My zanussi FJS1025W washing machine is showing the error code E20 and it wont let me spin or drain the water away. I have cleaned all the filter but still it wont do anything other than take in the water then half way thro the wash it does the E20 again!! it is also making a weird noise whilst it is trying to pump out the water
    President:
  • Washing Mach... Master
  • 1,932 Answers
E20 is a draining error.
Check the filter.You need to take the filter out, empty it of all lint and replace it. It may have water trapped in already, so get a cloth ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out.
If still the problem persists then the problem is with the draining pump.The pump is not pumping out the water.Check the pump impeller it may got stuck due to some obstacles.Replace it and this wont come again.
Thank You
Posted on Sep 09, 2010
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi washer dryer showing e20 error message in dryig cycle
Hi
This means that the filter is clogged. Unscrew the filter it'll be full of lint. E20 also means drain problem. If it actually goes through the Spin cycle then there is most likely some water still not drained out at the time of the tumble dry. Check the drain and the hose to make sure it isn't clogged.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 03, 2011 | Zanussi Washing Machines
I have an E20 error code flashing up on my zanussi jet system washing machine
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 05, 2010 | Washing Machines
Door on washing machine is locked with e20 code
This particular code is used when the machine detects a pump problem or water draining problem. In this case, the fault would occurr just before attempting to spin. It turned out to be a blocked filter, accessible from the bottom front of the machine. so the best thing to do is clean the filter on the front of the machine open the flap and undo the filter water will come out so be ready for that. after it is cleaned and filter all back in and secure switch machine back on at plug and run cycle this should fix it. hope this helps.
Here are some error codes for future problems. E10 - not filling
E20 - not draining
E40 - door open
EFO - Filter blocked
Sep 19, 2010 | Zanussi ZWD1270 Front Load Washer / Dryer
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Oct 18, 2009 | Washing Machines
Error code on washing machine!
Sep 09, 2009 | Washing Machines
Zanussi
E20 = Problems with water drain in wash phase ALARM CODES E20 Is the drain filter clean; Problems during draining phase (Machine tries to drain for 10 min without emptying the tub) Checks to do: E20 Is the drain pump working? Is the value of the pump about 200Ω? (Measure directly the connector by the board, between J2-2 and J2-7) ; If No Change the pump and run again Clean the filter; Is the draining system OK (drain hose and plumbing where machine is connected) Free and check the draining system; Is the pump blocked? Is there any burn mark on the control board; if yes Change the board E90 = Communication error between user interface and main board. Verify the connector between the main board and user interface board by plugging and unplugging the connector few times on both sides, OR replace the blue ribbon cable. The fault could have been caused by oxidized contacts in user interface plugged in the main board. Kind Regards David Marsh
Jun 19, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
251 people viewed this question
Top Washing Machines Experts
