Question about Dishwashers
It sounds like a hum, but continues to hum and doesn't take in any water
  • Dishwashers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 09, 2010
Started my washer forgetting that the water was turned off. made a beeping sound. started making a humming sound. turned the water on but humming continued. door won't open
Pull the mains plug and count to 10. Replace the plug and start again. This resets the computer board, and you will be able to open the door and start again. It happened to me once :>)
Aug 17, 2015 | Whirlpool Duet GHW9150P Front Load Washer
I have asked my question twice It has not been answered yet WHY?
Hard call without seeing the failure.
No hot water? Does the heating light come on? If so, then the element is gone. Not economical to replace it.
Humming sound? What frequency? Is it a pump that runs continuously? If a tube is broke, it might be repairable. A bad pressure sensor will not be.
If the sound is a 60 cycle low hum you may have an electrical failure and possibly a dangerous machine. A wiring problem has a small possibility of repair.
Apr 25, 2014 | Keurig Elite B40 Coffee Maker
Wtw6300SWO code dl hum and smell
http://www.appliancepartsquick.com/WhirlpoolCabrioWasherFaultCodes.html
This has all the tests that you need to run and has information on tech sheets that are included with that machine.
Feb 09, 2014 | Whirlpool Cabrio WTW6300SB
Doesn't spin
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.
Apr 29, 2012 | Kenmore Washing Machines
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Pump drain continues pumping when all water has been drained. Makes a loud humming sound
The humming sound might be in the motor unit due to short circuit
Jan 02, 2010 | LG Washing Machines
My dishwasher is making a humming sound and does not rinse?
A humming sound can be a failing wash motor (that drives the water pump) or it can be as simple as a blockage in the the pump area beneath the lower spray arm, under the filter.
Remove the spray arm and the filter top (screws will need to be removed)
Use a flashlight and inspect all over the sump area for debris that is blocking/jamming the impeller area. Reasemble and test with a short cycle.
If the dishwasher continues to make the same humming, it is time to replace the wash pump.
Good Luck! Post back here if you would like more guidance.
Dec 08, 2008 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwashers Logo
83 people viewed this question
Top Dishwashers Experts
