seconds, then press and hold the power button for 30 seconds. Keeping the battery off the laptop, reconnect mains power. Boot up your PC. When at the Windows desktop and all your startup programs have finished loading, switch your wireless on (to the right position). You should now have a blue light, and wireless should once again be working. You can now re-insert your battery. You might have to setup your wireless network connection again as mine seemed to be 'lost', but at least hopefully the main problem is now fixed.
Jamie Madriz Aug 8, 2008 01:58:15 GMT N/A: Question Author
Matt, i did what u said, and i'm happy because my wireless switch is WORKING! :) Hopefully it stays this way.
Sep 23, 2008 | Computers & Internet
Medion laptop
was it shut down correctly?
Apr 09, 2008 | Medion MD-40954 Notebook
Acer aspire 5610, wont start
U CAN TRY BY RESEATING THE BATTERY
AND TRY CHARGING IT BY CONNECTING THE SAME CORD..!!
Jan 01, 2008 | Computers & Internet
Medion Akoya EX Laptop computer
It sounds to me like some of the cells in the battery has collapsed.
A 12 volt light doesn't use as much juice on the battery as when you boot up. When Mobo, Monitor, Harddrive etc etc. start up they all use a large start-up-current and if the battery cant sustain the amount of amp. they all need together, nothing happens.
This is called shadow-charge, the battery seems fine, but when it really needs to put out some power it collapses.
I think you should try to sniff up another battery and see if this one has the same problem.
Or perhaps investigate wether or not you still have some warranty left on the battery, to try to get a free replacement.
Oct 11, 2007 | Medion (40010998)
Medion md40298 Notebook Logo
626 people viewed this question
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
