Question about Xerox WorkCentre 220 All-In-One Laser Printer
My workcertre pe 220 scanner locked . how can i scanner unlocked? also i can'nt use thr printer !
  • schongut Sep 09, 2010
    That I tryed first - pety no right solution . another Idea ?
    President:
  • 3,278 Answers
Hello.
Look for an Unlock Switch located on the bottom of the scanner module
Hope this helps.
Posted on Sep 09, 2010
    President:
  • 1,932 Answers
The scanner module is locked.Just plug out the power cord and plug it back.It will be unlocked.
Thank You
My workcentre PE 220 scanner locked . How can I scanner unlocked? Because there is no button in scanner???
Rick Kasper's solution is a good start. There is no mechanical lock for the scanner head (below the glass plate upon which the material to be copied may be placed).
The "scanner" in this context is the optical head that slides along a rail below the glass plate. Its movement from the home position is monitored by a photo transistor. If the scanner head fails to release from its park position under the left hand window as it should, including during the power-up sequence, the failure message will appear.
If you hear a fairly loud whining sound (from the stalled scanner head drive motor) during the power-up sequence followed by the "scanner locked" warning, it indicates that the scanner head is hung up mechanically in its park position below the left hand scanner glass. Verify this by opening the Automatic Document Feeder (ADF) before powering up and note lack of movement of the scanner head assembly. Following the sequence outlined in the service manual, remove the scanner + ADF assembly, open the scanner assembly and move the scanner head on its rail to free it up. Take care to reassemble the scanner head with the white nylon slides properly placed on either side of the head.
If however, during the power up sequence you do not hear the whining noise, it is a sure indication that the motor has either failed or that no drive power is applied, but this is rare compared to mechanical hang-up.
Sep 21, 2011 | Xerox WorkCentre 220 All-In-One Laser...
Dell a940 AIO makes noise as soon as i turn it on then displays unlock scanner - tried to but will not unlock
Found this: http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Hope it helps.
Oct 25, 2009 | Dell A940 All-In-One InkJet Printer
My workcentre pe220 printer's scanner is locked
my workcertre pe 220 scanner locked . how can i scanner unlocked?
Sep 03, 2009 | Xerox WorkCentre 220 All-In-One Laser...
I can not scan in xerox pe 220
I found the solution today. First you go to Autralia Fuji Xerox website at http://www.fujixeroxprinters.com.au then select Driver - Xerox WorkCentre PE220. Download the Control Centre and Scan to PC together with WHQL_PE220_2K_Vista_SCAN (scan Driver) and WHQL_PE220_2K_Vista_GDI.zip (GDI Driver). Setup files are in Control Centre and Scan to PC folder. The rest will pop up new hardware found and browse to two other files dor perfect driver.
Hope this help because it's help me today. Thanks to Miss Chin from Pineaple Computer Store One Utama Malaysia.
Nov 01, 2008 | Office Equipment & Supplies
My Vista 64 can't install Xerox PE 220
pls visit to this web http://fujixeroxprinters.com.au//en/support/Downloads.aspx?product=5460.
Everything in there. Just download and install. Hassle free
Jul 30, 2008 | Office Equipment & Supplies
Scanner locked. how to unlock
The scanner latch should be on the left side of the scanner.
You can try powering it off and on. Something is catching the scan head.
You should have a one year warranty on that product also if you need to call Xerox.
Feb 24, 2008 | Xerox WorkCentre 220 All-In-One Laser...
Scanner Locked
  1. Power OFF the printer using the power switch on the rear, right side of the printer.
  2. Wait 10 seconds, and then power ON
Dec 19, 2007 | Xerox WorkCentre 220 All-In-One Laser...
Dell A940 - Unlock Scanner then press power
See
Page 51 contains
holds it open.
page iv.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Xerox WorkCentre 220 All-In-One Laser Printer Logo
184 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
