Question about Vacuums
Hi I have a ws big power vacuum cleaner but have lost the user manual and cannot remember how to work it for cleaning my carpet, can you tell me where I can get the user manual
SOURCE: suction
Check the handle tube for a collection of hair, paper, dirt.
Posted on Oct 23, 2007
reddevil6
  • 1673 Answers
SOURCE: dust blowing out of my vaccuum cleaner
Usually when dust is blowing out it is caused by a clog, either the hose, or the dirt inlet down by the brush roll is clogged. Check them and clean them out and you should be ok.
Posted on Jan 09, 2008
renevacdoc
  • 84 Answers
SOURCE: bissell pro heat instructions
go to the bissell web site at www.bissell.com you can download owner manuals free, hope this helped you. let me know renevacdoc.
Posted on Jul 24, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
    A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
    Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
    So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
    There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
    Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
    I hope these tips help.
    Nov 07, 2014 | Vacuums
    Ive lost my user manual for my bissell
    I lost a user manual, then found this site called find my manual. They emailed it to me in about 2 hours and it only cost about £3, which i thought was very reasonable.
    http://findmymanual.com/
    Hope this helps.
    Jane
    Aug 19, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
    Have lost my instruction manual for my bissell PROHEAT PRO-TECH 7920E pLEASE CAN YOU HELP ME J Mills
    Bissell has online USER Guides... for your model
    CLICK HERE you can click on the user guide under your model to download a fresh pdf copy
    Happy Cleaning!
    Dec 05, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
    Don't remember how to use my hoover carpet cleaner
    Visit HOOVER Support HERE and enter your model number to download a free copy of your manual. Happy Cleaning!
    Nov 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
    Have lost instruction manual for bissell power wash
    BISSELL User's Guides can be downloaded at www.bissell.com
    On the front page under Customer Service click on User's Guides and enter the model number of your unit.
    User Guide will be displayed as a PDF file.
    Oct 22, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
    Intructions
    Hey storm,
    Rather than type all that out, it's faster to get you a copy of the instructions.
    Fortunately, like most (though not all) manufacturers, Bissell makes owner manuals for their recent carpet cleaners available online on their website. Go here
    http://www.bissell.com/Product_Search.aspx?Criteria=9500
    and choose the manual for your model ["User Guide (PDF)"]. As long as you have free Adobe Reader software installed on your computer, you can read and/or print the manual out for free.
    Jun 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Vacuums Logo
    63 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
