Question about Garden
Deck belt broke for my mtd je/130. i've bought a new one but can't figure out its route
  • 10865 Answers
SOURCE: Installing mower belt
The pulley at a wierd angle is the tension pulley. You may get the manual on line for free if you are lucky but not all mower manufacturers are that generous. What kind of mower do u have?
Posted on Mar 31, 2009
SOURCE: MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Posted on Jun 15, 2009
  • 138 Answers
SOURCE: have a power kraft 18.5hp with 46'' deck, need a
first you'll need a model number. look on the underside of the seat, or on the metal plate between the rear wheels for the model no. sticker. wards tractors were made by MTD. there will be two numbers plus the serial number, write 'em both down. then log on to www.milacalawn.com. in most cases, you'll be able to pull up an owner's manual for your tractor with one or the other model numbers
Posted on Aug 30, 2009
mowerman1857
  • 389 Answers
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
Posted on Sep 18, 2009
buffalonyman
  • 1865 Answers
SOURCE: Routing Of Deck Belt For DLT 2000 48 inch Deck
Go to this website, and enter your tractor model number, it will give you a drawing of how the belt goes
http://www.searspartsdirect.com/partsdirect/index.action?psid=26128388&sid=PSx20071217x00001a&OVMTC=Exact&site=&creative=3106724154&OVKEY=sears%20parts
Posted on Nov 07, 2009
Have a MTD RH 125-0479 lawnmower. Require a simple routing diagram to fit new 754-0479 deck belt. Can you help?
Go to youtube. They have some wonderful videos on mowers and belts. Good luck.
Aug 05, 2016 | Mtd Garden
I need a diagram of the drive belt and blade belts. How they run above the deck.
Ok.... I have to guess what mower you have. I am going to pass a deck belt link below. The first pitcures that will come up are for John Deere. At the top of the page you will see brands with links to the belt routing. Click on the brand name for your mower and then locate your deck.
John Deere http://opebycrigby.tripod.com/decks/jddeck.html
MTD http://opebycrigby.tripod.com/decks/mtddeck.html
Murray: http://opebycrigby.tripod.com/decks/murdeck.html
The MTD and JD links have most deck belt routing pictures that can equate to other brands.
Thanks for choosing FixYa,
Kelly
Jun 09, 2011 | Garden
Belt broke on riding mower and I don't know how how it goes back on
Go to Sears and take a look at how the belt is routed. After you get it figured out take a sharpie and mark your deck so you don't have the same problem again. When you buy a new mower mark it before you have to replace the belt.
Aug 19, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a yard man 13AH762F752 How do I know what size my deck is I thought it was a 38" and bought v-type belt and it is to shore so how do I find out my deck size?
If you have a single idler pulley you should have a 38" deck. If the deck has two idlers, then you must have a 42"deck. You should be able to approximate by measuring. This is the "cutting" width, not overall width. Two things might have happened. You didn't get the right belt, or you haven't routed it properly. Here is a link to the Yardman web site to download your manual if you don't have it. It appears that the 38" deck requires a longer belt than the 42" deck. http://manuals.mtdproducts.com/mtd/Public.do?langId=-1&BrandCode=10201
Jun 18, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Need to know what size and hoe to change belt for yardman 46" cutting deck for blade model # 13a0771h055
If you are missing the manual, for the said model,
I have found that the simplest way, of figuring out the correct route for the belt, is to remove the deck, and hold the replacement belt above the mechanism, with the tension from the engine end.
Then 'mock up' the replacing proceedure, bearing in mind the correct direction the tensioner/s, move in.
Then it's not too difficult to figure it out the correct route.
Hope that's clear enough, good luck.
Jul 18, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Deck belt
go to partstree.com click mtd,then put in your model#;then click deck assembly. it will show you your belt routing;then scroll or click the item #.it should tell you the lenth of your belt.hope this helps.please rate this;thank;s
Jul 02, 2009 | Mtd Garden
Can't figure out how to install main drive belt on riding mower.
Usally if you look on the bottom of of your mower deck it will show you the route you need to go
May 31, 2009 | Garden
The newly purchased deck belt turning the blades is extremely loose
If idler is in tact and spring attached, it is likely that the belt isn't routed properly. If you try to route the rear-most portion of the belt around the idler, it will be loose. You must route the front-most portion of the belt around the center blade pully and then around the idler. Just Google "MTD 46 inch deck diagram" and you will go to a Parts Tree site with the proper diagram showing routing.
May 26, 2009 | Mtd Garden
Garden Logo
125 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
