Question about Garmin GPS
My garmin nuvi 1390t has no sound how do i fix this
    President:
  • 1,514 Answers
1. Press the Volume (Speaker symbol) in the bottom right corner and check that the mute box is not ticked. If it is press it and it will be ok. Also check that the volume isn't fully down.
If that doesn't solve the problem it may be because the voice file is not selected or has become corrupted.
2. Press Tools, then press Settings (or Locale on some models), then press Language. You will see a bar for Voice. Press Voice and select a different voice. If this doesn't solve the problem it's most likely because the voice file has become corrupted. To replace the corrupted file.
3. Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and connect your satnav to your computer. Install webupdater and your satnav will look for updates. After it's finished it will give you an option to download voices. Click the ones you want and press next. The voices selected will be downloaded to your satnav.
When you have removed the satnav from the computer you'll need to select a voice again as described in para 2 above.
Posted on Sep 09, 2010
  • 587 Answers
SOURCE: My garmin Nuvi 1390t just started not showing
I would check your Avoidances in Navigation.... to do that go to Tools....Settings....Navigation..... Avoidances..... see what is checked to avoid and uncheck it
Posted on Oct 23, 2010
SOURCE: how do you view or use screenshot on garmin nuvi
If you want to see the screenshots, you have to connect the n
Posted on Oct 18, 2010
  • 587 Answers
SOURCE: the serial number at the
Do you still have the original box it came in? If so Garmin places a sticker on box with serial number see if its the same
Posted on Oct 30, 2010
  • 1082 Answers
SOURCE: Where can I get replacement screen for Garmin Nuvi
Search online for someone selling same model, ebay, craigs list, etc.. One that has issues not related to dead screen will be cheap, and you can get practice with dissaembly on the "bad" one before taking yours apart.
Posted on Dec 13, 2010
bbl242003
  • 1637 Answers
SOURCE: Hello ! i would Like To Know, How To Do A hard
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Posted on Jan 21, 2011
Accidentally deleted all files from my Garmin nuvi 1390T Car GPS
You might try restoring original settings and seeing if that helps.Here is a link for the manual. It instructs you how to do this on page 44.
Garmin Nuvi 1390 Manual
Feb 05, 2013 | Garmin nuvi 1390T Car GPS Receiver
Updating maps on garmin nuvi 1390t. Won't take 4g/sdhc card
You are correct. The 1390t works with microSD cards. While microSDHC cards will fit into the slot, they are electronically incompatible.
You need to use microSD cards 2GB and smaller.
Feb 18, 2012 | Garmin nuvi 1390T Car GPS Receiver
Garmin nuvi 1390t won't read or recognize microsd
The 1390t works with microSD cards. Your 8GB card is actually a microSDHC card. While it fits into the slot, it will not work in older devices.
You need to go with microSD cards, 2GB and smaller.
Feb 09, 2012 | Garmin nuvi 1390T Car GPS Receiver
My phone contact list shows one time and ten times dont show on my garmin 1390t.
Are you able to hook the unit up to the PC via USB, if you are able to get it into mass storage mode i would try giving the unit an update using Garmins WebUpdater Software. Often with new firmware updates issues like that are fixed, you may want to also try updating your phone aswell.
Hope this helps!
Apr 25, 2011 | Garmin nuvi 1390T Car GPS Receiver
Where can I get replacement screen for Garmin Nuvi 1390t. Mine cracked and Garmin is asking for $190 to replace
Dec 13, 2010 | Garmin nuvi 1390T Car GPS Receiver
My garmin Nuvi 1390t just started not showing roads other than main highways
Oct 23, 2010 | Garmin nuvi 1390T Car GPS Receiver
Got it for Xmas-just turned it on and it won't get a satellite signal...what gives ?
Hi.
Try resetting the Garmin Nuvi (access maintainance mode).
If that does not fix the problem, then the unit may be faulty. In that case contact Garmin at the number that you find on the owners manual to get the unit replaced.
Here how to reset the Garmin: How To Reset Garmin Nuvi GPS Device
Jan 05, 2010 | Garmin nuvi 1390T Car GPS Receiver
GPS Logo
1,402 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
