Microsoft vm option not in IE advance settings
I cant read my mail due to internet explorer not responding
HI
yes you can u have to configure your email account in Outlook or Microsoft outlook
Dec 22, 2010 | Computers & Internet
Internet explorer is not working,but mozilla firefox is working
Go to
Tools->Internet Options->Connections->Lan Settings
Make sure that the use proxy server is not selected if you are on a direct connection or selected with the correct proxy IP and Port if u are using a proxy server
Also DNS client needs to be active for it to work. goto start>control panel>admin tools>services; and look for DNS client. now highlight it by right clicking>properties - set startup type to automatic, then set service status to start
Nov 09, 2010 | Computers & Internet
The ie is not responding
This may be caused by a Third party addon. Please reset the IE settings to disable add-ons:
1. Close any IE or Windows Explorer windows that are currently open.
2. Open a new IE window.
3. Click the Tools button, and then click Internet Options.
4. Click the Advanced tab, and then click Reset.
5. In the Reset Internet Explorer Settings dialog box, click Reset.
6. When Internet Explorer finishes restoring the settings, click Close, and then click OK.
7. Close IE. (The changes will take effect the next time you open IE.)
Jun 27, 2010 | Microsoft Windows Vista Home Premium with...
I cannot access any site as it is telling me i need to enable cookies how would i do this please
To enable cookies in IE 7 or IE 8:
  1. Click Start > Control Panel. (Note: with Windows XP Classic View, click the Windows Start button > Settings > Control Panel).
  2. Double-click the Internet Options icon.
  3. Click the Privacy tab.
  4. Click the Advanced button.
  5. Select the option 'Override automatic cookie handling' under the Cookies section in the Advanced Privacy Settings window.
  6. Select the 'Accept' or 'Prompt' option under 'First-party Cookies.'
  7. Select the 'Accept' or 'Prompt' option under 'Third-party Cookies.' (Note: if you select the 'Prompt' option, you'll be prompted to click OK every time a website attempts to send you a cookie.)
  8. In the Internet Options window, click OK to exit.
To enable cookies in Mozilla Firefox 2.x (PC):
  1. Click Tools > Options.
  2. Click Privacy in the top panel.
  3. Select the checkbox labeled 'Accept cookies from sites.'
  4. Click OK.
To enable cookies in Mozilla Firefox 1.x (PC):
  3. Click the Cookies tab.
  4. Select the checkbox labeled 'Allow sites to set cookies.'
  5. Click OK.
Regards.
Jan 26, 2010 | Microsoft Windows Vista Ultimate Edition
Http does not work but https does
Your Advance Options < in INTERNET OPTIONS of your ie requires to be reset to DEFAULT
Also RESET internet Security Settings to MEDIUM HIGH in the INTERNET OPTION< TOOLS of you IE
Nov 27, 2009 | Microsoft Internet Explorer 8
My E Mail links wont open
The restrictions error?
This is a problem with IE, its not an Outlook error. You need to reset your
internet settings in IE's Tools, Internet Options, Advanced tab. (Or Control
panel, Internet options, Advanced tab).
See
http://www.slipstick.com/problems/link_restrict.htm
for more information.
Nov 16, 2009 | Microsoft Windows XP Professional
How to enabled microsoft vm?
Hey there, first check to make sure that you have it. Click start, run. Type "wjview" and press enter. The top line shows the version. If you get an error, you don't have Microsoft's Virtual Machine.
To enable click start, settings, control panel. Click Internet Options. Under the Advanced tab, find the "Java (Sun)" heading. Check the Box underneath to Enable, Remove the check to disable. Close all Internet Explorer windows to make it have effect.
Microsoft will automatically disable/enable at the same time
let me know if you need anything else
seth
Jun 26, 2009 | Microsoft Windows XP Professional With...
Java script
Thermador Hood VCH36+dimmable?
To turn on JavaScript within Internet Explorer 5.5 or higher:
* Open Internet Explorer
* Click on the "Tools" menu
* Under Tools, click on "Internet Options..."
* Within Internet Options, click on the "Advanced" tab
* Scroll down until you see the "Microsoft VM" heading
* Under Microsoft VM, "JIT compiler for virtual machine enabled" MUST BE CHECKED.
If it is not already selected, click on the box next to the JIT compiler option.
Click "OK" and then restart your computer before using Internet Explorer to come back to this Web site.
* NOTE: Some newer versions of Internet Explorer may not have "Microsoft VM" heading. If this is the case, then javascript may be enabled by default via another method. If you do not see the "Microsoft VM" heading and you are still having difficulty accessing other pages within this site, please call the Web Testing Helpline at (814) 865-8270 or email l-ftcap-tech@lists.psu.edu for further assistance.
Netscape Communicator 5.0 or higher:
* Open Netscape Communicator
* Click on the "Edit" menu
* Under Edit, click on "Preferences......"
* Within Preferences, click on the "Advanced" category on the left.
* When you click on Advanced, options will appear on the right.
"Enable Java" and "Enable JavaScript" (or "Enable native object scripting") MUST BOTH BE CHECKED.
* If they are not already selected, click on the boxes next to the "Enable Java" and "Enable JavaScript" options. Click "OK" and then restart your computer before using Netscape Communicator to come back to this Web site.
Mozilla Firefox 1.0.4 or higher:
* Open Mozilla Firefox
* Under Tools, Click "Options"
* Within Options, click the "Web Features" or "Content" tab
* Make sure "Enable Javascript" is checked
* If it is not already checked, put a check in the check box and click "OK." Then restart your computer before using Mozilla Firefox to come back to this Web site.
Oct 20, 2008 | YouTube Videos
Vista website not found
good to know there is no proxy.Because if there was one that might be the cause of the problem.You have to reset IE back to defaults.Go to the menu bar for IE click Tools,Internet Options,then go to the Advance tab,and click reset.
Aug 22, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
