Question about GPS
Hallo, My Rolls Royce Silver Shadow, 1973, shows this intermitant fault. When started, the warning lights " Partial Brake Failure" and "Master cylinder" stay on. The length of time varies from a few minutes to about 15 minutes. The lights then extinguise und stay out until the engine is switch off and then restarted after a pause of about an hour. Should the car be restarted within minutes, for example after refueling, there is no problem. I have noticed no difference in the braking system when the lights are on,nor is there any distinguisable hydraulic fluid loss. Any ideas? Thanks in advance Rod Parker PS. I have only had the car about 6 months and it is not used on a regular basis. History of services and other work done on the car are not available.
    Brigadier General:
  • 7,191 Answers
Kindly submit the question under Rolls Royce section on the website by clicking this link so that the top automobile experts can view and provide a solution to the problem.
Thanks for using FixYa.
Posted on Sep 09, 2010
Hi i have a rolls royce silver shadow 1 the side lights come on with the ignition can you tell me where the fault may be thanks
They may be set up that way, like driving lights, call a RR dealers service dept, they should be able to answer this over the phone.
Mar 09, 2015 | Rolls Royce Cars & Trucks
Rolls Royce Shadow 1 brakes fade and come back after parking for a while.
That's easy, tyou most likely need a new master cylinder, remember to use the coorect mineral based brake fluid with this brake system.
Jan 22, 2014 | Cars & Trucks
1986 rolls royce silver spur brakes do not work
When u push on the brake pedel does it go to the floor. If so u have a leak somewhere. If not possible master cylinder. It will use Dot 3 brake fluid.
Jun 14, 2012 | 1991 Rolls Royce Rolls Royce Silver Spur
How to remove wood dash from a 1975 rolls royc silver shadow
Sorry but never done one ,yes i have worked on this type of car but i have never done anything like this ,brake pipes yes and service work also welding ,they were not very hot on rust proofing around this time but the interior ,just take your time and follow your nose is the best advice i can give its only a car at the end of the day after so it cannot be that difficult or any more difficult than a jaguar or a wolsley 110 vandem plas
Dec 08, 2011 | 1991 Rolls Royce Rolls Royce Silver Spur
I have a 1977 Rolls Royce Silver Shadow with a brake oil leakage. How should it be repaired and what materials will be needed. Where could I get the service.
Where is the leak coming from. The wheel areas or under the hood where the master or pump are located. This is a very critical repair and you must use the proper brake fluid. This system can not use DOT 3 OR 4. It will contaminate the system and destroy every seal. Let me know the integrity of the system and what it is you would like to repair.
Oct 29, 2010 | 1991 Rolls Royce Rolls Royce Silver Spur
Where is the switch for the brake light in Rolls Royce Silver Spirit 1986
hello there
the switch should be located on the brake pedal arm there should be a pin and or a clip to hold it on the arm you should also have a plug on the switch...hope this helps thanks
May 30, 2010 | 2007 Rolls Royce Rolls Royce Silver Spirit
Car does not start/crank
your gear switch/ inhibitor switch may be faulty. and the system is preventing you from moving it to prevent you from starting the car in any gear other than park or neutral
Apr 26, 2010 | 2000 Rolls Royce Silver Seraph
GPS Logo
71 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
