Question about Refrigerators
The valve does not operate and ice cube does not form
  • Refrigerators Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 11, 2010
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
My ice maker receives water after it has filled and frozen ice cube tray, water in door is a very weak stream, where do I find a correct water line routing diagram, already replaced water valve?
A plugged water filter will cause low flow. To identify which solenoid operates the water flow on the door have a helper operate it while you feel for which one is working. It's possible you crossed the lines. That would explain water running over frozen ice cubes.
Aug 29, 2017 | Refrigerators
Hi have LG fridge, ice maker making ice but freezes into one solid block instead of staying in individual ice cubes making it impossible to dispense do you have any ideas a sto why this is happening and...
Sounds like this is a water level problem. Too much water is being released into ice tray, which raises the water level above the depth of each cube form, causing one big cube. You can adjust the water level.
Check this out:
How to Adjust the Water Level on an Ice Maker eHow
Jul 19, 2014 | LG LSC26905TT Side by Side Refrigerator
Hoshizaki model AM50BAE not dropping ice...
Replace water float and check water inlet valve. with water constantly filling sump tray it will not make ice water will never cool down to 32 deg.
May 26, 2012 | Hoshizaki Cubelet Ice MakerDispenser Water...
There is a sheet of ice forming in the ice cube tray and a larger one forming on the bottom of the freezer. The GE refrigerator is only 6 months old.
Because the sheet of ice is forming on the ice maker first it leads me to believe the water control valve for the ice maker is leaking water into the ice maker when it should be off. A filter installed before the dual water control valves would also be helpful. If you could find the model number of your refrigerator I would be able to tell you the part number. Sea Breeze
Nov 24, 2009 | GE Refrigerators
The cubes are hollow and keep get stuck when they try dispence
The cubes are hollow? Means not enough water coming in on the fill cycle to fill the metal ice tray (netal form, see solution #2). There should be an adjustment under the end cover, looks like a screw with a spring around it. Look inside the cover and see if the directions are there for adjusting it properly.
Sep 19, 2009 | Whirlpool GD2SHGX Refrigerator
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in icemaker overflows into ice cube storage box AND CAUSES ICE CUBES TO FREESE TOGETHER AND FORM BIG ICE CHUNKS. ALSO THE FULL SHUT OFF PADEL HAS ICE FORM ON TOP OF IT
Check the ice maker after it dropped the ice cubes and when it calls for water it should be pouring it for no much more than 7 seconds ,if more it overflows, in this case the module board inside the ice maker has to be replaced(or for almost the same price with parts and labor you can replaced it for a new ice maker) But if water is sitting in the ice maker all the time , the dual valve which supplies water to the ice maker is leaking and needs to be changed (it's located at the back of the fridge in the bottom behind the cover where the water line is hooked up).
Aug 05, 2009 | Refrigerators
Scotsman icemachine m# DCE33A-1WB ice cubes are hollow
There is a cube size thermostat that energizes the timer. If it has been energizing early try a thicker setting on the cube size. If still gives problems ... your trouble was back in Feb I assume in cold weather.. If the machine is not in a room where the temp stays above 65'f this can also cause premature harvesting as you discribe also. Also if you are loosing water from the water curtian not sealing off it will cause the problem you discribe because the water is dripping off and out before it can freeze. Any futher questions please post. If this helps you understand your trouble please rate me as high as yuou can, thank you for using fixya
Feb 11, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Ice maker leaking
Sometimes the frozen chunk of ice in the back of your ice tub is caused by the tub being overfilled. The ice cubes pile up so high that they come in contact with the defrost heating element in the bottom of the ice maker. This melts the already formed cubes and form a blob of ice in the rear of the tub.
If the "icicle" is forming even when the tub is relatively empty, then it is probably a leaking solenoid valve. This is an electric water valve that opens and closes according to demand. Like any valve, it has seats that eventually leak, especially in areas with hard water. This will need to be replaced. Water filters go a long way in increases the usefaul life span of the valve and will also improve the ice quality.
Dec 02, 2006 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
