Question about Bugaboo Cameleon Jogger
The round white buttons which are used to lay the seat back and forth are broken. one is stuck and the other has snaped.
    Guru:
  • 541 Answers
My driver seat is stuck in recline. How do i fix it?
The seat frame is most likely broken, you will need to have it taken apart and replaced or welded.
Jan 13, 2017 | 2002 Dodge Grand Caravan
Tip
HOW TO FIX BUGABOO WHITE SEAT BUTTONS
To fix it yourself, you need to disassemble the buttons, which can be done with two screwdrivers one a thin slot type the other a Phillips. Here is the process: 1. On the other side of the white button unit is a screw. Remove it using a Phillips screwdriver.
2. You'll now have a black housing with a white button held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs with the slot type screwdriver.
4. You'll now have a black base, a spring and a white button. Pay attention to how the two black parts align to each other so you re-assemble it correctly.
macnutz_28.jpg.
5. Pop the white button out of the upper black surround. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. A little silicon spray is a good idea.macnutz_27.jpg
6. Reassemble unit and check it has full movement (see photo below). macnutz_30.jpg
7.
On the underside of the button unit a ramp shape should lineup with an opening in the bottom edge.macnutz_33.jpg
8. Fit button unit back into upper seat leg, Fit lower seat leg aligning it to the back of the button unit so the push rod in the lower seat leg pushes on to the ramp on the button unit. Note the seat button will not come out and lock until the seat is fitted back on to the chassis pushing the rod up to push the button out to the lock position. Once you have fitted the back screw in you can use a large screw driver to push down the inside of the lower leg to check the white button pops out and locks. If you have any resistance dismantle again to check alignment and the condition of the interlocking teeth of the button and the outer rings. Sand of any burrs and use a little silicon grease. Reassemble and test again.
Repeat operation to the other side if necessary. Buttons are not interchangeable so doing one side at a time avoids mixing them up.
If the tabs on the white button are broken you can buy a new button unit as a part www.babycare.nl/bugaboo-cameleon-seat-frame-push-buttons-p-2664.html
on Jan 14, 2011 | Bugaboo Cameleon Jogger
How do I remove expansive cap holding screw so I can replace broken toilet seat?
Porcher 70018 Bathroom Toilet Seat Round Front ... - Fixya
www.fixya.com/support/...porcher_70018_bathroom_toilet_seat.../popul...
Popular Porcher 70018 Bathroom Toilet Seat Round Front White questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair tips ...
Aug 25, 2015 | Porcher 70018 Bathroom Toilet Seat Round...
My bugaboo bee won't recline, the mechanism seems stuck, when I push the release to lie it back the mechanism gets stuck in the up position and nothing happens. The two white buttons on the side
Hi, When the stroller is open, make sure that both of the green indicators either side of the frame are visible. If not, put your foot on the brake and pull the handle firmly with both hands until the green appears. This will enable you to get access to the seat. If the seat doesn't move still, check at the bottom (where the small of babies back is) to see if the excess seat fabric has become stuck inside. This is usually the main reason for the seat recline not functioning. Hope this helps.
Feb 07, 2013 | Bugaboo Bee Stroller
Seat problem on my speedfight 3
ive just had this problem and when i checked the cable has snaped, you can use long nose pliars or fit the cable all together but short term long nose pliars from the left back pannel of the bike. hope this helps
Nov 14, 2011 | 2010 Peugeot Speedfight 3
Driver seat is stuck all the way back.
Sounds like you have something stuck in the seat track look under the seat with a flash light to see if any thing binding the seat from moveing or if something looks broken and is stuck in the track spray with WD40 that will also help then work it back and forth until it starts moveing freely
Dec 04, 2010 | 2004 GMC Envoy
The back of my seat is stuck..it doesnt go back neither forth, but i can hear the motor running. other adjustments are working normal but only the back is stuck..thanks for help
the cable must of snaped that controls the back, or a gear, youll have to remove the seat put it no a work table then you may have to remove the seat covering to the back a little so that you can see the linkages, now power up the motor that operates the back and watch what isnt moving, then youll see your problem, good luck hope this helps
Nov 26, 2009 | 2008 BMW 3 Series
Drivers seat is tilting back and forth, a bar underneth is broken
it can be a spring that came loose from its spot under the seat look to where it should be or the seat could be back to far and it depends on how old it is if it has just broke down make sure nothing it in the way and the lever id not stuck hope this was helpful:)
Nov 16, 2009 | Odyssey Steel 2 Ball Srt Putter
Icemaker is on cube but is still crushing ice it seems like it is stuck on crush,the light is on cube.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Nov 13, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Hi, my bugaboo is now 16 months old and recently the round white buttons on the side that lock the seat into three different positions got stuck instide, so the seat is not locked in any position, which...
call bugaboo customer service (1-800-460-2922), give them your stroller's serial number, and they will mail you the replacement kit (the new round buttons) and instructions for free and very quickly - I had the same problem and was very satisfied with how it was resolved.
Apr 05, 2009 | Bugaboo Cameleon Jogger
Bugaboo Cameleon Jogger Logo
533 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
