Question about Universal Electronics Koda Music System With Universal Dock (IP915) Clock Radio
The stereo keeps turning itself off every 3 minutes or so. But the clock stays on and it turns back on for another 3 minutes with no problem. But how to keep it from turning off every three minutes! (koda istereo ip915)
2 Suggested Answers
SOURCE: my istereo ip915 stopped playing
just take ur ipod off and let it run out of battery and then try again same happened to mine once
Posted on Nov 23, 2012
Clock Manuals
leave it running when it gets to 12 oclock it wiil reset itself
May 02, 2013 | Watches
How do I set the time
  • Use the actual stereo to set the clock, not the remote.
  1. Turn off the stereo.
  2. Press "clock/timer" for at least 2 seconds.
  3. Press "memory" to make the hours blink.
  4. Turn the volume knob to adjust the hours.
  5. Press "memory" to make the minutes blink.
  6. Turn the volume knob to adjust the minutes.
  7. Press memory.
  8. Now the clock setting is complete.
Regards, Tony
May 21, 2011 | Sanyo AWM-660 CD Shelf System
How to change clock on Pioneer cxc5719 car radio?
1 Turn the ignition key to On or Accessory. Pull up the emergency brake. 2 Press Source or Power to turn the Pioneer car stereo off. 3 Press the Clock button to display the time. 4 Press and hold the Function or Audio button for 3-4 seconds. The display will come on, and the hour should flash. 5 Use the Up or Down buttons to change the hour setting on the stereo. 6 Press the Left or Right keys to get to the minutes. When the minutes start to flash, press the Up or Down keys to set the clock to the correct minutes. 7 Press the Function or Audio button again to exit.
Mar 25, 2011 | Car Audio & Video
Need to set clock
1) Press the center of the multi-control button (big round knob) once to display the settings mode which appears on the digital display of the stereo unit.
2) Turn the multi-control to until the display shows clock settings.
3) Press the control ONCE to enter this menu.
4) The display wish show the 'Hours' flashing - turn the control to adjust this setting to the correct hour and press the control once to select.
5) The "Minutes" will not be flashing - turn the control to adjust this setting to the correct minute (time) and press the control once to select.
6) Locate the "band/esc" button on the bottom left corner of the stereo face and press once to select and exit the settings.
The clock should now be set. NOTE: There are a LOT of different models of Pioneer car stereos and they will not all have the same menus. The above steps should work on the newer systems.
Sep 05, 2009 | Pioneer Car Audio & Video
HOW DO I SET THE CLOCK
I've had two Pioneer CD players and they both were set the same way. Turn it off then press and hold the AUDIO button if it has one. Then keep pressing it until it gets to the clock. I think on mine the hour starts flashing. When your done just turn it back on. == Answer == I had this problem too. In the far right corner is the "A" (Audio) button. Turn the stereo off and hold the "A" button until the clock comes on. The hour will be blinking. Use the up and down "Select" keys to set that. Then use the right "Select" key to switch to the minutes. Use the up and down keys to set the minutes. Push the "A" button when you're done. My stereo is older than yours but this is what someone who has one like yours told me to try and it worked
Jul 15, 2009 | JVC KD-SX650 CD Player
Cd changer not playing
Check fuses. There are two fuses to this stereo. One that hold memory for the clock and stereo preset buttons and one for turning the stereo on. There are usually two fuse boxes, on inside the vehicle and one under the hood near the car's battery. Again, check ALL fuses. One is usually labeled for the radio/stereo, the other is not.
As for the CD changer, disconnect one of the main car battery terminals for several minutes. This is easier then removing the changer and acts as a reset. Possibley bringing the changer back to working condition. Otherwise, this could be a repair issue, see www.carstereohelp.com
Nov 13, 2008 | 2001 Lexus RX 300
KitchenAid Superba Double Oven clock won't light up
hold down the clock button for 3-5 secs. youve somehow toggled the clock dosplay off.
Nov 05, 2008 | Ovens
Pioneer Supertuner IIID
To change the clock on this Pioneer stereo try this.
1. Press and HOLD the source button till the radio shuts off. Release the button.
2. Press and HOLD the source button again for about 5 seconds until the hour indicator on the clock begins flashing.
3. Press the UP and DOWN buttons to adjust the hours.
4. Press the LEFT or RIGHT arrows to MOVE TO THE MINUTES.
5. Press the UP and DOWN buttons to move the minutes.
6. When complete, press the source button to exit.
Oct 01, 2008 | Pioneer DEH-P690UB CD Player
Clock doesn't stay on
the clock to my kenmore stove wont stay on. only works for about three seconds and then it turns off.
Oct 30, 2006 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Universal Electronics Koda Music System With Universal Dock (IP915) Clock Radio Logo
140 people viewed this question
Top Universal Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Universal Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
