Question about Acer Aspire 5003WLMi Notebook
My acer aspire 1642ywlmi do not power at all, when i plug in the charger the charging light will show and the standby light will blink but it does'nt switch on. And when i remove the battery and plug in the charger nothing shows.Please help me solve my problem.Thanks.
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Posted on Sep 19, 2010
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
The orange light blinks a couple of times then goes off and after that the green power light blinks once with the antenna light
Blinking orange lights means no power or low power. Not enough to power the laptop. If it is plugged in and still the same, then your charging port or charger is damaged.
Mar 03, 2014 | Acer Aspire 5050-3371 Notebook
Acer aspire 5930g charger is blinking with or without battery when plugged in to my unit
If the charger light on the power supply is blinking, there is a short circuit or overload somewhere. Probably the DC plug.
Sep 30, 2013 | Acer Aspire 5930 Laptop Charger...
Acer Aspire 5552 won't power up, charge light flashes on and off
Remove the battery and plug in the Cord/charger, will it boot? If no, try another Cord/Charger with the EXACT same power specs. Replace battery if necessary.
Mar 02, 2013 | Acer Aspire 5552-3691-24271 Laptop
Sir i have acer 4720Z series laptop. when I plug in the power adapter it show adapter light green. when adapter pin connect the laptop then light show blink and laptop not charging.
Your laptop battery seems to be broken.
To be a 100% sure, can the computer run on only battery?
Try to have the computer plugged in to the charger for a couple of hours without starting it.
Feb 28, 2011 | Acer Aspire 4720 Notebook
Wont power back on. only yellow light flashes
I have an aspire one AOD250 notebook and I have had to unplug and plug the power cord to the outlet on the side and it always gets my charger light to come on, try it
Apr 03, 2010 | Acer Aspire 5610-4648 Notebook
Aspire One notebook won't power up. If I hold down the power button with the battery in, I can get the indicator light to blink red, but no start up. Have tried to remove battery and left it alone for...
Try to power up with the battery charger cord plugged in and attached. Then you can use AC power while the battery charges. Also check your power options. When the battery light turns green it is done charging. Then try using the battery alone again.
Feb 28, 2010 | Acer Aspire One PC Notebook
My charger works and the light is solid green when i plug it in, but when i plug the charger into my computer the light blinks and my computer wont charge. what's wrong?
Either the battery has failed beyond the point of taking a charge or power connector on the mother board is broken. Check out my website www.micromendllc.com
Feb 26, 2010 | Acer Aspire 3680 Laptop
I have a acer aspire 3680 that will not charge
The power cube is the problem..lets face it you had a 50/50 chance of getting to the root of the problem..so by replacing the battery that only leaves....
Don't Forget to rate the advice!!
http://www.aa1consulting.com
Jul 27, 2009 | Apevia HQRP Replacement Laptop AC Adapter...
Acer Aspire 5003WLMi Notebook Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
