Question about Hunter 27185 Remote Control
I just changed the batteries in my air conditioner remote control TAC490 VER1.1. Now it has not control the conditioner. When I try to turn on the conditioner with it I see some leds activity on the conditioner receiver, bit it not turns on. How can I sinchronize it. Please assist.
  • 2 more comments
  • leonid_kuril Sep 09, 2010
    Hello Ginko,
    I'm sorry, but it does not help.
    The same problem. I see leds activity on the A/C receiver, but it does not turn on.
    Do you have some another solution?
  • leonid_kuril Sep 10, 2010
    The problem is still not solved. Need your aasistance.
  • leonid_kuril Sep 11, 2010
    Sure.
    As I already wrote, there is some receiver leds activity when I try to turn in the A/C by the remote.
    So, there is no problem with the batteries polarity or something like this. I downloaded the datasheet of the remote but not found there any information about units sinchronization. The DIP-switch is in the following states:
    TAC-404 + Sweep + ∞C (Default Code) ON OFF OFF OFF OFF ON OFF
    What my be a problem?
    http://www.condi.ru/pdf/file_364.pdf
    I not see the leakage vestiges, but I'll check it.
    Thanks.
  • 666 Answers
You will want to go into your user manual and look up the remote control commands I would assume it may have a few just in case something else in your house was using the same frequency it should provide you with options for selecting a channel with the remote if you need any help finding a manual do to losing your own we can help with that as well
hope this helps
Robb
Posted on Sep 11, 2010
  • Hunter Master
  • 17,130 Answers
It is possible that your battery had leaked out into the board .this might have caused shorting in the circuits and changed the frequency output to the IR( infra red) emitters.
So open the board and clean well , possibily wash with petrol and dry.
If not solder the sections of the controller IC and the crystal and try again.
Lastly you can try to change the crystal to confirm or else the controller IC can be defective.
    President:
  • 1,961 Answers
Double check the polarity of the batteries that you inserted and make sure that the contacts are secured and fitted the battery terminals,you can also open tha cover of the remote to see to it that the terminals are securely solderd to the PCB.use a soldering iron to resolder them..thanks for using fixya good luck please do click the tumbs up button for my ratings..
Posted on Sep 10, 2010
  • Danilo Baraquiel
    Danilo Baraquiel Sep 11, 2010
    hello did you try my solution?
  • 19,396 Answers
Hi.
If the remote is the original one, then they should not need re-sync. The IR receiver on AC is set on same fixed frequency code assumedly used by the remote.
Try to cut power to the AC completely (trip circuit breaker or disconnect power cord, depending on the case). By draining power completely you will reset the AC electronics and this may fix the problem. Keep power off for about ten minutes.While power is off also remove remote batteries for one minute.
Posted on Sep 09, 2010
How to change batteries on the remote control of my Panasonic air conditioner Model Number CU_RE24LKR
  • Remove battery compartment cover
  • Observe battery orientation and polarity
  • Remove old batteries
  • Install new batteries
  • Test operation
  • Install battery compartment cover
Aug 30, 2016 | Panasonic Heating & Cooling
On my Air conditioner, there are no buttons for me to change controls on it, as well as the remote is not working. Could you possibly help me resolve this ? I put brand new batteries in it.
The remote is the only controller. Try turning off the power to the system at the breaker or o.d. disconnect, wait about 10 mins(at least 5) and then turn power back on. This should reset the system and if it has the controller locked out, should reset it also. If not, the remote may be damaged. Or I.d. unit sensing capabilities are damaged. Make sure the battery terminals in the remote are not corroded or broken and the batteries are new/hot. If the indoor unit has had water leak issues it may have damaged the sensor inside the air handler. I'm not sure what unit you have, window unit or mini split
Jun 23, 2015 | Heating & Cooling
How can I open the DPAC8399 remote control
Try this:
http://www.helpowl.com/q/Danby/DPAC8399/Technical-Support/change-batteries-remote/179339
Jan 20, 2013 | Danby DPAC8399 Air Conditioner
My remote controlled air conditioner would not turn off because I had dropped the remote on the floor. I tried many time to turn the air conditioner off, through the remote control, but it did not work. ...
There was no danger and you were in no danger....the batteries just got juggled around in such a way that they were shorted out and discharging very rapidly...
Replace the batteries with new ones and install them correctly and everything will be fine...
heatman101
Nov 25, 2010 | Heating & Cooling
REMOTE WONT TURN ON AIR CONDITIONER TRIED ALL THE
If the remotes work on other like units but not on that one, it probably has a bad control board.
Jan 16, 2010 | Heating & Cooling
The remote control won't work even though I have
bad remote control may something got spilled on it they do not like to get wet. Tom try google manufacture to get new is their power to the unit tripped breaker.Tom
Jun 20, 2009 | LG LSC121PMA Split System Air Conditioner
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
Air Conditioner will not turn off with remotes
Remote control has a reset button found in front or at back inside battery compartment. If you replace your remote control with battery or your remote control is malfunctioning you to reset it.
You don't have to go outside to turn off the unit, you can "on" or "off" the unit using the emergency operation switch.
Jan 02, 2008 | Heating & Cooling
Air conditioner
Some some remote control have RST or RESET button, you have to push this every time you change the battery or for malfunction remote control. You can find this either in front of remote control or at the back of the remote in battery compartment.
Jan 01, 2008 | Heating & Cooling
Televison & Video Logo
381 people viewed this question
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
