Question about Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
Stuck in a corner wont go up walls, has sufficient suction
  • 990 Answers
Make sure you have enough hose (at least three to five feet past long spot in pool). Then check your baskets and filter. If you can check the impeller in the pump (If you already did this skip this part) Next remove head and take to store and have them check the diarpham and for body cracks also be sure you have checked all your hoses before going. Replace any in ?
Posted on Sep 09, 2010
Barracudu wont go up the walls anymore and seems to get stuck in corners
Check your filter. It may be dirtier than it once was. If Sand Filter, use a "Sand Filter Cleaner" to soak the sand & remove the particulate that normal backwashing won't remove. If cartridge filters, then the elements need to be soaked overnight with a Cartridge filter cleaner. If DE, then - grids need to be removed and even possibly cleansed (mild acid wash) then recharged with fresh DE.
Or... check internals of pump. The impeller may be plugged where the flow is reduced. Internals of the cleaner itself, is also suspect. check for any sucked up large debris: pine cones, toys, plastic bags, etc. You may also have a pinhole or larger in the suction hose. Do you have a dog or critters (possums, squirrels, raccoons?) they have been known to Attack the hose and the teeth put holes into the hose. Just a minor hole will affect the efficiency of the operation of a suction style cleaner.
Feb 01, 2014 | Zodiac Baracuda X7 Quattro Swimming Pool...
Viper moving very slowly and wont turn
check water flow to unit if ok take apart check hoses and belts
Sep 11, 2012 | Hayward Viper Pool Cleaner
I installed the Hoover Wind Tunnel Central Vac in my new home. After connecting the wall outlets and successfully turning on the system from the hose control, I discovered there is lots of air flow t
I would recommend checking your wall outlets where the hose plugs in for any type of clog in the tubing. If the vacuum itself has great suction but when you go to the wall outlets that is probably something in the hose that is stuck. If cleared it will most likely have excellent suction throughout the entire system in the house.
Jul 21, 2012 | Vacuums
Loss of suction. we have checked that there is ni blockage.
Disconnect the incoming pipe from the vacuum power unit and turn the switch on (on the side of the unit) while you feel the bottom of the unit with your hand. If BOTH motors come on and sound normal and are producing suction you should feel the bottom of the canister flex or you should feel suction at the inlet connection.
If the bottom flexes but there is no section at the inlet there is an obstruction in the pipes witin the vacuum unit. A stiff wire with a hook bent at the end is usually sufficient for removing the dust stuck in that piping.
You can also unplug the 110v poser then remove the top cover (only 3 or 4 screws) and visually inspect the motors and piping for failures.
Dec 30, 2010 | Broan-NuTone CV750 Central Vacuum
Has good suction but wont move
Is there a tile stuck in the condom shaped diaphram when you look into the cleaner from underneath. Could be any kind of rubbish make sure you look deep inside as debris gets stuck right at the top.
This diaphram is removable check also that it does not have a hole in it.
Cheers Bazzard
May 08, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Get stuck in the pool corner
try adding a hose length or taking one piece off. Also you can try increasing or decreasing the suction.
Jan 15, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Gets stuck on walls
turn down the suction if thats not the problem under the left rear pod on the body housing youl see a little straight slot for a screw driver theres 3 settings it actually shows images like a ladder turn the screw down to the first step that should solve your problem
Jul 17, 2009 | Hayward Navigator Pool Cleaner
Bissell ProHeat 2X(9200) hose to cleaner solution no suction
There are a couple areas to check:
1. The black gasket where clearview water collecting unit and the base's front meet. Ensure gasket is in good condition.
2. Check if you're getting sufficient suction: remove the water collecting unit. When you turn on the the unit, you'll feel suction out of a black hose pointing upwards next to the grey dial. If you're not getting sufficient suction you need to check that all the gaskets are seated properly. there are 3 gaskets: (1) an orange one seated between the black hose and the base unit (2 and 3): On the bottom of the unit there is a removeable panel. This panel has a gasket (red) and inside there is a white gasket.
Jun 30, 2009 | Bissell 9200 Upright Vacuum
WHY SHOWER HEAD WILL NOT STICK
Make sure you clean and dry the wall that you are sticking the shower head to. It is OK for water to touch the exterior, but not the interior. Also, make sure there is no cracking or degradation of the suction cup. Also, this is posted in the wrong section.
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DCC-1200 Coffee Maker
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
197 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
