Question about HP LaserJet 4 plus Printer
I just installed a new ink cartridge and printed the test page. There are blots of ink on the right edge of the page, (and back) otherwise o.k. Does the printer need cleaning somewhere? Thanks for any advice, Wendy.
    Problem Solver:
  • 6 Answers
Print another test page or two. Often the toner has gotten onto a roller or something inside and it will clear itself off by running a few more sheets of paper through it. If that doesn't help, remove the toner cartridge and GENTLY use some canned air to remove any lose toner. IF you see alot of toner in the computer, don't blow it out but take a soft dry cloth and wipe it out. If it still continues, the fuser may have defects so it could be coming from that. Good luck, Wendy.
Posted on Sep 09, 2010
Testimonial: "Thanks for your help. Wendy"
Keep getting right cartridge incorrect. what does this mean?
For the check cartridge error:
Gently clean the contacts in the carriage, and on the cartridges with a paper towel or coffee filter moistened with water.
For the poor print quality or missing print:
Perform the Blot Test
Remove cartridge from machine, fold a paper towel back over a couple of times so it is about 4 layers thick, shake cartridge up and down hard, shake it over a sink unless you want to clean ink off the floor.
Now blot the nozzles of the cartridge on the paper towel, for a black cartridge you should see two black stripes, for a color cartridge you should see three colored stripes, if you don't have all stripes the cartridge is clogged or bad.
Have you checked the expiration date on the cartridges you are using?
Are you installing new HP cartridges, or refills?
You may be able to recover a clogged cartridge by swishing the tip in a saucer with a very small amount of warm water, then gently wiping it on a wet paper towel, be gentle the nozzles are delicate.
And do not trust the ink gauge on the PC, cartridges can dry up from the machine just sitting, the cartridges are vented, venting is necessary to let air in so that a vacuum won't develop in the cartridge. get more information and help for HP Printer Ink Cartridge .
Sep 01, 2010 | HP PSC 2110 Color Printer
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
Brother dcp-150c, black ink wont work
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nozzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nozzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
Feb 14, 2010 | Office Equipment & Supplies
Does not print in color although we have a new color cartridge in there and the print preview shows that it should be in color
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
Feb 11, 2010 | HP DeskJet 5650 InkJet Printer
Just installed new cartridges. won't align
Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
Dec 14, 2009 | Dell V305w All-In-One R840635AU InkJet...
Lexmark x73 - prints blank pages
This is a possibility however I can't be positive unless I were there to check it myself... where the printer hasn't been used in years it is highly possible that the ink in the cartridges has dried up. This is not uncommon.
It's also possible that the outlet for the ink on the cartridge itself is blocked with dried ink. You could place the ink cartridge itself in a saucer of nail polish remover (covering the electronic looking portion of the ink cartridge. Leave it there for 30 minutes. Blot dry it with a cloth and replace it into your printer. Try to print once again.
If this doesn't work, you most likely need new ink cartridges. Considering the cost of the ink cartridges for your printer, you are better off buying a new printer in which new ink cartridges are included. A new printer should only cost a little more than the cost of new ink cartridges. Considering you only require am all in one home use printer. Check online sites and check stores as there are usually sales ongoing.
Sep 22, 2009 | Lexmark X73 All-In-One InkJet Printer
My F4180 has stopped printing with the black cartridge. I have checked with different cartridges and have also uninstalled the HP software fully and then made a new installation with all new driver. No...
It's like the ink is not flowing at the nuzzle! To check this you take some tissue paper, fold it so that is is a little padded. Press the black ink cartridge nuzzle (this is the bottom part where the ink comes from) on it. If black in is flowing well, the tissue ahould come out blotted with black ink. If it does not, it means either the ink is blocked or the is finished. Try this with every black ink cartridge you want to test.
If see the blot of black and the problem persists, clean the "electronic" contact side of the cartridge with tissue soaked in a bit of methylated spirit. Do the same to the area it makes contact with inside the printer.
Then try to print.
Sep 20, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Brought 2 new black color inks for lexmark x8350, perform alignment several times and failed, when i set to print only the color will print where as the black color will not print clearly if it prints it...
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please try to print the self test page.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at
least "30 seconds." This is essential. Then plug the printer back in and follow these
steps:
1. Press the "Copy" button.
2. Press the "Menu" button.
3. Press the down arrow button once or until the screen displays "Maintenance."
4. Press the check mark button to select the "Maintenance" menu.
5. Press the down arrow button three times until the screen displays "Print Test Page."
6. Press the check mark button to select this. The Self-Test will start printing.
The self-test should at least print out a set of either black or color bars, if not both
(if you have a printer with both color and black installed simultaneously.) Should this
test fail, try it again without cartridges installed. If the self-test still fails to take
paper in and make sounds like the carrier is moving across the paper, this is a hardware
issue, and the printer will require service. If the self-test completes without any
cartridges installed, run the self-test again with the color cartridge installed. (If you
have both black and color cartridges, after this test, run the test again with just the
black cartridge installed.) If you find that either cartridge causes the self-test to fail
A technique to improve print quality is to try and clean the cartridge nozzles. You can clean the cartridge using the following steps given below:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
If you have replaced your ink cartridge with a new one and are continuing to experience difficulties with print quality, please try cleaning and wicking the ink cartridge. If this fails to resolve the issue, the maintenance station may have an excess build-up of ink.
The maintenance station is located inside the printer on the right hand side. This is the same area where the cartridges sit when in the "idle" position. To access the maintenance station: Unplug everything from the back of your printer, open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fanbelt. On some models, the cartridge access will be very small, but the belt should still be visible. Take the top part of the belt and move it gently to the right.
***Note*** please do not pull outwards on the belt. The cartridges should come over towards the left side of the printer. The maintenance station will be on the right side on the bottom of the printer behind the fixed cover. Clean the area with several damp cotton swabs or damp papertowels until the build up of ink is removed.
Once the maintenance station has been cleaned you should "wick" the cartridges. Remove the cartridge from the printer. Get a clean damp paper towel and lay it on a flat surface. Set the ink cartridge right side up, with the ink nozzles touching the towel and hold in this position for about 15 seconds. Then wipe the nozzles across in one direction only (left to right). Repeat this process, each time using a clean spot on the paper towel, until it looks clean. Dab the cartridge on a dry towel to make sure that the ink is flowing.
After you have wicked the cartridges place them back into the printer, securing them into place. Plug the power back into the printer. Close the cover and click on "Old Cartridge Installed" on the "Control Program" screen. Once the printer has reset, run the "Clean Print Nozzles" page twice. This should resolve the issue.
your's tech expert
Jeeth
Feb 19, 2009 | Lexmark X8350 All-In-One InkJet Printer
Ink blots deposit onto feed rollers which in turn transfers to all new prints
Most likely you have a leaking print cartridge (toner cartridge). Does it have the same problem if you use the Manual Bypass tray?
It could also be a worn fuser sleeve that is causing the print defect...the fuser would need replaced in that case.
Sep 30, 2008 | HP LaserJet P2015n Printer
Lexmark X75 no color
even though you have ink coming out of the cartridge, if it's more than a few months since it's pumped any ink, it can be clogged internally, blotting with paper doesnt always work. Try a new cartridge, or buy a new printer, it's usually cheaper now to get a whole new printer than it is to replace a set of cartridges. consider it's a few years old now
Aug 16, 2007 | Lexmark X75 All-In-One InkJet Printer
HP LaserJet 4 plus Printer Logo
193 people viewed this question
Seeker5211
Seeker5211
