Question about Sharp AQUOS LC-32D44U 32 in. LCD TV
Why is my sharp tv saying database empty - Sharp AQUOS LC-32D44U 32 in. LCD TV
How do I fix my Orion 19inch LCD TV we can't get anything on it except it saying database empty
Check and replace its main system control memory IC. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 20, 2016 | Orion Televison & Video
How do I access DTV channels? It always indicates 'Database Empty'
When you set up the tuner select analog + DTV and then do a channel search.
Jul 10, 2014 | Sharp LC32D44EBK 32 in. LCD TV
How do I remove the message status database empty
hi, you need to do an autotune with aerial connected so that the tv has all channels tuned in, then the message will disappear.
May 11, 2014 | Sharp Televison & Video
What does "freeview database empty"
My tv has been working fine and all of a sudden it wont find any channels on channel search and says "database empty" can anyone help??
Mar 08, 2011 | Televison & Video
Problem, unable to access any digital channels. TV displays error message Database Empty, any way of removing this message and accessing DTV again. Thanks
If the database is empty you need to re load the system.
With your remote controller, go to menu and from that you need to select install or setup.
This will scan for all available channels and store them for use.
Hope that helps.
Nov 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
No picture just message saying database empty
Hello there. We are probably going to have to go back and forth with comments in order to get this problem resolved. I do not have enough information to go by from your problem's description. The way it is listed you have a Sharp high definition television and all that will display on the screen is database empty. I can explain how to reset the television both a basic reset and a factory menu reset. However the procedure is different depending on the model number.
I do not know if this is a television problem or signal source problem. If you have cable or satellite tv and use a cable or satellite box this message could be coming from it. I can assist you with resetting the cable/satellite box and even bypassing it (if it is a cable box).
I can also assist you with connecting the cable box/satellite receiver to the television in a different way.
The first thing I would like for you to try is to turn off the cable or satellite box and unplug it for 2 whole minutes. Then plug it back in and wait for it to reboot. If this doesn't solve the problem we can go on to the next step. I'll be standing by waiting for a comment.
Nov 18, 2010 | Sharp Televison & Video
Database empty?
Set top box VSTBAW09
Error code: data base empty??
Aug 31, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Freeview channels (DTV) on a Sharp Aquos TV
On my Aquos it's saying no carrier and database empty what do I do, I have trying to reset TV but free view isn't coming on and it's saying carrier 0.
can anyone help
Nov 22, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC32GD8E displays Database empty. This occured after several weeks of TV not displaying picture until thumped. What is the problem and how is it resolved?
It may not be solved but I went to DTV menu and re-installed the channels and it is fine now. Don't know if it will happen again but it is fixed for now!
Apr 20, 2008 | Televison & Video
Sharp AQUOS LC-32D44U 32 in. LCD TV Logo
264 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
