How to remove dbx cas 0 fatal error - Computers & Internet
Low disk space. Low memory. How to stop this error?
This behavior can occur if the Outbox.dbx file is corrupted.
To resolve this behavior, rename the Outbox.dbx file:
- Click Start, point to Find, and then click Files or Folders.
- In the Named box, type Outbox.dbx.
- In the Look in box, click your primary hard disk (usually drive C), and then click Find Now.
- Right-click the Outbox.dbx file that appears, and then click Rename.
- Type Outbox.old, and then click OK.
- Restart Outlook Express to rebuild the Outbox.dbx file, and then send the message.
Also you can find 100% solution www.outlookexpress.repair
Aug 30, 2017 | The Computers & Internet
Calibrate cas ap-1 scale
www.cas-usa.com/cas.../AP1%20-%2060LB%20Owner's%20Manual.pdf
Jun 11, 2014 | CAS AP-1-15 Price Computing Scale 15 lbs x...
Outlook express error 0x800cc0d
Checkout this cost effective and result oriented Outlook Express Repair software, with the help of this utility user can easily restore emails files & folders in just few clicks.
http://www.recoverfilesdata.com/outlook-express-dbx-recovery.html
Download the free trial version to get results.
Mar 03, 2013 | Lenovo Computers & Internet
Outlook express won't let me read my emails. An error report box appears, and if I press send or don't send, it closes down outlook express.
This tool is able to recover your DBX file without need of backup file. So choose one repair method according to your requirement.
For more information visit:- Outlook Express Recovery DBX Recovery Software
Dec 14, 2012 | Microsoft Outlook Express
On linux centos it doesn work
The CT4170 SoundBlaster "Vibra" cards are old 16-bit ISA PnP cards, and were not detected at install by Linux kernels 2.16.15-27. You need to get the "isapnptools" package from the Fedora or CentOS sites, and do the following:
2. Install isapnptools using dpkg -i path-to-downloaded file .
3. Create and edit file /etc/isapnp.conf and put the following contents in it:
(READPORT 0x0273)
(ISOLATE PRESERVE)
(IDENTIFY *)
(VERBOSITY 2)
(CONFLICT (IO FATAL)(IRQ FATAL)(DMA FATAL)(MEM FATAL)) # or WARNING (CONFIGURE CTL00f4/-1 (LD 0
(INT 0 (IRQ 5 (MODE +E)))
(DMA 0 (CHANNEL 0))
(DMA 1 (CHANNEL 1))
(IO 0 (SIZE 16) (BASE 0x0240))
(IO 1 (SIZE 2) (BASE 0x0300))
(IO 2 (SIZE 4) (BASE 0x0388))
(NAME "CTL00f4/-1[0]{Audio }")
(ACT Y)
(WAITFORKEY)
4. Run "isapnp /etc/isapnp.conf". If it reports errors, you must change configuration above (it is suited to my setup). Try "pnpdump -c" and put its output in /etc/isapnp.conf file. If it does not help, you must find the correct configuration manually, for example change port to 0x220. For full list of possible values run pnpdump. Note that if you change the configuration, you must change options for modprobe below.
5. Create and edit file /etc/modprobe.d/sbvibra and put the following options in it:
alias snd-card-0 snd_sb16
options snd_sb16 port=0x240 irq=5 dma8=0 dma16=1 isapnp=0
6. Run "update-modules"
7. Run "modprobe snd-card-0". If it works OK (check if "ls -l /dev/dsp" shows that file is present), perform the steps below to make setup permanent:
8. Append following line to /etc/modules:
snd-card-0
8. Go to system configuration (in GUI) and choose "Services". Enable "isapnp" service and tick option to start it at boot.
Hope this helps :)
Ted
May 23, 2009 | Creative Labs CT4170 Sound Card
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Mail sending problem in outlook express 2003
Tried to take backup of messages was not able to copy the dbx files
- Rename folders.dbx
- Was able to send/receive messages without any error
May not able to retreive some messages in sent items, deleted items folder
>lets create new identiy
http://support.microsoft.com/kb/209169
Dec 06, 2008 | Microsoft Office Outlook 2003 for PC
How to recover deleted mails in the outlook express 6.0
A damaged DBX file of Outlook Express can be repaired with an professional application to Outlook Express . By using this utility, you can repair and recover deleted emails or damaged DBX file without any difficulty.
Try:- Outlook Express Recovery Tool
Feb 11, 2008 | Computers & Internet
Computers & Internet Logo
1,964 people viewed this question
David Payne
David Payne
