Question about Samsung R610-64G Laptop
My laptop is samsung R428 . one week back i brought this laptop.i m havinga little problem .afterd battery get charged to 79% its showing me "not charging"....please tell me solution
  • sanju1975
    sanju1975 Jan 06, 2012
    my laptop R428 dvd not working plz solution
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 19, 2010
Hi , I bought a rosewill bk-500a ,now it will not keep a charge. It is only about two weeks old. Any ideas ?
Even though it's new the battery may be shot. I bought something and it said battery good for three years and it lasted for a week. Either take it back or replace the battery yourself if you want to try. But my advise is take it back if its new.
Dec 31, 2015 | Samsung Radio Communications
Samsung R428 notebook wont switch on
This problem, from your description, is very unlikely to be because of a change in your settings, if nothing happens when you try to turn your computer on.
If no power is being supplied to your computer - no lights come on - then
you might just have the combination of a flat battery and a faulty power adapter. You must test the power adapter (measure the output voltage with a voltmeter) or obtain another one (preferably temporarily/borrow) to see if your computer will turn on with that. If your power adapter has failed it must be replaced. If still in warranty, Samsung or your retailer/dealer should replace it at no cost. (you should not attempt to repair a power adapter)
Otherwise (or even as a first step) I suggest you contact Samsung support by email or Live Chat (details are on this
http://www.samsung.com/in/support/model/NP-R428-DA01IN
webpage.) Please have your computer's model number, serial number, operating system and other details to hand (the numbers
can be often be found on labels on the case of your PC)
18.April.2014
Apr 08, 2014 | Samsung New original R428 R403 P428...
My Samsung RV511 Laptop isn't getting power.
Most likely problem in this instance is a loose dc socket. it is a cheap fix or you can re-solder it yourself, if you have the ability.
Nov 26, 2012 | Samsung Rv511-a01 Laptop
New battery charging very slowly?
Power off your Laptop, unplug the power cable from the laptop as well, take the battery out and wait for about 5 minutes. Put the battery back in, make sure it is seated properly. Plug the laptop back in and power it on an see if that charges the battery quicker. If it doesn't you may have a bad battery, and I would contact the place you bought it and ask for an exchange.
Oct 16, 2012 | Compaq Presario CQ61-310US Laptop
R530 switchesoff
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the battery dropsoff to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 12, 2012 | Samsung R530 Notebook
'79 CB 750 won't start back up after running for a while
I would take the bike and or the battery to Sears or any large auto parts store and let them test the condition of the battery and the chargeing system.They will do it for free.Bike batterys seem to only last 2 or 3 years.
Oct 02, 2009 | 1982 Yamaha XZ 550
MY MOBILE PHONE CHARGING SOCKET HAS SNAPPED
You have 3 options when the charge port breaks.
1. get it repaired, warrant if possible
2. Get a new one
3. Get an external battery charger and charge battery separate from phone. Another battery and charger will set you back about 10 dollars on ebay.
For more information and links to the parts check the following link below.
Fix for Broken Charge port on Samsung SGH-D900
Mar 07, 2009 | Samsung SGH-D900 Cellular Phone
Compaq V5000 Laptop wont recongnise / charge battery anymore
yes may be bcoz u already replace 2 battery but the problem is same may be the charging ic problem (in mother board) or the battery quality is not good try with the original battery and see. if still u facing the same problem then show it to repairing center and get it done.
Jun 11, 2008 | HP Compaq Presario V5000Z Notebook
Mp3 playr yp-k3 wont turn on after being charged, we only brought it a week ago and has never worked. Weve tryed resettin the player but still wont turn on.
take it back. it is not worth the trouble if you've only bought it for a week.
if it is a lion battery like the creative mp3s, then charge it for at least a day to begin with.
May 25, 2008 | Samsung Audio Players & Recorders
Samsung R610-64G Laptop Logo
159 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
