Question about Acer AL1717 17" LCD Monitor
My moniter completely not working, it was suddenly gone while we were working, also explain me how to open the moniter, please answer Regards Hameed
  • 11,361 Answers
Here are the serive manuals: http://elektrotanya.com/?q=showresult&megnev=acer&megnev2=al1717&kategoria=&kat2=all
It will show you how to open them up.
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL1717Abm/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 09, 2010
Dell e198fp suddenly appeared Auto Adjust In progress. Do not know how to turn OFF. Please help
this is lcd inverter problem open your lcd moniter case and resolder your lcd moniter power board
plese vote me and rat it
Aug 14, 2011 | Dell E198FP LCD Monitor
My Durango has been running with no problems. When I went to start it this morning it was just turning over and not starting. I finally got it to start and it was screeching really bad. When I opened...
That should have an auto tensioner, it could have suddenly gone bad. If you are in an area where the weather has just gotten cold make sure the antifreeze in your radiator is the proper mixture. If the mixture is not right and the waterpump was starting to freeze it would explain the loud squeeling and why the tensioner broke or came loose.
Please take a moment and rate my answer..............Tthanks
Nov 30, 2010 | Dodge Durango Cars & Trucks
Toshiba satelite L500-00W, had suddenly shut off while in progress as to be a black out. I can put the power on but I hear the fan barely and the screen doesn't come on. It goes on but nothing is shown for...
ok try the laptop on a pc screen on the side of your laptop is a socket for a moniter to be pluged in if that works then its the screen try also a light shining onto the screen sounds like the screen reg is gone
Mar 13, 2010 | Computers & Internet
Lenevo Y500 display screen crashed completely
Hi
This can be a number of things its not realy easy to give you the correct answer on exactly whats the cause of this.
If you dont have any experience in opening a laptop i would suggest that you take it in for repairs, if you do then good open the laptop check all the connection points and cables from the screen onto the mainboard. This can also be that the inverter has gone faulty.
Hope this helped
SlitWrists
May 09, 2009 | Acer Aspire 3690-2196 Notebook
Moniter Screen Blank when my PC start....Giga byte 8S661FXME-RZ Mother board
try to remove the motherboard from the casing and see it if the have some capacitors or any circuit distroy. use other mother board for testing chek your hardware one by one maybe some of your hardware devices damages.
Jan 01, 2009 | Computers & Internet
All of a sudden my moniter would not stay on I thoght it was my moniter because it was getting no imput siginal so I hookes uo another comouter to the moniter and it works fine, the message I was geeting...
it is possible the card is going out. however, since it is the ati radeon HD 2400 xt, it is doubtful. you may have been infected with a trojan or other nasty which is the cause. go to
http://www.download.com/SUPERAntiSpyware-Free-Edition/3000-8022_4-187228.html?tag=mncol&cdlPid=10978875
and download and install, then run the superantispy free edition to remove any nasties the security program you have has not caught.
restart the pc. if the problem is not resolved, you may need to re-install the video driver software from ati (if you don't have the cd) at
http://www.amd.com/us-en/SupportDrivers/ProcessorSupport/0,,15218_15219,00.html
you can use the same site for support info and help.
Dec 02, 2008 | Computers & Internet
Samsung SyncMaster 510N
its time for u poeple to buy a new moniter .....or get it repaired by a prof tecnician.....the electrons which bambard on the picture tube at a point of time they become weak...n they loose there capacity......so the moniter starts dim and after wards when the moniter heats up it get fine !!!!!!!!!!!!!!!
Oct 11, 2007 | Samsung 510N 15" Flat Panel LCD Monitor
Compaq Armada E500 PC Notebook Display Completly Out
Hi Jeryl; Im sorry to have to te3ll you but when the power went out it sent a surge to the external monitor . This blew the monitor which in turn blew your video display. This is a not so uncommon problem with laptop displays. They are very fragile. Especially when it comes to power urges. The only way you can fix this is to replace the monitor. Even this may not fix the problem. It could be any one of a few thousand parts inside your laptop. Best advice would be to let your local repair shop do the repair. Hope this has helped. If it has please accept this answer. Thank you; HELP2DIY
Jun 30, 2007 | Compaq Armada E500 Notebook
Acer AL1717 17" LCD Monitor Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
