My usb flash drive doesn't read of my pc? can u help me about this matter...
  • 32,281 Answers
USB flash drives can become corrupted if they are not removed from the USB port correctly. Please click on this link and follow my instructions to repair the flash drive :-
http://www.fixya.com/support/r3598107-faulty_usb_flash_drives
Posted on Sep 09, 2010
What to do when your alienware m14x does not read USB flash drives?
good day have you been tried to plug the usb flash drive with other usb input of your pc or tried to plug with other pc just to ensure where the problem. if still doesn't read using with other pc that was mean your usb drive might have problem. if the case that your usb drive work with other pc the problem is with in usb jack which need to check weather loose wiring or software problem.
May 18, 2014 | Computers & Internet
What can I do
I have an Acer c720 chromebook and there is a message that says that my chrome os is missing or damaged... and that I will need a usb flash drive or a sd card. So I got an 8 gb usb cruzer blade flash drive stick then it says it doesn,t work with my chrome os and then goes back to the first page and doesn,t let me get on anything else. What can I do? Plz help
Jan 07, 2014 | Dell Dimension 2400 PC Desktop
I have a PNY usb 2.0 combo. The usb ports work fine and read external drives etc. The SD readers quit working. The SD cards read fine on the internal mounted reader. My PC recognizes the drives, and t
I bought a deer cam (trail camera) at Walmart and a PNY card with PNY Multi-Slot USB & Flash Card Reader P-UBSDRDR21K-RF. I can't make them all work for me. PNY card reader has no instructions on the package neither on their website and their support is a joke. When I plug in this multi-slot card reader into my PC (I tried two different PCs) something isn't right. I get no results, just empty folders. The card is new and has data on it. Both products come from PNY, both were purchased at Walmart and both are going back to Walmart for a full refund and I will never buy a PNY product ever again.
Feb 14, 2013 | PNY Memory Card Reader and USB Hub Combo
What connections are required to set hard drive function (Master, Slave, etc) in this case for use on a USB extender
Doesn't matter where the pins are if the drive is being connected via usb because it will act as a internal drive. If anything, just set the jumper to Master.
Nov 08, 2012 | Computers & Internet
The pc does not detect the usb drive, the usb flashes. But nothing comes up
Make sure it is inserted all the way into the usb port. If nothing comes up, this doesn't mean it isn't connected, it just means autoplay isn't on. Once it is plugged in, go to the start menu > computer. This will open a folder with all your drives, both internal and external. Double click on your flash drive's icon to open it.
Jul 03, 2011 | SanDisk 32GB Ultra Backup USB 2.0 Flash...
My usb stick needs to be formatted for pc but i cant
you can try format recovery software like asoftech data recovery. You can see
Recover formatted files
It tells the steps how to perform format recovery.
If above does not work, you may have to format the usb drive (use quick format), and then use above mentioned software to scan again the usb drive and recover your files.
Apr 04, 2010 | Computers & Internet
Flash drive not lighting up and not being read
Hello aaron_s_robe,
Sounds like the flash drive may be faulty. You may try plugging it into another USB port on your computer, if that doesnt help try plugging it into another computers USB port.
If after trying the above doesnt work. Your drive is most likely bad.
Sep 17, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PS2 Action Replay MAX: PS2 can't read saves off a USB flash drive
Here are some instructions I came across when trying to find out how a regular usb drive could be used with AR. I don't want to purchase the MAX Drive either.
Hope this helps, I haven't been able to test this yet for myself.
"you can use ANY size, brand, and style of USB flash drive (I'm using my mp3 usb drive) as long as
1. it's plug and play and
2. you follow these semi-simple steps to format your flash drive so that your ps2 will see it.
1 insert drive onto computer
2 click on start/settings/control panel
3 go to administrative tools
4 double click on computer management
5 click on storage/disk management(local)
6 find your flash drive (BE ABSOLUTELY CERTAIN THAT IT'S YOUR FLASH DRIVE)
7 right click on the area that says your flash drive's name AND has a blue stripe above it
*8 delete partition ((it will tell you that you'll lose all of your data stored on the drive)(hence why i said to make absolutely certain that the drive you're clicking on is in fact your usb flash drive)
9 right click on the now unallocated space where your drive was before
10 create new partition: in the popup it will give you some options; volume label, file system, allocation unit size, perform a quick format
11 volume label doesn't matter, file system has to be fat, allocation unit size has to be 16k, and you choose weather to quick format or not (I did just so you know)
12 after it's done just plug it into your ps2 usb port and away you go!!!!"
* - You may not have to delete the partition manually--I didn't. I just went right to the 'format' option when I right clicked on the area with the blue strip. All you really are trying to do is format your flash drive to FAT file system and allocation unit size of 16k. That's it!
I hope these instructions help someone out there. You DON'T have to buy the Action Replay flash drive in order to transfer files...your flash drive will work, but you have to be willing to reformat it to FAT (which WILL erase all of the files on it, so move them or back them up first BEFORE you click 'format')
Jul 23, 2009 | Video Game Consoles & Games
I have problem with reading my PQI 1GB Mini I-Stick i810 2.0 USB Flash Drive.Computer doesn?t read it at all. Can?t recognise a new drive. Please help
If you are using Windows XP, please check if you have install service pack 2 or later,
or check if proper driver is installed..
Mar 26, 2009 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
