Question about LG 22" FLATRON LCD Monitor
Lg w2234s doesn't start up power light is on all the time can't swich the monitor off without unpluging it tried different pc unit, cables, no joy!!! Looks like I can't open it up. There's no screws please help stefan
leroyal
  • 2120 Answers
SOURCE: LG Flatron W2234S monitor seems to be in sleep mode.
the backlight fluorescent bulb is burned out
Posted on Dec 26, 2008
SOURCE: No picture lg flatron w2234s blinking blue light
Hi My screen developed exactly the same problem. It appears to be a hardwear problem associated with the screen it's self. continuity test is ok on the lead so I took it back to the shop under warranty and hey presto, the replacement works. I don't know what the problem is but there are a number of other folks on another thread with the same problem and their entries are dated May 09 too.  Dave
Posted on May 29, 2009
SOURCE: LG Flatron - Power button flashing blue
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Posted on Jun 03, 2009
  • 47 Answers
SOURCE: Power Button on (BLUElight)and goes off again. No
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's most likely the problem.
You can confirm that it's actually the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors2.gif that are replaceable. The board can run anywhere from $50 on up. Depending on how old your monitor is, and how much you've invested into it, you may find it better to just replace it with a gently used one from ebay.
Posted on Oct 24, 2009
SOURCE: LG Flatron W2234S Monitor Monitor goes black
Ahh the same thing has happened to my monitor! Mine unfortunately is 1 month over warranty. Apparently this is a common problem with this model!
Posted on Nov 02, 2009
Testimonial: "Excellent advise and many thanks. But it seems that this model does suffer some problems with this fault and LG knows it."
Why does not power up my LG 22MP65HQ after 4th use?
An internal fuse may have opened or the power supply may have failed abruptly.
Nov 05, 2017 | LG Computers & Internet
Lg w2234s-bn Monitor Cycling randomly through Light View Modes/Power Button turning It's self on and off.
On and off cycleing could be caused by a bad power supply or a low battery on your remote. Check them both out. Good luck.
Apr 28, 2012 | LG 22" FLATRON LCD Monitor
Lg w2234s keeps turning itself off, all cables ok so is video card, any ideas
try pressing on source key, the monitor has two input sources one digital and one analog maybe it's on the wrong input (digital connected while monitor on analog or vice-versa)
Oct 14, 2011 | LG W2234S 22" LCD Monitor
How do I get my LG W2234S out of power saving mode?
The mcu on your main PCB ( vga input) has most likey become corrupted. A replacement card would solve the problem.
the service manul has a step by step guide to fault finding
http://elektrotanya.com/lg_w2234s-sni-bni-axx-qp_sm.pdf/download.html.
Manufacturer Part Number:
EBU59489401
Board Numbers: 791501300700R
assuming tried different cables and pc's already
Nov 16, 2010 | LG Flatron W2243SPF Widescreen LCD Monitor
Hello, I have a LG flatron w2234s and a week ago the screen started to shut down on its own while i'm using the computer or when it goes to sleep mode. The screen gives me the LG sign and just turns off...
First try it on another Pc, you'll know the root of the problem. If there's no problem on another pc then the problem would be with your video card/motherboard. If the problem is still the same on another Pc, then your monitor has internal problem. You better call up a technician, he/she will check it for you, must be Pcb problem. Good luck. Thanks for using FixYa.
Jun 04, 2010 | Computers & Internet
Power swich blinging ,does not power on
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
May 04, 2009 | HP f2105 21" LCD Monitor
Monitor restarting randomly
Rarely does a monitor go out due to drivers. Try another monitor and verify that it isn't the computer (it isn't). If the power light goes out it is the power supply (usually inside) the monitor. If the light stays on, it will most likely be the backlight power unit. Browse the internet for the model and parts. Newer units are difficult to find.
Apr 29, 2009 | Computers & Internet
Apr 20, 2009 | Computers & Internet
LG W2234S screen just went black
If you plugged power cable, and Power button on monitor is not working, something's wrong with the eletronics. Go for a refund.
Jan 15, 2009 | LG L1932TQ LCD Monitor
LG 22" FLATRON LCD Monitor Logo
178 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
