Question about AOC LM729 17" LCD Monitor
Backlight inverter aoc lm729 Schematic diagram Please I am a repair technician (Retired) Lcd layer working picture on screen backlight goes off intermittently and now for almost all of time. Flashes on for initial few seconds
  • 11,361 Answers
Here is the service manual: http://elektrotanya.com/?q=showresult&megnev=AOC%20&megnev2=LM729%20&kategoria=&kat2=all
You will need test lamp to verify if it is the inverter or the lamp assemblies.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 09, 2010
    Renaissance:
    An user who is expert in 3 categories / brands.
  • AOC Master
  • 848 Answers
Backlight inverter aoc lm729 Schematic diagram Please I am a repair technician (Retired) Lcd layer working picture on screen backlight goes off intermittently and now for almost all of time? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
715L1103 AOC IDPC7425A3 Power Supply for TFT1780PSA LM729
Posted on Dec 23, 2014
I plug in the powercord and the monitor of my
It sounds like the backlight inverter board has gone out, or the cable connector came loose fromt the inverter board, see example of laptop inverter board replacement guide: www.insidemylaptop.com
Mar 26, 2010 | AOC LM729 17" LCD Monitor
AOC 2036 LCD
You can get the drivers from www.driversguide.com
Dec 05, 2009 | AOC LM729 17" LCD Monitor
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Jul 10, 2008 | AOC LM729 17" LCD Monitor
Inverter board
just change the 4 bloated caps on the board (2)100mfd 16v and (2) 470mfd 16v
Mar 19, 2008 | AOC LM729 17" LCD Monitor
Problem with the risolution
To my understanding, an AOC LM729 is capable of 1280 x 1024 and therefore should be able to display your preferred 1024x768 .
Perhaps you need to set the PC's Display Screen Refresh Rate to 75 Hz or lower (DisplayProperties/Settings/Advanced/Monitor).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 14, 2008 | AOC LM729 17" LCD Monitor
the inverter needs to be replaced
not real hard, but must have some knowledge of the process
Feb 02, 2008 | AOC LM729 17" LCD Monitor
AOC LM729 17" LCD Monitor - Manuel
I assume you only found the 4 mount screws in the back... You also need to take off the front silver edging - it pops off with some negotiating, but if you find the right spots and don't pry hard it will come off clean without too much difficulty. Then take out the screws that hold the screen inside and it should drop out.
Jan 26, 2008 | AOC LM729 17" LCD Monitor
Monitor problem
You are experiencing an inverter board failure. You will need to replace or repair the inverter. The inverter drives the CCFL lamps that illuminate the screen if the lamps draw to much current or components on the board are overheating it will shut down the backlights. Some monitors have cold solder joints on the toroidal coils of the inverter that causes this problem, very typical with HP monitors, If you are handy with a solder iron you may try just re-soldering board and replacing push-pull transistors for a few more years of use. Provide make and model and I can be more specific about probable cause and solution.
Jan 18, 2008 | AOC LM729 17" LCD Monitor
Where are the ring inductance coils on the power supply board?
Aug 15, 2007 | AOC LM729 17" LCD Monitor
AOC LM729 17" LCD Monitor Logo
1,281 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
