FixYa.com
Tags:
2001 Daewoo Lanos
Lanos Brake Problems
By Grant - usenet poster
Just wandering if anyone has had problems with their brakes.
I.ve had my brake disks and pads replaced but I still get a gringing noise.
The noise happens when it wants to. Sometimes I can be in the car for 5
minuts and when I brake the brinding noise occurs, sometimes it happens
after a hour or two. I took one of Daewoos main guys for a drive to try and
show him the problem but alas nothing happened, dropped him off and voila it
happened
Chris
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 14, 2008
FixYa! (100)
Grant
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I don't know about the OP's problem, but I have read several articles
on disc brake problems that can be caused by..of all things... under
inflated tires. The chain of events goes something like this. Disc
brakes rest lightly against the rotor nearly all the time. Under
inflated tires can heat up much more than normally inflated tires.
This heat expands the rotor and brake parts just slightly, but enough
to press the disc pads against the rotor with some pressure. This is
like riding the brake pedal and causes excessive brake wear, rotor
warping, and a host of other problems. This problem is especally
pronounced on front wheel drive vehicles as the front tires have the
stress of moving the vehicle, and of turning, and frequently loose
some air pressure more quickly than the rear tires.
Dutch
"I think therefore I am...usually in a lot of trouble."
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Helpful (85)
Grant
Rating: 0%, 0 votes
I have a 2001 Lanos and had the have the brake rotors replaced because
they had already warped after 2 months. The dealer replaced the rotors
without any hassle. My problem on my car was called "brake judder" and
while there was no grinding sounds when I braked coming off the
freeway there was a shudder that came through the steering wheel. This
is not a problem exclusive to Daewoo.
Solution #3
Not Rated (0)
Grant
Rating: 0%, 0 votes
Your pretty on the mark. Brake Judder is caused by hot spots on a rotor
which hardens the rotor in spots
causing the the pads to slip over the hardened spots.
Solution #4
Not Rated (0)
Grant
Rating: 0%, 0 votes
The same things happens to me sometimes, as I just got my brakes
replaced on my Leganza, and yes, they're going to squake for a while.
What's happening is that the mechanics are now using a softer and
thicker break pad that was on the cars before. I was told that some of
the original pads actually used Asbestos, which had the danger of
getting into the mechanics' lungs. These new pads are made from some
recycled material and are supposed to last much longer, but because
they're a softer pad, it's going to take them a while to "wear in", so
to speak. The occasional squeaking is going to be normal for a while.
However, it it's actually a GRINDING noise instead of squealing,
that's something else...
Solution #5
Not Rated (0)
Grant
Rating: 0%, 0 votes
Had about the same problem with our Leganza. Finally they replaced the rear
brakes.
Bob
Solution #6
Not Rated (0)
Grant
Rating: 0%, 0 votes
"Rob S." <
The Nubira has similar brake problems, so I suspect it is widespread. My
brakes started to pulse, and they shaved the rotors. That worked for
about 6 months or so and then it returned. They replaced the rotors and
the pads. That worked for another 8 months and now they are starting to
pulse again. They also squeal from time to time and there is grinding
feeling up front when turning slowly. When I had it in for my 24,000
service a few weeks ago (that I paid for) they said they couldn't hear
the noise. After reading these postings, I suspect they were just trying
to get rid of me because they didn't want to do the warranty service on
the brakes. The service guy did tell me, by the way, that they were
having trouble getting brake parts. He said they could only get one set
in a week. To me, that was indicative of a pervasive brake design
problem. I hope somebody in the US sees this as an opportunity and
starts manufacturing brake parts for these things.
This Problem Also Relates To: 1999 Daewoo Lanos 1999 Daewoo Nubira 1999 Daewoo Leganza 2001 Daewoo Lanos 2000 Daewoo Leganza 2001 Daewoo Nubira 2000 Daewoo Nubira
Can you Help with these Cars problems?
2001 Daewoo Lanos
01 Lanos
Fuel pump Not running - hear... Answer This...
2001 Daewoo Lanos
help
i am having trouble with ... Answer This...
2001 Daewoo Lanos
car problem
i have a 2001 daewoo lanos i... Answer This...
2001 Daewoo Lanos
engine
i have a 1994 daewoo 4cyl... Answer This...
Repair Service
Find Car Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
