Question about Lexmark X646e All-In-One Laser Printer
I'm working with a Lexmark X646e MFP that sometimes get a paper jam with code 202.04. When i open the printer and take out the Toner the page is always in the same spot and shape. Half the paper is before the fuser assembly and the other half is all jammed up inside the Fuser. If i open up the redrive door you can see the upper half of the paper stuck inside the Fuser. I've already changed the Fuser 2 times, but i've also found out that the fuser assembly installed is not new, its been remanufactured. So i donĀ“t really know if the fuser assembly is causing the problem or is it something else. Thanks for the help
  • Lexmark
    Lexmark Sep 09, 2010
    This is a fuser and redrive issue. If there were any services done on the printer by Lexmark, I suggest you contact Lexmark technical support via their toll-free number for assistance. If service was done by a 3rd party, contact them instead. Thanks.
pastorm
  • 98 Answers
SOURCE: Paper Jam
The fuser unit has a pape sensor. If, for some reason, the sensor is stuck, the printer will read a paper jam. Open the rear door and inspect the paper sensor located in the fuser assembly. See if it came out of it's original position or if there is something blocking it from moving freely. Good luck.
Posted on Aug 23, 2007
flopez
  • 161 Answers
SOURCE: Dell 1600 paper jam 1 or no cartridge
Your unit is actually manufactured by Samsung. Most probably you have a bad paper sensor. As a technician, you will find these sensors on the power supply board (SMPS)or main board. If your are receiving tech support from Dell, please illustrate those guys on how to do their job.
Posted on Oct 02, 2007
Cops
  • 64 Answers
SOURCE: Fuser Error 50.1 Fuser is hot. What is a fuser?
50.1
A low fuser temperature error has occurred, possibly due to an inadequate external or internal power supply.
this basicaly means that either the dc controller board is on its way out (expensive) or that there is a drain on the power line.
if you have it plugged into an extension lead try plugging it directly into the wall socket. if this fails also try using a different power lead (very easy to get hold of and are normaly called kettle leads)
Hope this helps
Cops
Pete@wedotoners.com
Posted on Oct 10, 2007
The Machine
  • 788 Answers
SOURCE: Lexmark Optra C710 keeps on having paper jams
Make sure the rear door is properly seated on it's hinges. Also look for any burs in the plastic guides that the paper might be catching. If you see any burs, try to smooth them out with a nail file or something.
Posted on Jan 10, 2008
Soulvisitor
  • 1113 Answers
SOURCE: HP clj 2550n error 50.2 fuser
Replace fuser assembly is the fix
Normal consumable, the lamp electrics (lamp, thermistor) will have blown.
9337832.jpg Part info
Posted on Jan 13, 2008
Lexmark x646e saying scanner cable missing while cables are connected. How can I fix?
X646e - 298.02 Scanner cable missing
The ICC card and/or Motor Driver Card has failed.
ICC - 40X0485
Motor Driver Card - 40X0486
ICC is located in the rear of the flatbed assy. Motor Driver card is in the rear of the ADF Assy.
Feb 13, 2015 | Lexmark X 646e MFP - multifunction ( B/W )...
Error 288.00
288 paper jam message indicates that the MFP has detected a jam in the finisher at or around Area F, Area G or Area H.
see http://support.lexmark.com/index?pmv=print&page=content&locale=en&userlocale=EN_US&id=SO4468
Dec 12, 2013 | Lexmark X850e, X852e, X854e Bar Code Card...
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
C544dn printer - getting code: 941.02 service magenta TMC sensor
Please try the steps provided below.
Step Action 1
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page.
Did the error message return?
Yes: Continue to Step 2.
No: The error is resolved. 2
Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Power on the printer/MFP again and print a test page.
Yes: Continue to Step 3.
No: The error is resolved. 3
It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
Did the error message return?Yes: Continue to Contacting Lexmark.
No: The error is resolved. If the toner and/or developer were not near the end of their working life.
You can also refer to this link: http://bit.ly/kecjEM
Jun 07, 2011 | Lexmark C544dn Laser Printer
THE 942.02 Service Yellow TMC Sens message is in the screen. What does it mean. It will not let me print
Error indicates a problem with the Cyan toner cartridge/developer. Try the following steps:
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page. Did the error message return? Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Try printing another test page, verify if you're still getting the same error. It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
For further assistance, please contact Lexmark Technical Support Center.
Jan 27, 2011 | Lexmark C540N PROD SPECS TBD Printer
Lexmark X646e All-In-One Laser Printer Paper jam duplex Out lexmark used to print duplex but after techs took it apart and cleaned it, it doesn't print any more. The paper prints one side and the gets...
Open left door. Remove screw covering the white plastic cover. Observed the white gear that you will now see. Make sure that it is not broken. If this gear is broken, you will not be able to duplex. What is the full code numerical code of the error?
Nov 09, 2010 | Lexmark X646e All-In-One Laser Printer
I have a lexmark pinter/fax model x646e, i do not have the manual. when i am trying to make copies it reads" 290.01 scanner jam, remove all originals from the scanner" but there is nothing stuck. i have...
This is a hardware issue. Maybe the sensor, the pick arm or the pick roller itself that's causing the problem. Here's an article on Repeated '290' Paper Jam Messages Occur When Using the Automatic Document Feed (ADF) on a Lexmark X64x Series Printer. Just click on this link: http://bit.ly/clBsWr. If this doesn't help, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 26, 2010 | Lexmark X646e All-In-One Laser Printer
Rear door paper jam
Here are some articles on rear door paper jam on Lexmark X646e printer. Just click on these links: http://bit.ly/blkK1m ("202 Paper Jam" Message on a Lexmark X642e, X642e or X644e Multifunction Printer) and this link: http://bit.ly/awNDER (A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark X64x Series Printer). These are some guidelines on how to resolve the rear door paper jam on your printer. If you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jul 22, 2010 | Lexmark X646e All-In-One Laser Printer
201.02 paper jam
Please open up the printer take the toner out, please there is a paper jammed in this location, Bring paper out put toner back and power on the printer
Apr 17, 2010 | Lexmark X342n All-In-One Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Lexmark X646e All-In-One Laser Printer Logo
97 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
