Question about Lexmark C532dn Laser Printer
I have Lexmark C532dn printer which continues to reports "Insert Tray 1". Until now it was enough to little press tray 1 to start print. But now it beeps all the time and little pressing is not enough. Can't figure out where is that microswitch or contact which is pressed by tray so that printer can register that tray1 is inside. Can be that fixed by me or should I send to service. I prefer first option rather than second because it takes too long for repair.
  • Lexmark
    Lexmark Sep 09, 2010
    Try to remove the paper tray from the printer, then reinstall after 30 seconds. You can also try a different tray from a similar printer, if you have one, to determine a possible tray issue. If problem continues, it's more likely a paper pick assembly issue (which includes the sensor). This would require a service call.
  • 45 Answers
I have Lexmark C532dn printer which continues to - 8db5o70lihgzmaaaaasuvork5cyiiaYou have problem in this sensor. Clean
Posted on Jul 03, 2017
SOURCE: Lexmark E232 - Tray-1 Paper Problem
Have the same problem after 1,500 pages! This was Lexmark's solution (and it worked)...
Take the paperfeed tray out and you will see a red lever , press it
downwards and you will see the paperfeed rollers coming down , you need to
pull the rubber tyres off those rollers and place them inside out over
them and then try printing any document. Check the paper weight and
the paper type you need to use 20 pounds regular paper and try runnning a
can of compressed air inside the machine.
If rubber tyres on the paper feed rollers are totally worned out you
need to replace the feed rollers.
Posted on Nov 21, 2007
Just take ruber band out and flip it. And put it back, It works. Main reason is rubber is dried. Frugalguy's suggestion worked for me. Thanks.
Posted on Oct 06, 2008
SOURCE: Somebody has messed with the settings and now whenever we print we have to press "Select" for each page
The tray 1 is same as manual tray, it opens in front of you.
normally (in windows) you need to configure printer driver from printers => properties => printing preferences.
Posted on Oct 14, 2008
  • 461 Answers
SOURCE: Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Posted on Dec 31, 2008
  • 85 Answers
SOURCE: Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Posted on Feb 15, 2009
The printer recognizes tray 2 but it will not print to tray 2.
The printer will not print from any tray if tray one is pulled out. the paper path from any other tray still goes through tray 1\'s feed path (little slit in the front of the tray). if tray one is not in the printer it will not pull from any other lower tray.
Jun 03, 2014 | Lexmark T630 Laser Printer
Lexmark T632 has 2 (ea) 500 sheet drawers, but once the paper runs out in Drawer 1 it will not automatically pull from Drawer 2. Please advise how to fix this problem.
go to Menu, reports, and print out the top report.
This will show you what the printer sees as the default tray, and what paper size and type are set for each tray.
If you have plain paper in each tray, make sure that the setting page also shows that each tray is set to letter, plain.
This printer sets the tray type automatically, based on the way the tray is set. There are little tabs on the side of the tray that change as you change the size of the paper with the paper guides.
If the paper guide is set even one click off, this can cause the printer to read the paper size incorrectly, and thus will not change to the next tray. ( if it thinks that tray 2 is A4 paper, but you are printing letter, it will not change to tray 2).
if the trays ARE set correctly, but the printer is still reading it wrong, then there could be something wrong with the sensor ( metal fingers and switch ) inside the printer.
Feb 15, 2011 | Lexmark T632 Laser Printer
Prints one or to pages then stops. Have to reset computer to get it to work. No test doesn't work. It is like it runs out of memory.
Try to run a test for continuous print test page in diagnostics mode. To enter the Diagnostics mode:
1. Turn off the printer.
2. Open the front access door.
3. Turn on the printer while pressing and holding Cancel .
4. Close the front access door once the Error light displays. Print the menu page by pressing and holding Continue until all of the lights flash. Follow the instructions on
the menu page to access the menu items.
Continuously print pages containing cross lines, printer information, and margin settings. Press and hold until the Continue button lights flash to begin. Press Cancel to stop.
Make sure he selects the "Cont Prt Simplex Tray 1" option
If problem persists, contact Lexmark at 1-800-LEXMARK()1-800-539-6275.
Apr 21, 2010 | Lexmark E260dn Laser Printer
I am currently using a windows 7 computer and experiencing problems with the hp laserjet 2840 all in one printer. Any time i try to print, the printer will attempt to print further then normal margins and...
Press MENU.
Press the left or right arrows and select REPORTS.
ENTER
PRESS < or > and select CONFIG REPORTS. ENTER
Now what does the output look like? If it is bad...try the same thing but pull out tray 2 about an inch and put paper in tray 1. If both of these tests come out good, you probably have a problem with the printer drivers. Download them from hp.com.
Apr 09, 2010 | HP LaserJet 2840 All-In-One Printer
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How do I stop daily reports from printing? How do I change the default tray for fax reports?
To program a default paper tray to print fax reports, perform the following:
1. Select Utility/Counter.
2. Select User Setting.
3. Select System Setting
4. Select Paper Tray Setting.
5. Select Print Lists
6. Select the paper tray for the fax reports to print from.
7. Press OK.
8. Press Exit on the lower left side of the display to return to the copier screen.
to set the activity report to not print daily
1 touch the utility button
2 touch administrator settings and enter the password 12345678
3 press fax setting
4 press report settings
5 select activity report and change to off
6 press close then exit
Mar 17, 2009 | Konica Minolta bizhub C250 All-In-One...
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
Lexmark T632 top tray is ejected when empty
Set tray 2 to be default tray. When this is empty, the printer moves to tray 3, and then on to tray 1.
Nov 21, 2008 | Lexmark T632 Laser Printer
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Nov 12, 2008 | Dell 3100cn Laser Printer
Paper source
I would suggest checking printer properties in the computer and ensure the paper size and source is Letter and set to Automatic Choose. Another choice may be to deleted the printer driver and re-install it. You can also go into the menu options until you get to Set factory defaults, press Select, then try the print job again.
I really suspect a program is controlling this from the computer.
To get a list of the existing printer settings, Select Menu and use the Right Arrow button until you get to Printer Menu Settings. The printed report should tell you what your actuall settings are. Maybe the default is set to Custom, instead of Letter.
The Set Factory Defaults option should fix most problems.
Good Luck John Moser
Jul 01, 2008 | Lexmark Optra S 1625 Laser Printer
Lexmark C532dn Laser Printer Logo
109 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
