Question about Hamilton Beach Proctor-Silex Simply Coffee Coffeemaker
Anne.m.edwards@hotmail.com. brand new coffee pot. worked a couple of times. now, light comes on, but heating surface does not get hot, and the water does not move from the reservoir.
SOURCE: water leaking from bottom of coffee maker
The tool is a special tool that is either meant to be vandal or idiot proof. Being one of the aforementioned I bought a set of these special tools at Sears. The first problem is Cuisinart recesses the hole so much that my tool can not remove the screw. I tried widening the hole using a drill bit but it cracked and broke.
As for using a hose from a hardware store, I have been there and done that. The hose attatched to the warmer side melted and leaked everywhere.
Posted on May 14, 2008
  • 18 Answers
SOURCE: coffee maker leaking water out of every hole in the bottom
hi ninerh! this may be an easy fix for you, or may require some replacement parts. if you need a new length of hose, try a hardware store or try a local medical supply as a source for new tubing (must be right size, food-safe & able to withstand heat) or espressoparts.com/cafeparts.com. if you can turn a screwdriver, remove ten screws in base plate (machine must be upside down & make sure it's cooled down/unplugged first!) gently lift base away--bottom most hose leading from where resevoir sits to pump should be held in place by a cheap wire clip; this may have come loose over time w/ vibration of pump, or it may be damaged. *be careful removing bottom of machine b/c wires lead from it to inside of machine; don't be scared, just be careful! good luck!
Posted on Jan 11, 2009
SOURCE: Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
Posted on Mar 08, 2009
SOURCE: GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Posted on Apr 03, 2009
  • 82 Answers
SOURCE: I fill the pot with water and push the power
Have you tried cleaning with vinegar, lime buildup can cause the water to stop drawing.
Posted on Jun 19, 2009
What makes a perculator heat?
Hi, If you have a Farberware, Just look into the bottom of the pot. There you will see what looks like a hole in the pot. That is the high heating element, under the pot, when you go to make coffee the pump ( rod) sits into the hole. When you turn it on to make coffee the high heating element that the pump is in gets very hot and starts pushing the water that is in the hole to the top (that is called perking) the hot water goes over the the top and the drops into the coffee, This keeps going on until the thermostat feels it has reached 190 degrees or close to it and turns the high element off. While this is running it's cycle the keep warn is on helping the water to get hot, when the main element is off the keep warm element that runs around the bottom of the pot stays on all the time the pot is plugged in. Should the coffee get to cold the thermostat will turn the main heating element back on until it is back to 190. This system was developed by Farberware and a lot of makers copied it, But Farberware sold the pots and was known for a FAST and HOT cup of coffee. Farberware started making them in China and the pots are having a hard time keeping it up to American standers, and parts are very scarce.Farberware USA pots have been around a long,long time and are still going strong . I hope this helped you to understand how the pot works.
Dec 09, 2010 | Faberware 12-55 Cup Coffee Urn
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Sep 13, 2010 | Bunn VPR Coffee Maker
My coffe maker turns on but nothing comes out, I already checked the spray head & its,not clogged, what can I do
check and make sure the heating pad gets hot if it does not then in the bottom inside the Base you will have to take it apart and under the heating pad their will be some wires their will be a thermal resistor that will be attached to a part of the element this part needs replacing and can be purchased at radio shack for about $1.50 replace it with the new one and reassemble as it was then try the unit. it should be working fine if the heating pad gets hot then you have another issue most likely the water tube come loose at the bottom of the water tank simply re-attach and reassemble some times wile filling the tank when the unit is still hot a steam shock will force the tube off. explanation of the workings the water tank supply water to a tube that attaches to the heating element the water runs though the element heating by the time it reaches the other side it is hot enough to force the water to the top where it is expended to the coffee grounds and brews the coffee like the same way a peculator pot works only difference is the water runs through a tube under the heating element instead of a fire under the pot. hope this helps the radio shack link for the thermal resistor or thermal fuse is the proper name is http://www.radioshack.com/search/index.jsp?kwCatId=&kw=thermal&origkw=thermal&sr=1
chose the proper temp most are for home use at 128°C (262.4°F) Thermal Protector Fuses
Aug 30, 2010 | Bunn VPR Coffee Maker
The unit brews coffee OK. About 2-3 times per hour, the brewing element turns on and bubbles for a few minutes. This annoys me. Will it shorten the life of the coffee maker? It has done this since it was...
Hi. The pot is turning itself on because the thermostat is telling it to do so, because the coffee in the pot is getting cold. You might try feeling the surface under the pot is sitting on to see if it is hot. if it is not hot the keepwarm element is not working, if so get rid of it and but a heavy duty coffee maker ( Bunn ) It does not pay to repair them because the fright to and fro, plus the cost of the repair. Probably made in China. Good luck. bobbyone
Aug 13, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
My tim hortons coffee maker is not brewing as quickly..s there a wayto clean it
Make a 1/2 pot 50/50 mixture of cold water and white vinegar then run it through the machine in normal brewing fashion. Place a clean filter in the brewing cup to catch the white deposits that are removed. Allow the mixture to cool, then repeat the process several times while using the same filter. Finally, run several pots of fresh water through to work out the taste of the vinegar. Repeat whenever the brewing time seems to be excessive.
Feb 02, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Gevalia CM-500 12 cup problem.
Underneath the hot pad that the carafe sits on, there are two thermal fuses that are inside tubes that are clamped to the heating element with spring clamps.
Remove the bottom of the unit (5 screws), unclamp the thermal fuse tubes, slide the tubes to one side and check the each fuse with an ohmmeter. If one of them is open, that's your problem.
Aug 30, 2008 | Gevalia CM-500 12 Cup Coffee Maker
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
The power cord is hot but no lights or clock, nothing works.
ok " un plug coffee pot, if you take the base apart you will find the wiring, follow wiring to a round disk on the heating tube ,
that disk is a heat sensor , replace that sensor .
any appliance parts store will have them
sensor is bi-metal on the inside when it gets too hot it shuts power down.
Jan 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Water is not heating
It is probily the thermal switch between hot wire and element. Check to see if you are getting power through this switch.
Sep 26, 2006 | Mr. Coffee TFTX85 Coffee Maker
Hamilton Beach Proctor-Silex Simply Coffee Coffeemaker Logo
269 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
