Question about Goodman Heating & Cooling
Unitkeeps freezing up unit runs outside but no air blowing inside
    Master:
    Sergeant:
  • 449 Answers
Have it serviced and check your filter
Posted on Sep 10, 2010
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
Hi, After finding out that Freon is low by seeing snow/icy surface on outside compressor, I went up in the attic to find snowy/Icy surface all over the coil inside the air handler. I wahsed it and made...
Hello
Your still froze up.There is a freeze cutoff device in the air handler upstairs.
Look for a thin silver color tube near the coil and follow it to the control box,there may be a reset button.If not, try using a hair dryer to warm up the coil and it should reset itsself.
These freeze devices can take an hour to reset on there own sometimes,do not run the compressor while doing this.
Aug 30, 2010 | Ruud Heating & Cooling
I have a heat pump and it freeze up
If you are referring to the outside unit freezing up, the issue is in the defrost cycle. The defrost cycle works something like this: The unit reverses the flow of freon causing the inside coil to blow cold air into the conditioned space and the outside coil is now working like an a/c unit, it gets warm to melt the frost/ice. The inside unit electric heat strips come on so you do not notice the cold air being blown in. The fan on the outside unit stops running to allow the coil to get good and warm.
Now the unit should go into the defrost cycle every 90 minutes or so. It should not terminate the cycle untill the coil is clear of frost. There is an "Klixon" type termostat that measures the temperature of the outside coil. This is most likely the problem. It is prematurely terminating the defrost cycle. I'd start there first.
Hope this helps, Let me know if I can be of any further help.
Dec 29, 2009 | Intertherm P3RC-030K Air Conditioner
10,200 BTU a/c blows air but not cool air
They can freeze up if the outside air is too cool. It needs to be over 65 degrees outside and inside. Another possibility is if the unit is a little low on refrigerant. They will run too cold if slightly under charged or if the condensor is very dirty and the heat can not be exhuasted.
Aug 27, 2009 | Heating & Cooling
Central air unit problem.......It starts out blowing cold then will only blow room temp air after some time. I don't see anything freezing up..Filter is clear. The unit outside is not clogged up. The...
Check your outside unit to see if fan is running. If it is running check to see if air is blowing out if not you have a bad capacitor. Some times if a capacitor shorts out the fan will run backwards and the line will get very hot same as if the fan is not running. Russ
Jul 20, 2009 | Heating & Cooling
No air blowing inside the house thru vents;starts fine than stops
You are likely low on charge and the unit is freezing up. You need some with gauges to check. You should not try to run this unit until then or it will burn out the compressor.
Jul 18, 2009 | Ruud Central System Air Conditioner
The outside unit runs but the inside doesn't blow
COUL BE A FAULTY BLOWER RELAY BOARD OR THE MOTOR COULD BE GETTING HOT AND SHUTTING OFF ON OVERLOAD. CALL A CONTRACTOR
Jun 16, 2009 | Goodman CLJ36AR42 Air Conditioner
Air condition unit will not cool and the coils freeze up in just a few min.
Is the inside fan running properly? Typically if the condensor outside is working, but the fan inside is not, the coils will freeze up quickly. For the system to work properly, you need to be blowing warmer air over the coils inside the house- that then brings the temp of the refrigerant in the coils back up, and the loop continues. If the fan inside is not working, check to make sure that the circuit breaker is not tripped.
Jul 06, 2008 | Intertherm Heating & Cooling
Non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Oct 27, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
