Question about Takara CDV1003 DVDMP3MPEG4USBSD Car Radio Car Video Player
Hey when i play a vob file with usb pen drive in takara car video player the video runs in motion for some time and it happens repetedly ...anyone help plzzz
Tip
VOB movies for Acer Iconia Tab A500-Stream DVD VOB to H.264 MP4 to Acer Iconia...
Transfer/Play DVD VOB files to H.264 MP4 for Acer A500 <br />Join multiple DVD vob files into one for Playback on Acer Iconia Tab A500 <br /><br /><b>A VOB file (Video Object)</b> is a container format in DVD-Video media. VOB can contain video, audio, subtitle and menu contents multiplexed together into a stream form. VOB file can contain H.262/MPEG-2 Part 2 or MPEG-1 Part 2 video, MPEG-1 Audio Layer II or MPEG-2 Audio Layer II audio, but usage of these compression formats in a VOB file has some restrictions in comparison to the MPEG program stream. <br /><br />How to convert and play DVD VOB files on Acer Iconia Tab A500? For Acer Iconia Tab A500 can not accept this format. <br />Acer Iconia Tab A500 is also a great media player which supports a lot of media formats including files with XviD, MP4, H.264, H.263 as video format and MP3, WAV, WMA, eAAC+ as audio format. So you need to convert the files before transferring and playing them on Acer Iconia Tab A500. <br /><br />Aunsoft Video Converter is the best <b><a href="http://www.aunsoft.com/video-converter/">VOB to Acer A500 Tab converter</a></b> for you to transfer files to tablet. It makes it easy to transfer VRO files to Android tablet by converting DVD VOB to MP4 for Acer Iconia Tab A500. You may also deinterlace VOB to progressive mode for perfect playback on Acer Iconia Tab A500. <br /><br />Below is the quick step-by-step guide for you to <b><a href="http://canon-videoconverter.com/2011/06/join-multiple-dvd-vob-files-into-one-for-playback-on-acer-iconia-tab-a500/">transfer and play VOB to Acer Iconia Tab A500</a></b> via Windows XP, Windows Vista, Windows 7. <br /><br />Step 1. Load VOB to Aunsoft Video Converter. <br />Run Aunsoft Video Converter as the best VOB to Acer Iconia Tab A500 converter, and click the "Add" button to import the .vob videos. <br /><img src="a500-vob-converter.jpg" /> <br /><br />Step 2: Choose the suitable Acer Iconia Tab A500 format. <br />As we know, Acer Iconia Tab A500 supported video like XviD, MP4, H.264, H.263 format like MP4. Here just take H.264 HD Video (*mp4) for example. Choose Common Video &gt; H.264 Video (*.mp4) as output format. <br /><br />Tips: Click "Settings" to set the Video/Audio Parameters like Size (resolution), bitrate, frame rate, etc to be more suitable for Acer Iconia Tab A500. For example: Set Size/Resolution to 1280*800 pixels. <br /><img src="set-a500-profile.jpg" /> <br /><br />Step 3: <b><a href="http://www.aunsoft.com/video-converter/">Convert/Rip DVD VOB to MP4 for A500</a></b>. <br />After all the above settings, you can click "Convert" to start <b>conversion VOB to MP4 for Acer A500</b>. Only a few munutes later, you can get the generated files by clicking "Open" icon. <br /><br />When the conversion is done, just connect Acer Iconia Tab A500 to Widnows PC via USB cable, and mount the converted videos to Acer Iconia Tab A500. <br /><br /><b>Tips:</b> If you want to <b>join multiple DVD vob files into a large files for smoothy playback on Acer Iconia Tab A500</b>, just check "Merge into one file" to make it.
on Jun 06, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tv usb port not working
hey check some other pen drive also
Feb 03, 2013 | Computers & Internet
I have change my pendrive format into FAT32 after i plug in my DVD player inside show no any video please help me solve this problem thanks alot
Usually pen drives supports files like .avi .mpg .jpg and etc. Be sure that pen containing media supported by the player. If files are not in that format you can use a video encoder to convert them to supported ones. You can use NTFS to play files in DVD player.
Aug 13, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Unable to read mkv and avi video files from usb drive on philips dvp5990 dvd player
what error does it give? mine reads avis fine, as long as theyre within resolution limits. same for windows media format. couldnt get the mkv files to work though. the usb drive has to be formatted fat32, ntfs does not seem to work. burning these files to dvd as a data disc is another option. lets you fit 10+ hours of video on the disc vs your standard 2 or 4 hour max limits.
Jan 27, 2010 | Philips DVP5990 DVD Player
I have prepared a home movie on Windows Movie Maker and when I copied it to a DVD it would not play on a dvd player can anyone tell me what I did wrong please thanks joe
The reason why the DVD disk you created may not contain the file format the DVD player recognizes. On a normal DVD disk there are two folders - AUDIO_TS and VIDEO_TS folders. The video files are located in the VIDEO_TS folder. This video folder contains the VTS_xxx.vob video files (the video files has a .vob extension).
The video file you created may have a avi or wmv or mov or mpg extension, whilst these video files can be played on a computer but they won't play on a DVD player.
Check the movie software you are using and make sure it creates the correct file format for a DVD player.
Jan 07, 2010 | ASUS Computers & Internet
DC 220 video file freezes in VLC player
Installed open source software mediacoder to convert my .VOB file into MP4. It is playing perfectly in VLC player now
Mar 21, 2009 | Canon DC220 DVD Camcorder
Problem in playing .vob files
I can play .vob files with a cool media player called VLC player, which plays everything I throw at it. I recommend you download it from here:
http://www.videolan.org/vlc/
and when you install it, set the File Associations to play everything with VLC, that'll let you double click on a .vob file and play it automatically.
VLC has a much lighter 'footprint' than Windows Media Player, or Nero or many DVD players,and has amazing codec-support already included.
If the .vob files are encrypted, then maybe that is slowing down your laptop, but that is not the only reason for this to happen.
If it still restarts automatically, you may have picked up malware from downloaded movies, and need to download Spybot and scan and immunize your hard drive. Spybot is completely free. Trust me, i don't like paying for things :)
It's also possible that you need to clean up your registry and your drive with a free program called ncleaner. you can find that here:
http://www.nkprods.com/ncleaner/
I suspect you will be successful with VLC player, though. Enjoy your movies :)
Chris
Dec 16, 2008 | Microsoft Windows Vista Ultimate Edition
Lacie Silverscreen USB2.0 500Gb
If you can use software to encapsulate the VOB file(s) in an ISO, it will play them in order.
Feb 07, 2008 | LaCie Silverscreen 80GB USB 2.0 - Portable...
Takara CDV1003 DVDMP3MPEG4USBSD Car Radio Car Video Player Logo
Top Takara Car Audio & Video Experts
xxxxxx xxx
Are you a Takara Car Audio and Video Expert? Answer questions, earn points and help others
