Question about Bosch Axxis WFL 2060 Front Load Washer
Drum will not turn will drain but not spin - Bosch Axxis WFL 2060 Front Load Washer
Its possible the brushes on the motor may be worn down. You can replace them your self. Mine started becoming intermittant, then finally would not turn at all. It would fill and drain fine. Service dude said that the whole motor needed to be replaced as you could not get just the brushes. he was wrong.
http://www.appliancepartspros.com/part_details.aspx?part_id=2822714
Posted on Sep 15, 2010
My whirlpool commercial washer is not draining properly. The close is extremely wet but there no excess water in the drum. what could cause this issue?
Sounds like the water drained but the drum did not spin. Select spin and see if the drum actualy turns. If you hear a motor running then it could be just the drive.
Oct 03, 2014 | Washing Machines
Trying to diagnose a problem and have back panel off. Belt was off AND I think the cause is that the drum pulley and inner drum will not spin without a lot of pressure. I figure the motor (which appea
Either something is caught between inner & outer bowl or drum bearings need replacing. Also check outlet hose going to pump sometimes object caught there causing the bowl to be tight to turn.
Dec 11, 2013 | Maytag MAH2400A Compact Front Load Washer
Motor sounds like it is turning the drum but drum is not turning
Check your timer. Jiggle the selector knob,then move it to a position just prior to the spin cycle, see if this helps.
Oct 27, 2012 | Bosch Washing Machines
When time to drain pump drains water then just hums and it wont spin, get error code f01. when i turn dial to drain and spin pump just hums drum might turn a little but it never spins. i have emptied...
f01 is main controller (board) failure.
Replacing it is the only solution.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Drain pump keeps running
Probable motor control board problem.
don't buy a GE anything!
May 03, 2010 | GE WBVH6240F Front Load Washer
Machine will not final spin
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
Feb 15, 2010 | Hotpoint Washing Machines
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Drum will not turn
check the belt if its not that the the brushes need replaced in the motor that will fix the spin problem
Mar 03, 2008 | Indesit W 123 Front Load Washer
Wont spin or drain
The drain pump is jammed or clogged up. Remove the filter cover and check for bobby pins, coins or bra wires. If clean, remove drum to pump hose from the pump and check for any foreign matter. Try to turn the pump impeller by hand. It should turn freely. If pump is not free, replace it.
Nov 03, 2007 | Maytag Neptune MAH5500B Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
81 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
